I’m running a 2.6.32 kernel and want to switch to the new u-boot. When doing so, I get the output below.
The 2.32 kernel was created with bitbake linux-omap-psp-2.6.32. u-boot was created with bitbake u-boot.
Do I need to change the u-boot configuration to work with this kernel? (My configuration is below).
–Mark
Booting Fails
Texas Instruments X-Loader 1.5.0 (Mar 27 2011 - 17:37:56)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.09-dirty (Jan 02 2012 - 11:48:39)
OMAP3630/3730-GP ES1.2, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
Recognized Tincantools Trainer board (rev 0 0)
No EEPROM on expansion board
Die ID #397600029ff80000015f26ad0f01a010
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 2 1 0
The user button is currently NOT pressed.
SD/MMC found on device 0
reading uEnv.txt
191 bytes read
Running uenvcmd …
Loading file “/boot/uImage” from mmc device 0:2 (xxa2)
3203088 bytes read
Booting from mmc …
Booting kernel from Legacy Image at 80200000 …
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3203024 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
[ 0.000000] Linux version 2.6.32 (koen@dominion) (gcc version 4.3.3 (GCC) ) #3 PREEMPT Tue May 10 10:06:15 CEST 2011
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
[ 0.000000] Reserving 25165824 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 122624
[ 0.000000] Kernel command line: console=tty0 console=ttyS2,115200n8 consoleblank=0 mpurate=auto buddy=trainer buddy2=none camera=none vram=24M omapfb.mode=dvi:hd720 mem=99M@0x80000000 mem=384M@0x88000000 omapfb.vram=0:12M,1:8M,2:4M omapdss.def_disp=dvi root=/dev/mmcblk0p2 ro rootfstype=ext3 rootwait
[ 0.000000] Beagle expansionboard: trainer
[ 0.000000] Beagle cameraboard: none
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 99MB 384MB = 483MB total
[ 0.000000] Memory: 458496KB available (5900K code, 673K data, 204K init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000000] Calibrating delay loop… 507.32 BogoMIPS (lpj=1982464)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option ‘mode’
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP3 Beagle Rev: xM C
[ 0.000000] Beagle expansionboard: exporting GPIOs 130-141,162 to userspace
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 0.000000] omap_init_mbox: platform not supported
[ 10.957855] OMAP DMA hardware revision 5.0
[ 10.966705] bio: create slab at 0
[ 10.968688] SCSI subsystem initialized
[ 10.970886] usbcore: registered new interface driver usbfs
[ 10.971191] usbcore: registered new interface driver hub
[ 10.971557] usbcore: registered new device driver usb
[ 10.972290] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[ 10.976226] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 10.976318] twl4030: power (irq 373) chaining IRQs 376…383
[ 10.976867] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 10.979431] regulator: VUSB1V5: 1500 mV normal standby
[ 10.979827] regulator: VUSB1V8: 1800 mV normal standby
[ 10.980346] regulator: VUSB3V1: 3100 mV normal standby
[ 10.982238] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 10.982971] regulator: VMMC1: 1850 <–> 3150 mV normal standby
[ 10.983428] regulator: VDAC: 1800 mV normal standby
[ 10.983886] regulator: VPLL2: 1800 mV normal standby
[ 10.984313] regulator: VSIM: 1800 <–> 3000 mV normal standby
[ 10.984863] regulator: VAUX3: 1800 mV normal standby
[ 10.985412] regulator: VAUX4: 1800 mV normal standby
[ 10.985717] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[ 10.993286] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 10.995117] Switching to clocksource 32k_counter
[ 11.007293] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 11.011383] musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 11.011444] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 11.011657] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 11.011871] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.011932] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.011993] usb usb1: Product: MUSB HDRC host driver
[ 11.012023] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 11.012054] usb usb1: SerialNumber: musb_hdrc
[ 11.012939] hub 1-0:1.0: USB hub found
[ 11.013031] hub 1-0:1.0: 1 port detected
[ 11.014526] NET: Registered protocol family 2
[ 11.014862] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 11.015625] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 11.016082] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 11.016326] TCP: Hash tables configured (established 16384 bind 16384)
[ 11.016357] TCP reno registered
[ 11.016387] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 11.016448] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 11.016845] NET: Registered protocol family 1
[ 11.017547] RPC: Registered udp transport module.
[ 11.017669] RPC: Registered tcp transport module.
[ 11.017700] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 11.019073] omap-iommu omap-iommu.0: isp registered
[ 11.021575] VFS: Disk quotas dquot_6.5.2
[ 11.021789] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 11.023193] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 11.024414] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 11.025543] msgmni has been set to 896
[ 11.031707] alg: No test for stdrng (krng)
[ 11.032165] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 11.032226] io scheduler noop registered
[ 11.032257] io scheduler deadline registered
[ 11.032501] io scheduler cfq registered (default)
[ 11.089233] OMAP DSS rev 2.0
[ 11.089355] OMAP DISPC rev 3.0
[ 11.089447] OMAP VENC rev 2
[ 11.089874] OMAP DSI rev 1.0
[ 11.434112] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 11.453186] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 11.471221] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 11.489349] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 12.070617] console [ttyS2] enabled
[ 12.084808] brd: module loaded
[ 12.093261] loop: module loaded
[ 12.098541] omap2-nand driver initializing
[ 12.102996] No NAND device found!!!
[ 12.106811] No NAND device found!!!
[ 12.111907] usbcore: registered new interface driver catc
[ 12.117492] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 12.123687] usbcore: registered new interface driver kaweth
[ 12.129425] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 12.137176] usbcore: registered new interface driver pegasus
[ 12.142944] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 12.150085] usbcore: registered new interface driver rtl8150
[ 12.156036] usbcore: registered new interface driver asix
[ 12.161712] usbcore: registered new interface driver cdc_ether
[ 12.167816] usbcore: registered new interface driver dm9601
[ 12.173614] usbcore: registered new interface driver smsc95xx
[ 12.179656] usbcore: registered new interface driver gl620a
[ 12.185546] usbcore: registered new interface driver net1080
[ 12.191497] usbcore: registered new interface driver plusb
[ 12.197174] usbcore: registered new interface driver rndis_host
[ 12.203399] usbcore: registered new interface driver cdc_subset
[ 12.209594] usbcore: registered new interface driver zaurus
[ 12.215454] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 12.224121] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 12.231140] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 12.237518] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[ 12.245208] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 12.261016] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 12.266998] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 12.273956] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.281311] usb usb2: Product: OMAP-EHCI Host Controller
[ 12.286712] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 12.292236] usb usb2: SerialNumber: ehci-omap.0
[ 12.297790] hub 2-0:1.0: USB hub found
[ 12.301757] hub 2-0:1.0: 3 ports detected
[ 12.331481] Initializing USB Mass Storage driver…
[ 12.336700] usbcore: registered new interface driver usb-storage
[ 12.342864] USB Mass Storage support registered.
[ 12.348266] mice: PS/2 mouse device common for all mice
[ 12.354156] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 12.362762] input: twl4030_pwrbutton as /devices/platform/i2c_omap.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 12.373870] i2c /dev entries driver
[ 12.378692] Linux video capture interface: v2.00
[ 12.383789] omap-iommu omap-iommu.0: isp: version 1.1
[ 12.391540] vpfe_init
[ 12.394897] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 12.402374] cpuidle: using governor ladder
[ 12.406555] cpuidle: using governor menu
[ 12.519195] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card detect
[ 12.526580] Registered led device: beagleboard::usr0
[ 12.531829] Registered led device: beagleboard::usr1
[ 12.538604] Registered led device: beagleboard::pmu_stat
[ 12.546813] usbcore: registered new interface driver usbhid
[ 12.552581] usbhid: USB HID core driver
[ 12.556732] Advanced Linux Sound Architecture Driver Version 1.0.21.
[ 12.564025] usbcore: registered new interface driver snd-usb-audio
[ 12.629211] usb 2-2: new high speed USB device using ehci-omap and address 2
[ 12.657653] No device for DAI omap-mcbsp-dai-0
[ 12.662261] No device for DAI omap-mcbsp-dai-1
[ 12.666809] No device for DAI omap-mcbsp-dai-2
[ 12.671356] No device for DAI omap-mcbsp-dai-3
[ 12.675903] No device for DAI omap-mcbsp-dai-4
[ 12.680419] OMAP3 Beagle SoC init
[ 12.684814] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 12.697845] ALSA device list:
[ 12.701019] #0: omap3beagle (twl4030)
[ 12.705078] oprofile: using arm/armv7
[ 12.709106] TCP cubic registered
[ 12.712402] NET: Registered protocol family 17
[ 12.717041] NET: Registered protocol family 15
[ 12.721679] lib80211: common routines for IEEE802.11 drivers
[ 12.727539] ThumbEE CPU extension supported.
[ 12.731933] Power Management for TI OMAP3.
[ 12.737884] SmartReflex driver initialized
[ 12.742279] omap3beaglelmb: Driver registration complete
[ 12.758514] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 12.767211] registered taskstats version 1
[ 12.832489] usb 2-2: New USB device found, idVendor=0424, idProduct=9514
[ 12.839355] usb 2-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 12.847869] hub 2-2:1.0: USB hub found
[ 12.851867] hub 2-2:1.0: 5 ports detected
[ 12.925109] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 12.933410] mmc0: new high speed SDHC card at address 1234
[ 12.939483] mmcblk0: mmc0:1234 SA04G 3.67 GiB
[ 12.944488] mmcblk0:Console: switching to colour frame buffer device 160x45
[ 12.989013] p1 p2
[ 12.992828] regulator_init_complete: incomplete constraints, leaving VAUX3 on
[ 13.000762] regulator_init_complete: incomplete constraints, leaving VDAC on
[ 13.009063] omap_vout omap_vout: probed for an unknown device
[ 13.023803] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem
[ 13.031250] EXT3-fs (mmcblk0p2): write access will be enabled during recovery
[ 13.198760] usb 2-2.1: new high speed USB device using ehci-omap and address 3
[ 13.324554] usb 2-2.1: New USB device found, idVendor=0424, idProduct=ec00
[ 13.331878] usb 2-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 13.342773] smsc95xx v1.0.4
[ 13.410125] usb0: register ‘smsc95xx’ at usb-ehci-omap.0-2.1, smsc95xx USB 2.0 Ethernet, 0a:42:14:0a:a5:5c
[ 13.511383] usb 2-2.2: new high speed USB device using ehci-omap and address 4
[ 13.639953] usb 2-2.2: New USB device found, idVendor=1415, idProduct=2000
[ 13.652465] usb 2-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 13.665374] usb 2-2.2: Product: USB Camera-B4.04.27.1
[ 13.675964] usb 2-2.2: Manufacturer: OmniVision Technologies, Inc.
[ 13.792694] usb 2-2.3: new high speed USB device using ehci-omap and address 5
[ 13.939575] usb 2-2.3: New USB device found, idVendor=0b95, idProduct=7720
[ 13.952545] usb 2-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 13.965545] usb 2-2.3: Product: AX88772
[ 13.975128] usb 2-2.3: Manufacturer: ASIX Elec. Corp.
[ 13.985870] usb 2-2.3: SerialNumber: 000001
[ 14.836486] eth0: register ‘asix’ at usb-ehci-omap.0-2.3, ASIX AX88772 USB 2.0 Ethernet, 00:50:b6:06:c4:57
[ 14.933105] usb 2-2.4: new low speed USB device using ehci-omap and address 6
[ 15.063446] usb 2-2.4: New USB device found, idVendor=046d, idProduct=c016
[ 15.076538] usb 2-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 15.090148] usb 2-2.4: Product: Optical USB Mouse
[ 15.100860] usb 2-2.4: Manufacturer: Logitech
[ 15.116546] input: Logitech Optical USB Mouse as /devices/platform/ehci-omap.0/usb2/2-2/2-2.4/2-2.4:1.0/input/input2
[ 15.134399] generic-usb 0003:046D:C016.0001: input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-ehci-omap.0-2.4/input0
[ 15.237945] usb 2-2.5: new low speed USB device using ehci-omap and address 7
[ 15.376342] usb 2-2.5: New USB device found, idVendor=04f3, idProduct=0103
[ 15.389678] usb 2-2.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 15.410430] input: HID 04f3:0103 as /devices/platform/ehci-omap.0/usb2/2-2/2-2.5/2-2.5:1.0/input/input3
[ 15.427276] generic-usb 0003:04F3:0103.0002: input: USB HID v1.10 Keyboard [HID 04f3:0103] on usb-ehci-omap.0-2.5/input0
[ 15.452301] input: HID 04f3:0103 as /devices/platform/ehci-omap.0/usb2/2-2/2-2.5/2-2.5:1.1/input/input4
[ 15.469360] generic-usb 0003:04F3:0103.0003: input: USB HID v1.10 Device [HID 04f3:0103] on usb-ehci-omap.0-2.5/input1
[ 21.735321] EXT3-fs (mmcblk0p2): recovery complete
[ 21.747802] kjournald starting. Commit interval 5 seconds
[ 22.486877] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
[ 22.501617] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
[ 22.520935] devtmpfs: mounted
[ 22.531005] Freeing init memory: 204K
INIT: version 2.86 booting
Please wait: booting…
Starting udev
/etc/rcS.d/S03udev: line 52: can’t create /tmp/uname: Read-only file system
touch: cannot touch /tmp/uname': Read-only file system Remounting root file system... [ 23.391815] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended [ 23.412109] EXT3-fs (mmcblk0p2): using internal journal Caching udev devnodes Populating dev cachemv: cannot stat /tmp/uname’: No such file or directory
[ 25.897247] Bluetooth: Core ver 2.15
[ 25.908264] NET: Registered protocol family 31
[ 25.919982] Bluetooth: HCI device and connection manager initialized
[ 25.933380] Bluetooth: HCI socket layer initialized
[ 25.975799] Bluetooth: L2CAP ver 2.14
[ 25.986450] Bluetooth: L2CAP socket layer initialized
[ 26.027465] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 26.271148] NET: Registered protocol family 10
[ 26.392578] NET: Registered protocol family 23
[ 26.436798] IrCOMM protocol (Dag Brattli)
[ 26.555267] Bluetooth: RFCOMM TTY layer initialized
[ 26.567016] Bluetooth: RFCOMM socket layer initialized
[ 26.578918] Bluetooth: RFCOMM ver 1.11
ALSA: Restoring mixer settings…
Cleaning: /etc/network/run/ifstate.
/usr/sbin/alsactl: load_state:1625: No soundcards found…
Configuring network interfaces… [ 28.945495] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 29.156188] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
eth0 no wireless extensions.
Internet Systems Consortium DHCP Client 4.1.1-P1
Copyright 2004-2010 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/eth0/00:50:b6:06:c4:57
Sending on LPF/eth0/00:50:b6:06:c4:57
Sending on Socket/fallback
DHCPREQUEST on eth0 to 255.255.255.255 port 67
DHCPACK from 137.112.41.1
bound to 137.112.41.87 – renewal in 1206015 seconds.
done.
Starting portmap daemon: portmapportmap: fork: No such device.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
hwclock: can’t open ‘/dev/misc/rtc’: No such file or directory
Fri Jan 27 21:15:00 GMT 2012
[ 87.628143] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Booting with this older u-boot succeeds
Beagle xM
Reading boot sector
U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 01 2011 - 17:41:42)
OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
u-boot configuration u-boot/include/configs/omap3_beagle.h
- (C) Copyright 2006-2008
- Texas Instruments.
- Richard Woodruff r-woodruff2@ti.com
- Syed Mohammed Khasim x0khasim@ti.com
