Hello, I wanted to access the ADC and the PWM pins for my motor driver application on BeagleV fire. I wanted to know:
1. how to use the PWM pins with varied duty cycle?
2. How to access the ADC data and capture a signal for further processing (Plot, tabulation, etc.) ?
TIA.
I am using the cape(both cape_for_uarts and robotics) mentioned here:
I am using the following process:
ls /sys/class/pwm/
pwmchip0 pwmchip16 pwmchip32
echo 0 | sudo tee /sys/class/pwm/pwmchip0/pwm0/enable
echo 20000000 | sudo tee /sys/class/pwm/pwmchip0/pwm0/period
echo 1500000 | sudo tee /sys/class/pwm/pwmchip0/pwm0/duty_cycle
echo 1 | sudo tee /sys/class/pwm/pwmchip0/pwm0/enable
I don’t know which physical pin it is referring as pwmchip0/pwm0?
My primary problem is I want to change the duty cycle and frequency of PWM and apply it on a specific pin. Any help would be really appreciated.
ADC part, I have been able to figure out myself.
TIA.
