Greetings,
I am trying to install X11VNC and log into it via my laptop and I am having some tough luck
Here is what I have done…
I have changed my IP address to a 192.168.1.XX
My router for some reason still thinks it is the old IP address even when I refresh it.
I have turned on VNC on the firewall on my 2wire router
Next I installed VNC:
- Debian: sudo apt-get install x11vnc
- Enter the below command
-Debian:
x11vnc -bg -o %HOME/.x11vnc.log.%VNCDISPLAY -auth /var/run/lightdm/root/:0 -forever
(I’m not sure if I turned it on)
I can ping the beaglebone from my computer
C:\Users\William>ping 192.168.1.XX
Pinging 192.168.1.XX with 32 bytes of data:
Reply from 192.168.1.XX: bytes=32 time=3ms TTL=64
Reply from 192.168.1.XX: bytes=32 time=5ms TTL=64
Ping statistics for 192.168.1.XX:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 5ms, Average = 3ms
So I can See it.
I start tightVNC on my laptop
192.168.1.XX:5901
I get connection has been gracefully closed. Or Connection was actively Refused…
X11VNC has a few configurations when opened on the desktop I am unfamiliar with. No passwords in use as of yet (I was warned when I started)
Does anyone see anything out of whack?
Thanks!
Bill
