In Putty, I’ve enabled x11 forwarding, with the ‘X display location’ set to 0.0
The BBB’s X -version is 1.16.4, with the the /etc/ssh/ssh_config set to:
ForwardX11 yes
ForwardX11 Trusted yes
and /etc/ssh/sshd_config:
X11Forwarding yes
I’ve also forced the DISPLAY variable to point to my local machine’s IP:
export DISPLAY=192.168.1.140:0.0
and verified it’s set correctly (using ‘echo $DISPLAY’)
Finally restarted, ‘service ssh restart’ and ‘service sshd restart’
Unfortunately, when I enter ‘xterm&’, I get the error
“Can’t open display: %s”
and the locally running xming (Win8) never shows anything. Interestingly, the Xming log seems to show an authentication error?
winClipboardProc - Hello
DetectUnicodeSupport - Windows Vista
winClipboardProc - DISPLAY=127.0.0.1:0.0
winMultiWindowXMsgProc - XOpenDisplay () returned and successfully opened the display.
winInitMultiWindowWM - XOpenDisplay () returned and successfully opened the display.
winClipboardProc - XOpenDisplay () returned and successfully opened the display.
AUDIT: Mon Jul 04 09:40:48 2016: 2508 C:\Program Files (x86)\Xming\Xming.exe: client 4 rejected from IP 192.168.1.151
[Note: the 192.168.1.151 is the IP of the BBB (ifconfig -a)]
Any ideas what could be the problem? Anyone else try this on the beaglebone black (Debian 8.4)?
