Hello, Many years ago, we have created our own flaser image for the Beaglebone Black. When the engineer is going to program it in the factory we never have a problem, until a few weeks ago. Now I have four Beaglebones on my desk witch I cannot program. Of course, I push the user button when power up and I tried different CD cards to be sure the SD card is not broken. After a few seconds, the Beaglebone stops responding (terminal freezes) and user LED D4 burns, the rest is off (except power LED D1).
Here is the debug log of a (non working) Beaglebone.
U-Boot 2013.04-dirty (Oct 09 2017 - 06:41:40)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
** Unable to read file uEnv.txt **
4391432 bytes read in 602 ms (7 MiB/s)
24884 bytes read in 27 ms (899.4 KiB/s)
Booting from mmc âŠ
Booting kernel from Legacy Image at 80007fc0 âŠ
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4391368 Bytes = 4.2 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ⊠OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image ⊠OK
OK
Using Device Tree in place at 80f80000, end 80f89133
Starting kernel âŠ
Uncompressing Linux⊠done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13 (yocto@6d093f821622) (gcc version 4.7.3 20130205 (prerelease) (Linaro GCC 4.7-2013.02-01) ) #1 SMP Mon Oct 9 06:49:34 UTC 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0b32000 s9408 r8192 d15168 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try âcgroup_disable=memoryâ option if you donât want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 510304k/510304k available, 13984k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc060ec18 (6172 kB)
[ 0.000000] .init : 0xc060f000 - 0xc06514c0 ( 266 kB)
[ 0.000000] .data : 0xc0652000 - 0xc06c79a0 ( 471 kB)
[ 0.000000] .bss : 0xc06c79a0 - 0xc072173c ( 360 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000356] Calibrating delay loop⊠545.07 BogoMIPS (lpj=531968)
[ 0.015421] pid_max: default: 32768 minimum: 301
[ 0.015658] Security Framework initialized
[ 0.015751] Mount-cache hash table entries: 512
[ 0.026234] Initializing cgroup subsys cpuacct
[ 0.026267] Initializing cgroup subsys memory
[ 0.026332] Initializing cgroup subsys blkio
[ 0.026472] CPU: Testing write buffer coherency: ok
[ 0.027006] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.027083] Setting up static identity map for 0x8038a5a0 - 0x8038a5ec
[ 0.028452] Brought up 1 CPUs
[ 0.028477] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.029770] devtmpfs: initialized
[ 0.094410] pinctrl core: initialized pinctrl subsystem
[ 0.094620] rstctl core: initialized rstctl subsystem
[ 0.095119] regulator-dummy: no parameters
[ 0.095694] NET: Registered protocol family 16
[ 0.096507] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.106572] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.107385] platform 49000000.edma: alias fck already exists
[ 0.107418] platform 49000000.edma: alias fck already exists
[ 0.107445] platform 49000000.edma: alias fck already exists
[ 0.108768] OMAP GPIO hardware version 0.1
[ 0.113458] gpio-rctrl rstctl.4: loaded OK
[ 0.119027] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.121161] cpsw.0: No hwaddr in dt. Using 18:2c:65:2a:a5:c5 from efuse
[ 0.121194] cpsw.1: No hwaddr in dt. Using 18:2c:65:2a:a5:c7 from efuse
[ 0.136563] bio: create slab at 0
[ 0.148620] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.149063] vmmcsd_fixed: 3300 mV
[ 0.151837] SCSI subsystem initialized
[ 0.152312] usbcore: registered new interface driver usbfs
[ 0.152424] usbcore: registered new interface driver hub
[ 0.152693] usbcore: registered new device driver usb
[ 0.154751] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.156283] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.158495] DCDC1: at 1500 mV
[ 0.159645] vdd_mpu: 925 â 1325 mV at 1100 mV
[ 0.160828] vdd_core: 925 â 1150 mV at 1100 mV
[ 0.161972] LDO1: at 1800 mV
[ 0.163065] LDO2: at 3300 mV
[ 0.164996] LDO3: 1800 mV
[ 0.166140] LDO4: at 3300 mV
[ 0.167145] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.167906] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.168637] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.170962] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.171182] media: Linux media interface: v0.10
[ 0.171285] Linux video capture interface: v2.00
[ 0.171427] pps_core: LinuxPPS API ver. 1 registered
[ 0.171445] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.172249] Advanced Linux Sound Architecture Driver Initialized.
[ 0.173487] Switching to clocksource gp_timer
[ 0.191588] NET: Registered protocol family 2
[ 0.192580] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.192725] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.192887] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.192978] TCP: reno registered
[ 0.193006] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.193052] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.193537] NET: Registered protocol family 1
[ 0.194081] RPC: Registered named UNIX socket transport module.
[ 0.194101] RPC: Registered udp transport module.
[ 0.194115] RPC: Registered tcp transport module.
[ 0.194129] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.194851] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.195393] CPU PMU: attempt to register multiple PMU devices!
[ 0.195434] arm-pmu: probe of arm-pmu failed with error -28
[ 0.195821] omap2_mbox_probe: platform not supported
[ 0.199669] VFS: Disk quotas dquot_6.5.2
[ 0.199899] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.201282] NFS: Registering the id_resolver key type
[ 0.201374] Key type id_resolver registered
[ 0.201391] Key type id_legacy registered
[ 0.201456] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.201897] msgmni has been set to 996
[ 0.204722] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.204749] io scheduler noop registered
[ 0.204765] io scheduler deadline registered
[ 0.204878] io scheduler cfq registered (default)
[ 0.206530] tps65217-bl tps65217-bl: no platform data provided
[ 0.206571] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.207555] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.210099] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.210381] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 0.924486] console [ttyO0] enabled
[ 0.929375] [drm] Initialized drm 1.1.0 20060810
[ 0.947930] brd: module loaded
[ 0.958114] loop: module loaded
[ 0.961567] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.968854] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.976130] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.983405] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.990676] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.004974] bone-capemgr bone_capemgr.9: Baseboard: âA335BNLT,00C0,2336SBB09277â
[ 1.012768] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-black
[ 1.050570] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 1.087672] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 1.124781] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 1.161890] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 1.168149] bone-capemgr bone_capemgr.9: slot #4: specific override
[ 1.174755] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[ 1.182794] bone-capemgr bone_capemgr.9: slot #4: âBone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2Gâ
[ 1.192956] bone-capemgr bone_capemgr.9: slot #5: specific override
[ 1.199556] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[ 1.207592] bone-capemgr bone_capemgr.9: slot #5: âBone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMIâ
[ 1.217645] bone-capemgr bone_capemgr.9: slot #6: specific override
[ 1.224242] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[ 1.232280] bone-capemgr bone_capemgr.9: slot #6: âBone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMINâ
[ 1.242993] bone-capemgr bone_capemgr.9: initialized OK.
[ 1.248639] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware âcape-bone-2g-emmc1.dtboâ for board-name âBone-LT-eMMC-2Gâ, version â00A0â
[ 1.262229] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware âcape-boneblack-hdmi-00A0.dtboâ for board-name âBone-Black-HDMIâ, version â00A0â
[ 1.278337] OneNAND driver initializing
[ 1.283961] usbcore: registered new interface driver asix
[ 1.289675] bone-capemgr bone_capemgr.9: slot #4: dtbo âcape-bone-2g-emmc1.dtboâ loaded; converting to live tree
[ 1.300382] bone-capemgr bone_capemgr.9: slot #5: dtbo âcape-boneblack-hdmi-00A0.dtboâ loaded; converting to live tree
[ 1.311754] usbcore: registered new interface driver cdc_ether
[ 1.318224] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[ 1.324391] usbcore: registered new interface driver smsc95xx
[ 1.331373] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[ 1.338323] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[ 1.345365] usbcore: registered new interface driver net1080
[ 1.353531] platform 4830e000.fb: alias fck already exists
[ 1.359476] usbcore: registered new interface driver cdc_subset
[ 1.367573] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[ 1.374534] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware âcape-boneblack-hdmin-00A0.dtboâ for board-name âBone-Black-HDMINâ, version â00A0â
[ 1.388967] usbcore: registered new interface driver zaurus
[ 1.395024] usbcore: registered new interface driver cdc_ncm
[ 1.401112] bone-capemgr bone_capemgr.9: slot #6: dtbo âcape-boneblack-hdmin-00A0.dtboâ loaded; converting to live tree
[ 1.413362] usbcore: registered new interface driver cdc_acm
[ 1.419351] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.427738] Initializing USB Mass Storage driverâŠ
[ 1.433006] usbcore: registered new interface driver usb-storage
[ 1.439333] USB Mass Storage support registered.
[ 1.444533] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 1.454131] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 1.460906] bone-capemgr bone_capemgr.9: loader: retrying slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.470173] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.476908] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.482189] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.490964] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.500784] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.505835] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.512118] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.517385] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.526371] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.531441] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.536767] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.543194] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.551667] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.558808] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.566386] usb usb1: Product: MUSB HDRC host driver
[ 1.571605] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[ 1.577276] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.583546] hub 1-0:1.0: USB hub found
[ 1.587585] hub 1-0:1.0: 1 port detected
[ 1.593040] mousedev: PS/2 mouse device common for all mice
[ 1.601446] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.609259] i2c /dev entries driver
[ 1.614666] pps_ldisc: PPS line discipline registered
[ 1.620163] Driver for 1-wire Dallas network protocol.
[ 1.627451] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.635034] cpuidle: using governor ladder
[ 1.639358] cpuidle: using governor menu
[ 1.643969] omap_hsmmc mmc.5: of_parse_phandle_with_args of âresetâ failed
[ 1.651208] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[ 1.658058] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 1.665264] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 1.672617] mmc.5 supply vmmc_aux not found, using dummy regulator
[ 1.679584] omap_hsmmc mmc.5: pins are not configured from the driver
[ 1.713007] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[ 1.719173] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 1.727124] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[ 1.733578] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 1.740699] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 1.748207] mmc.11 supply vmmc_aux not found, using dummy regulator
[ 1.754912] omap_hsmmc mmc.11: pins are not configured from the driver
[ 1.789384] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 1.801115] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 1.808420] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 1.817407] leds-gpio gpio-leds.8: pins are not configured from the driver
[ 1.826090] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.832906] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 1.840153] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.848607] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.854929] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 1.862184] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 1.874919] usbcore: registered new interface driver usbhid
[ 1.880830] usbhid: USB HID core driver
[ 1.888939] davinci_evm sound.14: nxp-hdmi-hifi â 48038000.mcasp mapping ok
[ 1.900471] TCP: cubic registered
[ 1.904011] Initializing XFRM netlink socket
[ 1.908555] NET: Registered protocol family 17
[ 1.913294] NET: Registered protocol family 15
[ 1.918093] Key type dns_resolver registered
[ 1.922845] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.930987] ThumbEE CPU extension supported.
[ 1.935534] Registering SWP/SWPB emulation handler
[ 1.941734] registered taskstats version 1
[ 1.947499] pinctrl-single 44e10800.pinmux: pin 44e109b0 already requested by mmc.11; cannot claim for hdmi.13
[ 1.958006] pinctrl-single 44e10800.pinmux: pin-108 (hdmi.13) status -22
[ 1.965099] pinctrl-single 44e10800.pinmux: could not request pin 108 on device pinctrl-single
[ 1.974129] slave hdmi.13: Failed to select default state
[ 1.979824] mmc1: BKOPS_EN bit is not set
[ 1.984145] slave: probe of hdmi.13 failed with error -22
[ 1.991460] tilcdc 4830e000.fb: No power control GPIO
[ 2.003471] mmc1: new high speed MMC card at address 0001
[ 2.010086] mmcblk0: mmc1:0001 MK2704 3.53 GiB
[ 2.015235] mmcblk0boot0: mmc1:0001 MK2704 partition 1 2.00 MiB
[ 2.021799] mmcblk0boot1: mmc1:0001 MK2704 partition 2 2.00 MiB
[ 2.029784] mmcblk0: p1
[ 2.035665] mmcblk0boot1: unknown partition table
[ 2.043463] mmcblk0boot0: unknown partition table
[ 2.106360] tilcdc 4830e000.fb: found TDA19988
[ 2.111814] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.118759] [drm] No driver support for vblank timestamp query.
[ 2.125354] tilcdc 4830e000.fb: No connectors reported connected with modes
[ 2.132673] [drm] Cannot find any crtc or sizes - going 1024x768
[ 2.156400] Console: switching to colour frame buffer device 128x48
[ 2.177763] tilcdc 4830e000.fb: fb0: frame buffer device
[ 2.183440] tilcdc 4830e000.fb: registered panic notifier
[ 2.189226] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 2.245915] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.252331] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.259891] libphy: 4a101000.mdio: probed
[ 2.264153] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.273998] Detected MACID = 18:2c:65:2a:a5:c5
[ 2.278659] cpsw 4a100000.ethernet: NAPI disabled
[ 2.285381] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.301675] ALSA device list:
[ 2.304829] #0: TI BeagleBone Black
[ 2.309490] VFS: Cannot open root device âmmcblk0p2â or unknown-block(179,2): error -6
[ 2.317816] Please append a correct âroot=â boot option; here are the available partitions:
[ 2.326575] b300 3702784 mmcblk0 driver: mmcblk
[ 2.332160] b301 3698688 mmcblk0p1 a8021243-01
[ 2.337742] b310 2048 mmcblk0boot1 (driver?)
[ 2.343318] b308 2048 mmcblk0boot0 (driver?)
[ 2.348885] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[ 2.357734] [] (unwind_backtrace+0x1/0x8c) from [] (panic+0x55/0x14c)
[ 2.366282] [] (panic+0x55/0x14c) from [] (mount_block_root+0x13b/0x178)
[ 2.375096] [] (mount_block_root+0x13b/0x178) from [] (mount_root+0x8b/0xa8)
[ 2.384266] [] (mount_root+0x8b/0xa8) from [] (prepare_namespace+0xc5/0x118)
[ 2.393433] [] (prepare_namespace+0xc5/0x118) from [] (kernel_init+0x7/0x90)
[ 2.402612] [] (kernel_init+0x7/0x90) from [] (ret_from_fork+0x11/0x34)
[ 2.411317] drm_kms_helper: panic occurred, switching back to text console
For anyone who is interested, here is a log of a working Beaglebone:
I2C: ready
DRAM: 512 MiB
0 MiB
cpsw, usb_ether
micro SD card found
reading uEnv.txt
24884 bytes read in 28 ms (867.2 KiB/s)
Booting from mmc âŠ
OK
Starting kernel âŠ
[ 0.015425] pid_max: default: 32768 minimum: 301
[ 0.015661] Security Framework initialized
[ 0.015754] Mount-cache hash table entries: 512
[ 0.026244] Initializing cgroup subsys cpuacct
[ 0.026277] Initializing cgroup subsys memory
[ 0.026342] Initializing cgroup subsys blkio
[ 0.026482] CPU: Testing write buffer coherency: ok
[ 0.027021] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.027097] Setting up static identity map for 0x8038a5a0 - 0x8038a5ec
[ 0.028473] Brought up 1 CPUs
[ 0.028499] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.029788] devtmpfs: initialized
[ 0.094373] pinctrl core: initialized pinctrl subsystem
[ 0.094586] rstctl core: initialized rstctl subsystem
[ 0.095084] regulator-dummy: no parameters
[ 0.095647] NET: Registered protocol family 16
[ 0.096461] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.106502] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.107315] platform 49000000.edma: alias fck already exists
[ 0.107348] platform 49000000.edma: alias fck already exists
[ 0.107375] platform 49000000.edma: alias fck already exists
[ 0.108696] OMAP GPIO hardware version 0.1
[ 0.113353] gpio-rctrl rstctl.4: loaded OK
[ 0.118867] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.121045] cpsw.0: No hwaddr in dt. Using 54:45:38:01:0e:24 from efuse
[ 0.121077] cpsw.1: No hwaddr in dt. Using 54:45:38:01:0e:26 from efuse
[ 0.136384] bio: create slab at 0
[ 0.148499] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.148943] vmmcsd_fixed: 3300 mV
[ 0.151718] SCSI subsystem initialized
[ 0.152191] usbcore: registered new interface driver usbfs
[ 0.152307] usbcore: registered new interface driver hub
[ 0.152585] usbcore: registered new device driver usb
[ 0.154645] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.156170] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.158384] DCDC1: at 1500 mV
[ 0.159543] vdd_mpu: 925 â 1325 mV at 1100 mV
[ 0.160724] vdd_core: 925 â 1150 mV at 1100 mV
[ 0.161820] LDO1: at 1800 mV
[ 0.162950] LDO2: at 3300 mV
[ 0.164881] LDO3: 1800 mV
[ 0.166024] LDO4: at 3300 mV
[ 0.167029] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.167736] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.168519] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.170834] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.171054] media: Linux media interface: v0.10
[ 0.171156] Linux video capture interface: v2.00
[ 0.171300] pps_core: LinuxPPS API ver. 1 registered
[ 0.171316] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.172156] Advanced Linux Sound Architecture Driver Initialized.
[ 0.173394] Switching to clocksource gp_timer
[ 0.191482] NET: Registered protocol family 2
[ 0.192468] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.192611] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.192773] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.192867] TCP: reno registered
[ 0.192895] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.192942] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.193432] NET: Registered protocol family 1
[ 0.193977] RPC: Registered named UNIX socket transport module.
[ 0.193997] RPC: Registered udp transport module.
[ 0.194011] RPC: Registered tcp transport module.
[ 0.194025] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.194747] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.195286] CPU PMU: attempt to register multiple PMU devices!
[ 0.195329] arm-pmu: probe of arm-pmu failed with error -28
[ 0.195720] omap2_mbox_probe: platform not supported
[ 0.199577] VFS: Disk quotas dquot_6.5.2
[ 0.199810] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.201179] NFS: Registering the id_resolver key type
[ 0.201272] Key type id_resolver registered
[ 0.201288] Key type id_legacy registered
[ 0.201353] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.201792] msgmni has been set to 996
[ 0.204621] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.204647] io scheduler noop registered
[ 0.204663] io scheduler deadline registered
[ 0.204703] io scheduler cfq registered (default)
[ 0.206441] tps65217-bl tps65217-bl: no platform data provided
[ 0.206483] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.207464] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.210004] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.210283] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 0.924362] console [ttyO0] enabled
[ 0.929257] [drm] Initialized drm 1.1.0 20060810
[ 0.947801] brd: module loaded
[ 0.957966] loop: module loaded
[ 0.961417] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.968707] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.975981] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.983253] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.990526] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.005046] bone-capemgr bone_capemgr.9: Baseboard: âA335BNLT,00C0,2309SBB16650â
[ 1.012841] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-black
[ 1.050472] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 1.087577] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 1.124686] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 1.161796] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 1.168052] bone-capemgr bone_capemgr.9: slot #4: specific override
[ 1.174657] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[ 1.182696] bone-capemgr bone_capemgr.9: slot #4: âBone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2Gâ
[ 1.192856] bone-capemgr bone_capemgr.9: slot #5: specific override
[ 1.199456] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[ 1.207493] bone-capemgr bone_capemgr.9: slot #5: âBone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMIâ
[ 1.217543] bone-capemgr bone_capemgr.9: slot #6: specific override
[ 1.224141] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[ 1.232178] bone-capemgr bone_capemgr.9: slot #6: âBone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMINâ
[ 1.242895] bone-capemgr bone_capemgr.9: initialized OK.
[ 1.248538] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware âcape-bone-2g-emmc1.dtboâ for board-name âBone-LT-eMMC-2Gâ, version â00A0â
[ 1.262130] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware âcape-boneblack-hdmi-00A0.dtboâ for board-name âBone-Black-HDMIâ, version â00A0â
[ 1.278236] OneNAND driver initializing
[ 1.283867] usbcore: registered new interface driver asix
[ 1.289583] bone-capemgr bone_capemgr.9: slot #4: dtbo âcape-bone-2g-emmc1.dtboâ loaded; converting to live tree
[ 1.300289] bone-capemgr bone_capemgr.9: slot #5: dtbo âcape-boneblack-hdmi-00A0.dtboâ loaded; converting to live tree
[ 1.311666] usbcore: registered new interface driver cdc_ether
[ 1.318130] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[ 1.324298] usbcore: registered new interface driver smsc95xx
[ 1.331281] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[ 1.338233] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[ 1.345273] usbcore: registered new interface driver net1080
[ 1.353435] platform 4830e000.fb: alias fck already exists
[ 1.359374] usbcore: registered new interface driver cdc_subset
[ 1.367423] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[ 1.374381] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware âcape-boneblack-hdmin-00A0.dtboâ for board-name âBone-Black-HDMINâ, version â00A0â
[ 1.388810] usbcore: registered new interface driver zaurus
[ 1.394863] usbcore: registered new interface driver cdc_ncm
[ 1.400957] bone-capemgr bone_capemgr.9: slot #6: dtbo âcape-boneblack-hdmin-00A0.dtboâ loaded; converting to live tree
[ 1.413202] usbcore: registered new interface driver cdc_acm
[ 1.419191] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.427580] Initializing USB Mass Storage driverâŠ
[ 1.432844] usbcore: registered new interface driver usb-storage
[ 1.439170] USB Mass Storage support registered.
[ 1.444368] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 1.453963] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 1.460738] bone-capemgr bone_capemgr.9: loader: retrying slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.469995] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.476728] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.481982] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.490756] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.500574] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.505622] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.511905] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.517166] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.526153] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.531226] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.536555] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.543002] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.551462] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.558603] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.566182] usb usb1: Product: MUSB HDRC host driver
[ 1.571400] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[ 1.577071] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.583338] hub 1-0:1.0: USB hub found
[ 1.587375] hub 1-0:1.0: 1 port detected
[ 1.592834] mousedev: PS/2 mouse device common for all mice
[ 1.601165] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.608967] i2c /dev entries driver
[ 1.614392] pps_ldisc: PPS line discipline registered
[ 1.619882] Driver for 1-wire Dallas network protocol.
[ 1.627137] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.634748] cpuidle: using governor ladder
[ 1.639073] cpuidle: using governor menu
[ 1.643685] omap_hsmmc mmc.5: of_parse_phandle_with_args of âresetâ failed
[ 1.650924] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[ 1.657730] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 1.664948] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 1.672302] mmc.5 supply vmmc_aux not found, using dummy regulator
[ 1.679239] omap_hsmmc mmc.5: pins are not configured from the driver
[ 1.712919] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[ 1.719121] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 1.727115] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[ 1.733595] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 1.740752] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 1.748265] mmc.11 supply vmmc_aux not found, using dummy regulator
[ 1.755010] omap_hsmmc mmc.11: pins are not configured from the driver
[ 1.789290] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 1.800992] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 1.808299] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 1.817271] leds-gpio gpio-leds.8: pins are not configured from the driver
[ 1.825890] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.832718] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 1.839962] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.848375] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.854744] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 1.861924] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 1.870529] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 1.879761] mmc0: new high speed SDHC card at address 1234
[ 1.889023] usbcore: registered new interface driver usbhid
[ 1.894915] usbhid: USB HID core driver
[ 1.899735] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[ 1.908088] mmcblk0: p1 p2
[ 1.914324] davinci_evm sound.14: nxp-hdmi-hifi â 48038000.mcasp mapping ok
[ 1.925726] TCP: cubic registered
[ 1.929259] Initializing XFRM netlink socket
[ 1.933798] NET: Registered protocol family 17
[ 1.938584] NET: Registered protocol family 15
[ 1.943420] Key type dns_resolver registered
[ 1.948209] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.956373] ThumbEE CPU extension supported.
[ 1.960913] Registering SWP/SWPB emulation handler
[ 1.967101] registered taskstats version 1
[ 1.973099] pinctrl-single 44e10800.pinmux: pin 44e109b0 already requested by mmc.11; cannot claim for hdmi.13
[ 1.983642] pinctrl-single 44e10800.pinmux: pin-108 (hdmi.13) status -22
[ 1.990679] pinctrl-single 44e10800.pinmux: could not request pin 108 on device pinctrl-single
[ 1.999705] slave hdmi.13: Failed to select default state
[ 2.005488] slave: probe of hdmi.13 failed with error -22
[ 2.012877] tilcdc 4830e000.fb: No power control GPIO
[ 2.054865] mmc1: BKOPS_EN bit is not set
[ 2.064831] mmc1: new high speed MMC card at address 0001
[ 2.071246] mmcblk1: mmc1:0001 MK2704 3.53 GiB
[ 2.076646] mmcblk1boot0: mmc1:0001 MK2704 partition 1 2.00 MiB
[ 2.083212] mmcblk1boot1: mmc1:0001 MK2704 partition 2 2.00 MiB
[ 2.091176] mmcblk1: p1 p2 p3
[ 2.098179] mmcblk1boot1: unknown partition table
[ 2.105972] mmcblk1boot0: unknown partition table
[ 2.131661] tilcdc 4830e000.fb: found TDA19988
[ 2.137112] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.144068] [drm] No driver support for vblank timestamp query.
[ 2.150667] tilcdc 4830e000.fb: No connectors reported connected with modes
[ 2.158064] [drm] Cannot find any crtc or sizes - going 1024x768
[ 2.181726] Console: switching to colour frame buffer device 128x48
[ 2.202958] tilcdc 4830e000.fb: fb0: frame buffer device
[ 2.208647] tilcdc 4830e000.fb: registered panic notifier
[ 2.214449] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 2.271208] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.277633] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.285203] libphy: 4a101000.mdio: probed
[ 2.289468] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.299308] Detected MACID = 54:45:38:01:0e:24
[ 2.303967] cpsw 4a100000.ethernet: NAPI disabled
[ 2.310723] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.327004] ALSA device list:
[ 2.330161] #0: TI BeagleBone Black
[ 2.340776] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[ 2.348792] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.360031] devtmpfs: mounted
[ 2.363519] Freeing init memory: 264K
[ 2.756886] systemd[1]: systemd 196 running in system mode. (+PAM -LIBWRAP -AUDIT -SELINUX +IMA +SYSVINIT -LIBCRYPTSETUP +GCRYPT +ACL +XZ; angstrom)
Welcome to The à ngström Distribution v2012.12!
If you compare them, you will notice a difference between those two. On a working Beaglebone, the following lines occur in the log:
From this, I conclude, the non working Beaglebone doesnât see the SD card properly, resuling in this log line:
If I jump into the UBOOT cli, (by removing the SD card on time) and comparing the printenv list, I am not seeing any differences (excep MAC address)
I also tried an official Beaglebone black image. On a working Beaglebone, there is no problem programming it. On a non working Beaglebone, the same problem occurs with our own image.
I also checked the hardware on missing resistors and checking their values. I didnât find any difference with a working Beaglebone.
Should I send them RMA, or does anyone have an idea? Please advice.
Best Regards,
Kees
