For potential of the OMAP3 I guess you mean the SGX hardware. Well, there is a small catch to get that acceleration on Xserver. Accelerated Xserver approaches used in current desktops are based on standard OpenGL not OpenGL ES (OGLES from now on), all of them requiring the GLX protocol for integration between the X server and the GL library. But GLX doesn't support OGLES as far I known.
There is X server project called Xegl (http://www.freedesktop.org/wiki/Xegl) that runs without using GLX, but has not received too much effort since there is lack of EGL libraries for desktop machines. OMAP does have an EGL, so problem solved here if you invest some time doing the glue logic. Then you need a way to render with the Xrender extension: meet glitz.
glitz is a rendering library over OpenGL that can be the Xegl backend (or also used as cairo rendering backend for accelleration, but in OMAP case would do more sense to use the OpenVG backend for cairo than glitz). The good news is that glitz designer keep OGLES in mind when writing glitz[0], but some people tried to test it on OGLES 1.1 and didn't work well due the lack of pbuffers, fbo and buffer mapping functions on the 1.1 standard[1]. So, maybe attempting to port glitz to the OGLES 2.0 standard could be more successful.
Then you will have to do some funny hacking with the modular X server libraries and you will finally get an OGLES accelerated Xserver, and then you will have to get a composite manager running on top of it.
There are other options for taking advantage of the acceleration like using clutter (which already works with OMAP3), but you will be lacking the ability to run standard widget sets like Gtk. Still clutter provides a very good ground (IMHO) for creating UIs since it provides rich scenography functions to create animations and widgets with good effects like 2D physics (something you won't find with the Xserver approach).
Then you also have the partial acceleration mode: use standard X server with GTK, and a gtk-clutter widget for rendering accelerated scenes inside a special window.
Sorry I just confuse things a bit more, the landscape here is not that simple yet. If I miss something or someone has some other ideas (or corrections, it take me several weeks to get the picture and I may be mistaken in something) they are welcome.
There is X server project called Xegl (Xegl
meet glitz.
Xserver approach).
Could you elaborate clutter approach more? If I only want to run one
special application (no need for windows manager here), and I don't
have the burden of running traditional X-window based application.
Will clutter be a good choice. How far away is clutter from metal?
Clutter -> openGL dirver -> PowerVR 530 -> Display ? No heavy
x-protocol in the chain?
I'm mostly interested in the overlays (yuv422) and DSS lib to switch
video planes to TV, lcd, dvi, etc.
I think you are forgetting about Gallium3D here A gallium sgx
driver + failover pipe would give us a complete openGL implementation
where the GLES portions are accelerated.
Having said that, I have no idea what imgtec is working on, but I
suspect they are writing kernel 2.4 drivers for tinyX or something
equally useless in this day and age. Intel binned the imtec drivers
and hired TG to do drivers for their SGX chip....
Yes, clutter is a good choice here.
The layout will be:
Clutter -> OpenGL ES -> Video hardware.
Clutter provides text rendering using fontconfig and pango, so you have all the goodies for text rendering as normal Linux applications (i18n support, bi-directional support, etc), and you can stack up some more libraries on top of it like cairo and gstreamer to render directly from them to actors in 3D space.
At this point it clutter only provides input using tslib for touchscreens when using the EGL backend, but I'm working in adding a generic Linux input event so you can use mouses or keyboards or keypads.
What clutter doesn't provide is an elaborated toolkit for rich-text boxes or tree views. However you can use the webkit actor for complex text rendering.
Sorry a little off topic here. If I want to get very accurate 256
level of black and white, and
very accurate 256 level of color. Is that possible with omap3530? I
know for sure 16bit 5-6-5 format
won't do that. Is that a hardware limitation of software driver issue?
Are there something like 16bit palette
color mode?
I didn't know about Gallium3D, thanks for the info. It seems from google it hat TG is working on an OGLES state tracker (which will be useful to bring the standard desktop acceleration), so this is another option. The issue here is that either you wait for TG to release the state tracker or you write it yourself. It seems to me that you need to be a seasoned OpenGL guru to do it.
just start a new thread instead of replying to an existing one and chose a meaningful subject
color mode?
the omap3530 supports up to 24bit RGBA, should be enough, no?
If you are into text, it is better to use the VG support on the SGX.
An interesting option would be if we can have multiple passes :: VG
accelerated text using OpenVG on SGX->buffer, buffer->graphics
accelerated with OpenGLES on SGX->buffer -> display. Need to do more
profiling.
Anyone have a working Cairo build with OpenGLES enabled ? I am
beginning to work on one, but wanted to check before in this thread.
Writing an accelerated X server for the SGX is pretty easy. The SGX
has a 2D core for blitting (with scaling & alpha blending). There's
also a pretty nice API to the blitting hardware provided by the
libpvr2d.so library. The problem is that you need to sign an NDA with
ImgTec to get the headers for the pvr2d library. I guess you could
dump the symbols from the library and reverse engineer a header. The
pvr2d library is what the WSEGL libraries use to blit the GL/VG back
buffer into the frame buffer. It also allows chaining buffers for
full-screen applications (so a eglSwapBuffers really does swap the
buffers as opposed to doing a blit). This is what we use for the QWS
(Qt Window System) EGL backend (Which should appear in the Qt
snapshots sometime next week if anyone's interested).
In addition to the NDA issue, another problem is that the pvr2d API
takes physical addresses of the memory you want to blit. Normally you
ask pvr2d to allocate the memory for you (in which case you don't need
the physical address). But to get a composition manager to work with
GL, you need to allocate memory in one process and use it in another
(I.e. allocate in x server and use in client). I have no idea how
you're supposed to allocate a hunk of memory, pin it and then get the
physical address of it from user space. The idea I've been kicking
around is to "reserve" say 8MB of ram for graphics. I think this can
be done by passing a parameter to the kernel which tells it the
physical address of memory it can use. You just pass in the physical
address of the RAM, minus the top 8MB. Once you've made sure the
kernel's never going to touch the top 8mb of physical RAM, you can use
it for the SGX and even mmap it through /dev/ram. Anyone know if this
is likely to work?
BTW: Gallium3D's SGX drivers are for the SGX in Intel Atoms. As far as
I know, TI have no plans to licence the Gallium3D driver from TG -
Which means we're stuck with the ImgTec binary drivers with almost no
X integration.
If anyone's interested in running QWS on the beagle, let me know -
however I guess all the BeagleBoard people are focussed on X11 & GTK+?
Even so, taking a look at the QWS integration might shed some light on
things. BTW: I also wrote a backend for EGL on X11 for Qt if anyone
wants to give it a try. If you're feeling _very_ adventurous you can
even try out my OpenGL ES 2.0 paint engine (Not for the faint of heart
- it's a bit buggy at the moment but should be stable for Qt 4.5.0,
whenever that gets released.)
Well, I don't have the skills for driver work, but I'll be using Qt or Qt
Embedded with my Beagle. My goal is to port my Qt based "MythTV like" media
setup to the Beagle and get it all running smoothly. But as audio and video
currently are in a somewhat mixed state I guess 4.5.0 is out before it all
stabilizes.
But I'll try some snapshot on the Beagle and see what I can get to work, so
you're not the only Qt person on this list/forum.
One of my objective is to use the frame buffer with some hw acceleration
and to possibly mix 2D surface with 3D.
My first thought was to not use X11 systema ans to use instead DirectFB
library.
Then to try creating plugin for hardware acceleration (fill rectangle, blit
copy, blit color keying, blit blend)
Your point is very interesting. I am interested in trying QWS and your
opengl es paint engine.
Maybe it is the solution i am looking for.
The paint engine is part of Qt and will be included in the up-coming
4.5.0 release. We also have nightly snapshots from outr repo which
should now contain the engine:
