The lines below I put in a script and ran it from a command line with a wire run from pin 3 to pin 4 on J8 and it prints a 1 and then a 0. I disconnect my wire and I get 0 both times. So I am setting one pin high/low and detecting state on another. Then I made 3 scripts by taking pieces of these - one that left out the unexports at the end, one that just sets 38 high and one that sets it low. I put the detection of the input bit changing into a C++ program. In my C++ program, I opened /sys/class/gpio/gpio39/value, read it and then dropped into a loop where I would sleep for a second and read looking for a change. I closed the port outside the loop. I never saw a change. Then I moved the ope and close of the port inside the loop and it now works. Do you have to close and re-open the ports every time you want to read the current state? That seems really inefficient.
GPIO1_6 = (32 * 1) + 6 = 38 It’s J8 pin 3
GPIO1_7 = (32 * 1) + 7 = 39 It’s J8 pin 4
echo 38 > /sys/class/gpio/export
echo 39 > /sys/class/gpio/export
echo 0x0f > /sys/kernel/debug/omap_mux/gpmc_ad6
echo 0x27 > /sys/kernel/debug/omap_mux/gpmc_ad7
set gpio pin 38 to output
echo out > /sys/class/gpio/gpio38/direction
set gpio pin 39 to input
echo in > /sys/class/gpio/gpio39/direction
set the pin high
echo “high” > /sys/class/gpio/gpio38/direction
#read the input it is looped back to
cat /sys/class/gpio/gpio39/value
set the pin low
echo “low” > /sys/class/gpio/gpio38/direction
echo 38 > /sys/class/gpio/unexport
echo 39 > /sys/class/gpio/unexport
