on every Device
Is this a general problem? Are some preparations required or is it not possible for win10, 21h1
on every Device
This ‘driver’ is not required for current supported images:
https://beagleboard.org/latest-images
If for some reason you need to install the driver, you should disable the windows signature driver enforcement - How to Enable or Disable Driver Signature Enforcement in Windows 10 | Tutorials
