What is a known working USB to wifi adapter. Currently I was trying to use a Netgear a6210 that works fine on Ubuntu x64 metal box but its crashing / rebooting the SBC AI-64.
Running NVMe and suspect it might not have enough power on the board. Its on a stiff lab supply and pulling upto 2.7 amps??
When you say you run an NVMe you mean having boot an M2 hard disk on the pci port ?
I have successfully load more than 15 watts with a good lab power supply for booting with two 5V USB fans at 250ma each without the lab supply the boot wasn’t possible ( peak load at startup collapse the boot process a big capacitor would probably do the trick but that another story… )
