Dear all,
Unfortunately, my Beaglebone (especially wlcore) crashes regularly after RT throttling is enabled. The syslog looks as follows:
Feb 19 19:06:47 debian systemd[1]: Removed slice User Slice of debian.
Feb 19 19:12:22 debian hostapd: SoftAp0: STA 50:eb:71:d5:37:f2 IEEE 802.11: disassociated due to inactivity
Feb 19 19:12:23 debian hostapd: SoftAp0: STA 50:eb:71:d5:37:f2 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Feb 19 19:14:04 debian kernel: [ 607.589484] sched: RT throttling activated
Feb 19 19:14:54 debian kernel: [ 657.589610] wlcore: ERROR ELP wakeup timeout!
Feb 19 19:14:54 debian kernel: [ 657.599703] ------------[ cut here ]------------
Feb 19 19:14:54 debian kernel: [ 657.600010] WARNING: CPU: 0 PID: 1600 at drivers/net/wireless/ti/wlcore/main.c:796 wl12xx_queue_recovery_work.part.10+0x68/0x6c [wlcore]
Feb 19 19:14:54 debian kernel: [ 657.600018] Modules linked in: aes_arm_bs crypto_simd cryptd xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 wl18xx wlcore mac80211 rfcomm bnep cfg80211 hci_uart btqca bluetooth ecdh_generic w1_therm w1_gpio wlcore_sdio evdev usb_f_mass_storage usb_f_acm u_serial iptable_nat nf_conntrack_ipv4 usb_f_ecm nf_defrag_ipv4 bc_example(O) nf_nat_ipv4 usb_f_rndis nf_nat u_ether nf_conntrack pvrsrvkm(O) libcomposite iptable_mangle iptable_filter uio_pdrv_genirq uio spidev pruss_soc_bus pru_rproc pruss pruss_intc ip_tables x_tables
Feb 19 19:14:54 debian kernel: [ 657.600223] CPU: 0 PID: 1600 Comm: hostapd Tainted: G O 4.14.108-ti-r113 #1
Feb 19 19:14:54 debian kernel: [ 657.600229] Hardware name: Generic AM33XX (Flattened Device Tree)
Feb 19 19:14:54 debian kernel: [ 657.600275] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
Feb 19 19:14:54 debian kernel: [ 657.600296] [] (show_stack) from [] (dump_stack+0x80/0x94)
Feb 19 19:14:54 debian kernel: [ 657.600312] [] (dump_stack) from [] (__warn+0xf8/0x110)
Feb 19 19:14:54 debian kernel: [ 657.600325] [] (__warn) from [] (warn_slowpath_null+0x30/0x38)
Feb 19 19:14:54 debian kernel: [ 657.600442] [] (warn_slowpath_null) from [] (wl12xx_queue_recovery_work.part.10+0x68/0x6c [wlcore])
Feb 19 19:14:54 debian kernel: [ 657.600650] [] (wl12xx_queue_recovery_work.part.10 [wlcore]) from [] (wl12xx_queue_recovery_work+0x24/0x28 [wlcore])
Feb 19 19:14:54 debian kernel: [ 657.600817] [] (wl12xx_queue_recovery_work [wlcore]) from [] (wl1271_ps_elp_wakeup+0x240/0x24c [wlcore])
Feb 19 19:14:54 debian kernel: [ 657.600982] [] (wl1271_ps_elp_wakeup [wlcore]) from [] (wlcore_op_set_key+0x78/0x134 [wlcore])
Feb 19 19:14:54 debian kernel: [ 657.601630] [] (wlcore_op_set_key [wlcore]) from [] (ieee80211_key_enable_hw_accel+0x118/0x3f8 [mac80211])
Feb 19 19:14:54 debian kernel: [ 657.602116] [] (ieee80211_key_enable_hw_accel [mac80211]) from [] (ieee80211_key_link+0x16c/0x28c [mac80211])
Feb 19 19:14:54 debian kernel: [ 657.602424] [] (ieee80211_key_link [mac80211]) from [] (ieee80211_add_key+0x1b4/0x2b0 [mac80211])
Feb 19 19:14:54 debian kernel: [ 657.603139] [] (ieee80211_add_key [mac80211]) from [] (nl80211_new_key+0x144/0x34c [cfg80211])
Feb 19 19:14:54 debian kernel: [ 657.603462] [] (nl80211_new_key [cfg80211]) from [] (genl_rcv_msg+0x24c/0x44c)
Feb 19 19:14:54 debian kernel: [ 657.603482] [] (genl_rcv_msg) from [] (netlink_rcv_skb+0xe0/0x114)
Feb 19 19:14:54 debian kernel: [ 657.603498] [] (netlink_rcv_skb) from [] (genl_rcv+0x34/0x44)
Feb 19 19:14:54 debian kernel: [ 657.603511] [] (genl_rcv) from [] (netlink_unicast+0x19c/0x250)
Feb 19 19:14:54 debian kernel: [ 657.603524] [] (netlink_unicast) from [] (netlink_sendmsg+0x2d4/0x3b4)
Feb 19 19:14:54 debian kernel: [ 657.603544] [] (netlink_sendmsg) from [] (sock_sendmsg+0x44/0x54)
Feb 19 19:14:54 debian kernel: [ 657.603559] [] (sock_sendmsg) from [] (___sys_sendmsg+0x23c/0x250)
Feb 19 19:14:54 debian kernel: [ 657.603573] [] (___sys_sendmsg) from [] (__sys_sendmsg+0x60/0x9c)
Feb 19 19:14:54 debian kernel: [ 657.603587] [] (__sys_sendmsg) from [] (SyS_sendmsg+0x18/0x1c)
Feb 19 19:14:54 debian kernel: [ 657.603608] [] (SyS_sendmsg) from [] (ret_fast_syscall+0x0/0x54)
Feb 19 19:14:54 debian kernel: [ 657.615753] ā[ end trace 1c6afe2c155c40e4 ]ā
Know Iām not sure if the wlcore crashes and then activates RT throttling or if another process crashes, which activates RT throttling and then wlcore crashes.
Is there a possibility to find out why RT throttling is activated?
Thank you for your help and kind regards
Chraebi
