In my project I use ADC. But I try to avoid dynamic overlay loading in order to increase boot speed.
So I move code from ADC overlay (BB-ADC-00A0.dts) to main device tree source (am335x-boneblack.dts):
ocp {
/* ADC filesystem helper
test_helper: helper {
compatible = "bone-iio-helper";
vsense-name = "AIN0", "AIN1", "AIN2", "AIN3", "AIN4", "AIN5", "AIN6", "AIN7";
vsense-scale = <100 100 100 100 100 100 100 100>;
status = "okay";
/* Enable ADC */
&tscadc {
status = "okay";
adc {
ti,adc-channels = <0 1 2 3 4 5 6 7>;
After boot I found out that directory /sys/devices/ocp.*/helper.*/ does not contain AIN files. dmesg out dos not contain messages from
bone-iio-helper driver. Somehow bone-iio-helper driver haven't been loaded while device tree processing.
Is there a way to fix this issue?
Which OS?
Run
uname -a
cat /etc/dogtag
cat /etc/debian_version ###if debian
If the device tree was loaded and you have a late version of debian,
probably you need to look in /sys/devices/platform/ocp/ for the
directory 44e0d000.tscadc
There you will find the directories TI-am335x-adc/iio\:device0
Inside, you will find in_voltage[06].raw
These correspond to the AIN[0-6] for earlier OSes.
If the device tree was not loaded check dmesg.
Chad
