Interfacing wifi module (wl12xx ti chipset) with beaglebone black. Unable to bring up wlan0 interface, please guide me for proper device tree configuration.
After booting excecuted
modprobe wlcore_sdio
modprobe wl12xx
Below are my configurations.
Kernel : 4.1
Rootfs : Debian
Device Tree:
vwlan_en_reg: regulator-vwlan-en {
compatible = “regulator-fixed”;
regulator-name = “vwlan_en”;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
gpio = <&gpio0 27 0>;
enable-active-high;
startup-delay-us = <70000>;
pinctrl-names = “default”;
pinctrl-0 = <&wlan_enable_pins>;
&am33xx_pinmux {
wlan_pins: pinmux_wlan_pins {
pinctrl-single,pins = <
0x28 (PIN_INPUT_PULLUP | MUX_MODE7) /* gpio0_26 WL_IRQ */
wlan_enable_pins: pinmux_wlan_enable_pins {
0x2c (PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpio0_27 WL_EN */
mmc2_pins: pinmux_mmc2_pins {
0x3C (PIN_INPUT_PULLUP | MUX_MODE3) /* mmc2_dat3 /
0x38 (PIN_INPUT_PULLUP | MUX_MODE3) / mmc2_dat2 /
0x34 (PIN_INPUT_PULLUP | MUX_MODE3) / mmc2_dat1 /
0x30 (PIN_INPUT_PULLUP | MUX_MODE3) / mmc2_dat0 /
0x8c (PIN_INPUT_PULLUP | MUX_MODE3) / mmc2_clk /
0x88 (PIN_INPUT_PULLUP | MUX_MODE3) / mmc2_cmd */
&i2c2 {
pinctrl-0 = <&i2c2_pins>;
status = “okay”;
clock-frequency = <100000>;
/* ODIN-W160 EEPROM */
eeprom@5D {
compatible = “at,24c64”;
reg = <0x5D>;
pagesize = <32>;
&mmc2 {
non-removable; /* TI specific feature /
bus-width = <4>;
cap-power-off-card; / TI specific feature */
vmmc-supply = <&vwlan_en_reg>;
pinctrl-0 = <&mmc2_pins &wlan_pins>;
status = “okay”;
#address-cells = <1>;
#size-cells = <0>;
wlcore: wlcore@0 {
compatible = “ti,wl1273”;
reg = <2>;
interrupt-parent = <&gpio0>;
interrupts = <26 0x4>;
ref-clock-frequency = <38400000>;
dmesg log:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.3+ (dileep@ubuntu) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #2 SMP PREEMPT Tue Aug 18 16:54:12 IST 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] cma: Reserved 24 MiB at 0x9e000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 130560
[ 0.000000] free_area_init_node: node 0, pgdat c0f4c700, node_mem_map df96d000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130560 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] PERCPU: Embedded 13 pages/cpu @df925000 s22336 r8192 d22720 u53248
[ 0.000000] pcpu-alloc: s22336 r8192 d22720 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129408
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw nfsroot=192.168.0.101:/home/dileep/BeagleBone/rootfs_debian ip=192.168.0.105:::::eth0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 475580K/522240K available (10502K kernel code, 881K rwdata, 3680K rodata, 672K init, 901K bss, 22084K reserved, 24576K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0de1d40 (14184 kB)
.init : 0xc0de2000 - 0xc0e8a000 ( 672 kB)
.data : 0xc0e8a000 - 0xc0f6666c ( 882 kB)
.bss : 0xc0f69000 - 0xc104a648 ( 902 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000040] clocksource timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000054] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000437] Console: colour dummy device 80x30
[ 0.000465] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 0.000474] This ensures that you still see kernel messages. Please
[ 0.000482] update your kernel commandline.
[ 0.000504] Calibrating delay loop… 996.14 BogoMIPS (lpj=4980736)
[ 0.088666] pid_max: default: 32768 minimum: 301
[ 0.088826] Security Framework initialized
[ 0.088911] AppArmor: AppArmor disabled by boot time parameter
[ 0.088921] Yama: becoming mindful.
[ 0.089140] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089154] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090088] Initializing cgroup subsys blkio
[ 0.090116] Initializing cgroup subsys memory
[ 0.090164] Initializing cgroup subsys devices
[ 0.090185] Initializing cgroup subsys freezer
[ 0.090213] Initializing cgroup subsys net_cls
[ 0.090231] Initializing cgroup subsys perf_event
[ 0.090249] Initializing cgroup subsys net_prio
[ 0.090309] CPU: Testing write buffer coherency: ok
[ 0.090373] ftrace: allocating 34337 entries in 101 pages
[ 0.185862] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.185994] Setting up static identity map for 0x80008280 - 0x800082d8
[ 0.238749] Brought up 1 CPUs
[ 0.238776] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[ 0.238786] CPU: All CPU(s) started in SVC mode.
[ 0.239723] devtmpfs: initialized
[ 0.258431] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.280001] omap_hwmod: tptc0 using broken dt data from edma
[ 0.280242] omap_hwmod: tptc1 using broken dt data from edma
[ 0.280462] omap_hwmod: tptc2 using broken dt data from edma
[ 0.286479] omap_hwmod: debugss: _wait_target_disable failed
[ 0.341305] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.343537] xor: measuring software checksum speed
[ 0.438761] arm4regs : 1218.400 MB/sec
[ 0.538693] 8regs : 1090.800 MB/sec
[ 0.638691] 32regs : 807.600 MB/sec
[ 0.738692] neon : 1662.000 MB/sec
[ 0.738702] xor: using function: neon (1662.000 MB/sec)
[ 0.738887] pinctrl core: initialized pinctrl subsystem
[ 0.740981] NET: Registered protocol family 16
[ 0.743658] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.749925] OMAP GPIO hardware version 0.1
[ 0.762640] No ATAGs?
[ 0.762674] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.764679] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.764700] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.968887] raid6: int32x1 gen() 205 MB/s
[ 1.138747] raid6: int32x1 xor() 165 MB/s
[ 1.308851] raid6: int32x2 gen() 241 MB/s
[ 1.478767] raid6: int32x2 xor() 188 MB/s
[ 1.648854] raid6: int32x4 gen() 234 MB/s
[ 1.818742] raid6: int32x4 xor() 162 MB/s
[ 1.988999] raid6: int32x8 gen() 183 MB/s
[ 2.158816] raid6: int32x8 xor() 117 MB/s
[ 2.328691] raid6: neonx1 gen() 1452 MB/s
[ 2.498720] raid6: neonx2 gen() 1864 MB/s
[ 2.668706] raid6: neonx4 gen() 785 MB/s
[ 2.838694] raid6: neonx8 gen() 321 MB/s
[ 2.838703] raid6: using algorithm neonx2 gen() 1864 MB/s
[ 2.838712] raid6: using intx1 recovery algorithm
[ 2.848426] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 2.849484] reg-fixed-voltage regulator-vwlan-en: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wlan_enable_pins, deferring probe
[ 2.852189] vgaarb: loaded
[ 2.852959] SCSI subsystem initialized
[ 2.853364] libata version 3.00 loaded.
[ 2.853752] usbcore: registered new interface driver usbfs
[ 2.853837] usbcore: registered new interface driver hub
[ 2.853949] usbcore: registered new device driver usb
[ 2.854623] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 2.854684] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 2.854724] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 2.854881] pps_core: LinuxPPS API ver. 1 registered
