Hi
I am disabling serial port of BBXM once my booting is over. By commenting the line
#S:2345:respawn:/sbin/getty 115200 ttyO2
Now I have a script for writing onto the serial port. I have kept this script in /etc/init.d and created a symlink in rc5.d and rc3.d.
The content of the script file is:
#!/bin/bash
while true
do
echo “Writing to Serial port” > /dev/ttyO2
done
But once my booting is over, my minicom is not receiving anything from the board.
Whats the problem in this procedure??
Thanks!
Hi
the line
#!/bin/bash
while true
do
echo "Writing to Serial port" > /dev/ttyO2
done
board.
Not sure, but you might want to run 'stty' to make sure your serial
port is in the desired mode.
I tried adding this line before I write to the serial port.
stty -f /dev/ttyO2 115200
Still not receiving anything in minicom.
Is the symbolic link creation right? I am doing the following for creating a symlink:
Saved the shellscript writeserial.sh in /etc/init.d
For creating a symlink, I created a S75writeserial.sh using
ln -s /etc/init.d/writeserial.sh S75writeserial.sh
Also I tried creating in rc3.d too.
Hi I did the same procedure again. But this time instead of taking the SD card out and putting it to pc. I directly went to my vi editor disabled the serial port, then made an initscript in /etc/init.d and created a symlink in rc5.d and now it is working fine.
I couldnt understand why it was not working before.
Anyways thank you Jason
