I would like to know:
[1] If any one out there has used any of the above or other with success on the Rev C boards(Debian)?
[2] Any advice would be welcomed?
Note: I know I can use a wireless Ethernet Adapter, but I prefer to use a wired version in this case because of security reasons.
I have used a number of “USB 2.0 3-port hub with Ethernet” units in the past with Beagle Boards (not specifically the bone).
I don’t recall the chip in them. They usually run about US $9 from China. I rip them apart, cut off the
USB sockets and build them into the cabinet of my unit. These have worked well. The very first time
I did this I needed to rebuild the kernel, since then the Robert Nelson kernels have supported that
unit without special attention. Sorry, I don’t have one unboxed here to see what the chip is.
I have not specifically tested this with the bone, but it really ought to work fine there, too.
Thanks for the much appreciated guidance. I don’t know if you or someone out there can give me the steps to compile the kernel module…I am a newbie to this sort of stuff, that’s why.
Good point Robert … I haven’t purchased the adapter as yet, so I just wanted to make sure before hand if anyone had tried it as yet and what to do if I get a problem.
Normally for usb devices. (ignoring wifi/bluetooth as those have other
issues) Even if the supplier never provided a linux driver, linux
usually has support, as usb devices are pretty easy to sniff and write
a driver too..
No, the ones I’ve used have three USB sockets that are on a swivel, like this
eBay item # 300965379372
You can’t tell from the eBay listing, but the controller I have had good luck with is the MosChip
MCS7830CV
But, I can’t absolutely say what chip is inside any specific China hub+ethernet, just that that
one in the eBay listing I give above LOOKS from the outside to be the same.
