I am able to read/write the data from beagle bone black A5 after disabling the WP . But after power cycle the board it is not getting booted. Iam not getting why it is happening like this. Iam using ti SDK
#1 You’re writing what to the eeprom ?
#2 Which Linux image are you attempting to use ?
#3 Which TI SDK ?
So the Debian images now days I believe go by what is in eeprom, to decide which board file to load at boot. No properly formatted, or recognized eeprom, no board file detection, no boot.
So . . .
william@beaglebone:~$ cat /uEnv.txt
##These are needed to be compliant with Angstrom’s 2013.06.20 u-boot.
loadaddr=0x82000000
fdtaddr=0x88000000
rdaddr=0x88080000
loadxfdt=load mmc 0:1 ${fdtaddr} /boot/dtbs/${uname_r}/${fdtfile}
check_dtb=if test -n ${dtb}; then setenv fdtfile ${dtb};fi;
Ok, in order to understand fully what is happening here, we’d need to read through the source for uboot, But I can in short tell you with reasonable certainty what is going on here.
This is attempting to load the board device tree file from the first partition of device mmc0. ${fdtaddr} is a variable created in this file near the top, so we know what this is. ${fdtfile} however is not defined in this file so we have to assume it is defined by uboots executable. How does uboot do this ? We’d have to read the source code to be 100% sure, but like I said I am reasonably sure that uboot reads from the eeprom, to make this determination.
This, I’m not sure exactly what is going on. What is obvious however that when some condition is met( this is the part im not sure of ), then the environment variable fdtfile is set to environment variable dtb. I can make several assumptions here what exactly ${dtb} is, but I would not feel comfortable without reading through uboots source code . . .
Anyway, “we” can bypass a lot of this behavior simply by hard coding the value for the required device tree file. However, if one burns up their board( and this is possible )in the process. Then that is their own responsibility.
Actually now that I think on this, I believe this variable to be set, or settable from the second stage uEnv.txt file.
With a blank/wrong board eeprom, things start going very wrong here:
Especially right here:
Hi Robert,
Thanks for the reply. So the code you’ve linked there seems to be in relation to reading from the eeprom, making assumptions based on values in the eeprom, and setting the PMIC values accordingly ?
So if I understand this correctly, this means if no eeprom then no PMIC settings ? Re-reading the source again . . .
Correct.. if no eeprom, the boot stops very early and just bail's..
Correct… if no eeprom, the boot stops very early and just bail’s…
Ah, so it used to be that we could manually set the device tree board file. I guess this is no longer possible ?
Well, you could manually set the device tree, but the eeprom lookup happens
in the SPL, so you never get into the full u-boot.img..
For "blank" boards, we do have a patch to assume bbb.. (for the oem's that
produce the bbb's)
if this is done on the white, lots of bad things can happen, ddr2 vs ddr3,
ldo3...
Well, you could manually set the device tree, but the eeprom lookup happens in the SPL, so you never get into the full u-boot.img…
For “blank” boards, we do have a patch to assume bbb… (for the oem’s that produce the bbb’s)
if this is done on the white, lots of bad things can happen, ddr2 vs ddr3, ldo3…
Yeah, sorry, I asked the wrong question. Although you answered the question I had anyway. I know there is the ${dtb} environment variable. Then, I’m reasonably sure what that variable is for. I just was not sure how that played out with the eeprom checks and all. Now, I know.
So without ${dtb} we’d not have a way to set various board files, for the same board, from within the second stage uEnv.txt file.
