I would like to know if someone had already this problem ? Or does someone know how to solve it ?
[327741.539] X Protocol Version 11, Revision 0
[327741.540] Build Operating System: Linux 3.16.0-0.bpo.4-armmp-lpae armv7l Debian
[327741.540] Current Operating System: Linux alex 4.4.13-bone11 #88 Tue Nov 8 17:53:55 CET 2016 armv7l
[327741.540] Kernel command line: console=ttyUSB0,115200n8 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait coherent_pool=1M quiet splash video=HDMI-A-1:1024x600MR@60e fbcon=rotate:1
[327741.540] Build Date: 11 February 2015 01:18:06AM
[327741.540] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[327741.540] Current version of pixman: 0.32.6
[327741.540] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[327741.540] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[327741.543] (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Dec 6 09:41:59 2016
[327741.545] (==) Using config file: “/etc/X11/xorg.conf”
[327741.546] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[327741.549] (==) ServerLayout “Builtin Default Layout”
[327741.550] () |–>Screen “Builtin Default fbdev Screen 0” (0)
[327741.550] () | |–>Monitor “Builtin Default Monitor”
[327741.551] () | |–>Device “Builtin Default fbdev Device 0”
[327741.551] () Option “BlankTime” “0”
[327741.551] () Option “StandbyTime” “0”
[327741.551] () Option “SuspendTime” “0”
[327741.551] () Option “OffTime” “0”
[327741.551] (==) Automatically adding devices
[327741.551] (==) Automatically enabling devices
[327741.551] (==) Automatically adding GPU devices
[327741.551] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[327741.551] Entry deleted from font path.
[327741.552] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[327741.552] (==) ModulePath set to “/usr/lib/xorg/modules”
[327741.552] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[327741.552] (II) Loader magic: 0x7f7a0f18
[327741.552] (II) Module ABI versions:
[327741.552] X.Org ANSI C Emulation: 0.4
[327741.552] X.Org Video Driver: 18.0
[327741.552] X.Org XInput driver : 21.0
[327741.552] X.Org Server Extension : 8.0
[327741.553] (II) xfree86: Adding drm device (/dev/dri/card0)
[327741.554] (II) no primary bus or device found
[327741.554] falling back to /sys/devices/platform/ocp/4830e000.lcdc/drm/card0
[327741.554] (II) LoadModule: “glx”
[327741.555] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[327741.639] (II) Module glx: vendor=“X.Org Foundation”
[327741.639] compiled for 1.16.4, module version = 1.0.0
[327741.639] ABI class: X.Org Server Extension, version 8.0
[327741.639] (==) AIGLX enabled
[327741.639] (II) LoadModule: “fbdev”
[327741.642] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[327741.644] (II) Module fbdev: vendor=“X.Org Foundation”
[327741.644] compiled for 1.15.99.904, module version = 0.4.4
[327741.645] Module class: X.Org Video Driver
[327741.645] ABI class: X.Org Video Driver, version 18.0
[327741.648] (II) FBDEV: driver for framebuffer: fbdev
[327741.648] (–) using VT number 2
[327741.648] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[327741.649] (WW) xf86OpenConsole: setsid failed: Operation not permitted
[327741.656] (WW) Falling back to old probe method for fbdev
[327741.657] (II) Loading sub module “fbdevhw”
[327741.657] (II) LoadModule: “fbdevhw”
[327741.657] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[327741.658] (II) Module fbdevhw: vendor=“X.Org Foundation”
[327741.658] compiled for 1.16.4, module version = 0.0.2
[327741.658] ABI class: X.Org Video Driver, version 18.0
[327741.659] (II) FBDEV(0): using default device
[327741.659] (II) FBDEV(0): Creating default Display subsection in Screen section
“Builtin Default fbdev Screen 0” for depth/fbbpp 16/16
[327741.659] () FBDEV(0): Depth 16, (–) framebuffer bpp 16
[327741.659] (==) FBDEV(0): RGB weight 565
[327741.659] (==) FBDEV(0): Default visual is TrueColor
[327741.659] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[327741.659] (II) FBDEV(0): hardware: (video memory: 3600kB)
[327741.659] (II) FBDEV(0): checking modes against framebuffer device…
[327741.669] (II) FBDEV(0): checking modes against monitor…
[327741.669] (–) FBDEV(0): Virtual size is 1024x600 (pitch 1024)
[327741.669] () FBDEV(0): Built-in mode “current”
[327741.669] (==) FBDEV(0): DPI set to (96, 96)
[327741.669] (II) Loading sub module “fb”
[327741.669] (II) LoadModule: “fb”
[327741.672] (II) Loading /usr/lib/xorg/modules/libfb.so
[327741.673] (II) Module fb: vendor=“X.Org Foundation”
[327741.673] compiled for 1.16.4, module version = 1.0.0
[327741.673] ABI class: X.Org ANSI C Emulation, version 0.4
[327741.673] () FBDEV(0): using shadow framebuffer
[327741.673] (II) Loading sub module “shadow”
[327741.673] (II) LoadModule: “shadow”
[327741.674] (II) Loading /usr/lib/xorg/modules/libshadow.so
[327741.675] (II) Module shadow: vendor=“X.Org Foundation”
[327741.675] compiled for 1.16.4, module version = 1.1.0
[327741.675] ABI class: X.Org ANSI C Emulation, version 0.4
[327741.771] (==) FBDEV(0): Backing store enabled
[327741.772] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[327741.773] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[327741.774] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[327741.775] () FBDEV(0): DPMS enabled
[327741.775] (==) RandR enabled
[327741.880] (II) SELinux: Disabled on system
[327741.884] (II) AIGLX: Screen 0 is not DRI2 capable
[327741.884] (EE) AIGLX: reverting to software rendering
[327742.225] (II) AIGLX: Loaded and initialized swrast
[327742.226] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[327742.799] (II) config/udev: Adding input device ITE IT7280 Mutual (/dev/input/event1)
[327742.803] () ITE IT7280 Mutual: Applying InputClass “evdev touchscreen catchall”
[327742.803] (II) LoadModule: “evdev”
[327742.806] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[327742.812] (II) Module evdev: vendor=“X.Org Foundation”
[327742.812] compiled for 1.16.0, module version = 2.9.0
[327742.812] Module class: X.Org XInput Driver
[327742.812] ABI class: X.Org XInput driver, version 21.0
[327742.813] (II) Using input driver ‘evdev’ for ‘ITE IT7280 Mutual’
[327742.813] () ITE IT7280 Mutual: always reports core events
[327742.813] () evdev: ITE IT7280 Mutual: Device: “/dev/input/event1”
[327742.870] (–) evdev: ITE IT7280 Mutual: Vendor 0x48d Product 0x7280
[327742.870] (–) evdev: ITE IT7280 Mutual: Found absolute axes
[327742.871] (–) evdev: ITE IT7280 Mutual: Found absolute multitouch axes
[327742.871] (II) evdev: ITE IT7280 Mutual: No buttons found, faking one.
[327742.871] (–) evdev: ITE IT7280 Mutual: Found x and y absolute axes
[327742.871] (–) evdev: ITE IT7280 Mutual: Found absolute touchscreen
[327742.871] (II) evdev: ITE IT7280 Mutual: Configuring as touchscreen
[327742.871] () evdev: ITE IT7280 Mutual: YAxisMapping: buttons 4 and 5
[327742.871] () evdev: ITE IT7280 Mutual: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[327742.871] () Option “config_info” “udev:/sys/devices/platform/ocp/47400000.usb/47401c00.usb/musb-hdrc.1.auto/usb1/1-1/1-1:1.0/0003:048D:7280.0001/input/input1/event1”
[327742.871] (II) XINPUT: Adding extended input device “ITE IT7280 Mutual” (type: TOUCHSCREEN, id 6)
[327742.872] (II) evdev: ITE IT7280 Mutual: initialized for absolute axes.
[327742.873] () ITE IT7280 Mutual: (accel) keeping acceleration scheme 1
[327742.873] () ITE IT7280 Mutual: (accel) acceleration profile 0
[327742.873] () ITE IT7280 Mutual: (accel) acceleration factor: 2.000
[327742.873] () ITE IT7280 Mutual: (accel) acceleration threshold: 4
[327742.875] (II) config/udev: Adding input device ITE IT7280 Mutual (/dev/input/mouse0)
[327742.875] (II) No input driver specified, ignoring this device.
[327742.875] (II) This device may have been added with another device file.
[327742.877] (II) config/udev: Adding input device ITE IT7280 Mutual Pen (/dev/input/event2)
[327742.878] (II) No input driver specified, ignoring this device.
[327742.878] (II) This device may have been added with another device file.
[327742.879] (II) config/udev: Adding input device ITE IT7280 Mutual Pen (/dev/input/mouse1)
[327742.879] (II) No input driver specified, ignoring this device.
[327742.879] (II) This device may have been added with another device file.
[327742.893] (II) config/udev: Adding input device tps65217_pwr_but (/dev/input/event0)
[327742.893] (II) No input driver specified, ignoring this device.
[327742.893] (II) This device may have been added with another device file.
