I am working on assembler code with arm-linux-gnueabihf-as with a third part code project. I find that the assembler has errors:
arm-linux-gnueabihf-as test_sp0.s
test_sp0.s: Assembler messages:
test_sp0.s:1: Error: junk at end of line, first unrecognized character is `=’
test_sp0.s:3: Error: bad instruction `arm’
test_sp0.s:5: Error: bad instruction `area ||.text||,CODE,READONLY,ALIGN=2’
test_sp0.s:7: Error: bad instruction `export fl_array_m_ic32’
test_sp0.s:9: Error: bad instruction `input’
test_sp0.s:10: Error: bad instruction `r0 -p_i0_left’
test_sp0.s:11: Error: bad instruction `r1 -p_i0_right’
test_sp0.s:12: Error: bad instruction `r2 -p_i1_left’
test_sp0.s:13: Error: bad instruction `r3 -p_i1_right’
test_sp0.s:14: Error: bad instruction `sp -p_ot_left’
test_sp0.s:15: Error: bad instruction `sp +4-p_ot_right’
test_sp0.s:16: Error: bad instruction `sp +8-count’
test_sp0.s:17: Error: bad instruction `sp +12-shift’
test_sp0.s:19: Error: bad instruction `return’
test_sp0.s:20: Error: bad instruction `n/A’
test_sp0.s:22: Error: bad instruction `global Variables Accessed’
test_sp0.s:23: Error: bad instruction `none’
test_sp0.s:24: Error: bad instruction `cortex_a8’
for the code:
ARM |
AREA ||.text||, CODE, READONLY, ALIGN=2 |
EXPORT | fl_array_m_ic32 |
; Input
; | r0 - p_i0_left |
; | r1 - p_i0_right |
; | r2 - p_i1_left |
; | r3 - p_i1_right |
; | sp - p_ot_left |
; | sp + 4 - p_ot_right |
; | sp + 8 - count |
; | sp + 12 - shift |
; Return
; | N/A |
; Global Variables Accessed
; | None |
;;;;;;;;;;;;;;;;;;;;;;;;;;;; | IF :DEF:CORTEX_A8 |
fl_array_m_ic32 | PROC |
It is obvious that the assembler treats the comment char ‘;’ as asm instruction. I used other compiler before, but not arm-linux-gnueabihf-as. From the asm code format, do you think what assembler can work on it? or are there some switches with arm-linux-gnueabihf-as to work on this asm code?
