I am using Ubuntu on Beagleboard rev c5. I was able to configure wpa_supplicant and connect to the network, however after working for an hour or so the network became unstable. It started dropping packets and started taking a longtime to reassign ip address. (sudo dhclient wlan0 used to work very smoothly). My Edimax wifi dongle had developed a small crack so I though that might be the issue. So I ordered new dongle and tried to make it work. It recognized the interface however as wlan8 (instead of wlan0) and the system started working fine. However again after a couple of hours there was a problem with ip address renewal (it would take a few minutes before it could get an ip address) and after a few boots it is now recognizing wlan card as wlan9 and then wlan10.The chipset is 8192cu.
In between I also saw the following messages while trying to get an IP address. RTNETLINK answers: file exists. On other ocassions it automatically tired to ping 192.168.1.254 and then failed. Following are my settings for /etc/network/interfaces
auto lo
iface lo intet loopback
auto wlan8
iface wlan8 inet dhcp
pre-up wpa_supplicant -Dnl80211 -iwlan8 -c /etc/wpa_supplicant/wpa_supplicant.conf -B
post-down killall -q wpa_supplicant
Following is wpa_supplicant.conf
ctrl_interface = DIR=/run/wpa_supplicant
ap_scan = 1
network ={
ssid = " "
psk = " "
proto = WPA RSN
key_mgmt =WPA-PSK
pairwise = CCMP TKIP
What am I doing wrong ? How does linux determine the interface number ?
Thanks for your help
