just a yes or no ... if i configure and build buildroot for a BBB,
will the generated artifacts simply "work" if i copy them to an
appropriately formatted SD card?
i ask as i downloaded the current state of buildroot, did the
obligatory:
as in, no reference to the kernel image file or the dtb file, so i'm
only assuming that all of that is somehow encoded in the u-boot.img.
i'm going to dig deeper later, but can anyone who's done this verify
that just copying those artifacts to an SD card will give me a
bootable system? thanks.
It looks like you have most of the parts there. I think the am335x will use the file system and load the mlo. So yep, it looks like you can copy the files over and the bbb should boot off of it (assuming you hold the boot button or have zeroed out the first block of emmc). At least you should get into uboot. Not sure what that roofs.ext2 is but that’s probably because we boot to another partition, that may work just fine.
Apologies for the late follow-up here. I’ve pretty much the same problem. Using BR 2015.02 I get a sane looking set of outputs post build.
u-boot spew follows.
Both mmc 0:1 and mmc 0:2 show the expected SD card content. It just looks like uEnv is wrong (?).
Any help here would be much appreciated. TVMIA
-----------------------snip----------------------------------------
micro SD card found
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
96 bytes read in 3 ms (31.3 KiB/s)
Importing environment from mmc ...
Running uenvcmd ...
## Error: "loadimage" not defined
reading ramdisk.gz
** Unable to read file ramdisk.gz **
reading /am335x-boneblack.dtb
34004 bytes read in 9 ms (3.6 MiB/s)
Booting from ramdisk ...
Wrong Image Format for bootm command
ERROR: can't get kernel image!
reading /uImage
** Unable to read file /uImage **
U-Boot#
micro SD card found
reading uEnv.txt
Running uenvcmd ...
reading ramdisk.gz
Yuck! bootm!!
reading /uImage
U-Boot#
You have a really old bootloader in eMMC.. Robert's original post
assumes at-least the Debian May 2014 release or newer stored in eMMC..
reading uEnv.txt 96 bytes read in 3 ms (31.3 KiB/s) Loaded environment from uEnv.txt Importing environment from mmc … Running uenvcmd … ## Error: “loadimage” not defined
This is what a “modern” "first stage " uEnv.txt looks like ( Debian wheezy 7.8 )
