Dear All,
I’m trying to port linux on beaglebone using Buildroot.
But rootfs is mounted as read-only, but I need write-enable. What shall I do
Following is snap of my configurations
1.Kernel configuration file as below …
Dear All,
Wasn't linux already ported to beaglebone over a year ago?
Buildroot's default is to mount the root filesystem as read-only.
There's an option in the Buildroot configuration menus under "System
Configuration" to change this. It is the
BR2_TARGET_GENERIC_REMOUNT_ROOTFS_RW option in the config file.
Or you could manually remount the root filesystem by running:
mount -o remount,rw /
Thanx Frank,
It worked, Thanx again.
Ravi
