The BBB does not even see the Edimax, as when typing in IFCONFIG it does not show. The Edimax’s blue LED does not come on either.
I have also performed the following troubleshooting:-
Power supply is plenty - 5v 4amp.
Plugged the Edimax directly into the USB of the BBB without any hub.
The Edimax is fine, as it works with my Windows machine.
The USB on the BBB seems fine as I can use a mouse and keyboard without an issue
Ethernet works without any issues.
I can live with the fact that my BBB doesn’t work on my monitor and that I cannot use an SD card to boot from. But I really need to get it going with Wifi, so any suggestion are very much welcome!
p.s. Is everyone else having these sorts of problems…or is it me and my BBB?
I know this one is complete but wanted to refresh since I just tired the $10 Edimax mini wifi from amazon( http://amzn.com/B003MTTJOY ) and got it working with Debian wheezy running Machinekit super easy:
show the Edimax is recognized after plugging it in:
lsusb | grep Edimax
See there are some RTL firmware installed:
ls /lib/firmware/rtlwifi/
Install the WPA Supplicant package for WPA2 security
sudo apt-get install wpasupplicant
Edit/create the WPA Supplicant configuration file for your network:
sudo vi /etc/wpa_supplicant.conf
