First of all I am not a PRU expert in anyway, I just need to get some code running so I thought I would post some basics about getting something running on one of the PRUs to toggle a gpio on the pin headers. I will follow this up with some more posts about getting pasm and prudebug running on the AI64.
Everything here should be done as root
This file is your friend: /opt/source/dtb-5.10-ti-arm64/src/arm64/k3-j721e-beagleboneai64.dts
Search for #define BONE_PIN(XX,ZZ,QQ)
Under that line are all the definitions for the headers, so we can see for instance:
BONE_PIN(P8_16, default, P8_16(PIN_INPUT, 7))
BONE_PIN(P8_16, pruout, P8_16(PIN_OUTPUT, 0))
BONE_PIN(P8_16, pruin, P8_16(PIN_INPUT, 1))
BONE_PIN(P8_16, gpio, P8_16(PIN_INPUT, 7))
BONE_PIN(P8_16, gpio_pu, P8_16(PIN_INPUT_PULLUP, 7))
BONE_PIN(P8_16, gpio_pd, P8_16(PIN_INPUT_PULLDOWN, 7))
So we can use P8_16 for output from the pru.
In order to do this we need to change cape_header: pinmux_dummy to choose what muxing we want.
So we change
&P8_16_default_pin
to
&P8_16_pruout_pin
Now make all the dts stuff, install it and reboot:
cd /opt/source/dtb-5.10-ti-arm64/
make
make install
sync
reboot
Now we can output to P8_16, to test this we will modify one of the pru examples that is on the AI64
cd /usr/lib/ti/pru-software-support-package/examples/j721e/PRU_RPMsg_Echo_Interrupt0
cp main.c main_backup.c
This example creates a device /dev/rpmsg_pru30, if we write data to that device the data will be echoed back to it.
We will change it to toggle all the GPIOs whenever it receives a message, this then should then toggle P8_16.
__R30 is used for the GPIOs so we add in:
volatile register uint32_t __R30;
in main() we add:
volatile uint32_t gpio;
gpio = 0xFFFFFFFF;
Then whenever we receive a message we flip __R30
while (pru_rpmsg_receive(&transport, &src, &dst, payload, &len) == PRU_RPMSG_SUCCESS) {
//toggle gpios
__R30 ^= gpio;
/* Echo the message back to the same address from which we just received */
pru_rpmsg_send(&transport, dst, src, payload, len);
now build it and copy to the correct place, we are using the first pru PRU0 with is remoteproc0
the firmware name that is set can be found like this:
cat /sys/class/remoteproc/remoteproc0/firmware
j7-pru0_0-fw
So:
make
cp gen/icssg0/PRU_RPMsg_Echo_Interrupt0_0.out /lib/firmware/j7-pru0_0-fw
Now the firmware is in the correct place we can set it running:
echo 'start' > /sys/class/remoteproc/remoteproc0/state
we can use dmesg to check that everything has loaded, you should see:
[ 644.802576] remoteproc remoteproc0: powering up b034000.pru
[ 644.808380] remoteproc remoteproc0: Booting fw image j7-pru0_0-fw, size 122156
[ 644.822303] virtio_rpmsg_bus virtio6: creating channel rpmsg-pru addr 0x1e
[ 644.829311] virtio_rpmsg_bus virtio6: rpmsg host is online
[ 644.836014] remoteproc0#vdev0buffer: registered virtio6 (type 7)
[ 644.842165] remoteproc remoteproc0: remote processor b034000.pru is now up
[ 644.852919] rpmsg_pru virtio6.rpmsg-pru.-1.30: new rpmsg_pru device: /dev/rpmsg_pru30
So we now have our echo device /dev/rpmsg_pru30
Each time you write a message to it P8_16 should toggle and you should also be able to see the echoed data:
echo 1 > /dev/rpmsg_pru30
echo 2 > /dev/rpmsg_pru30
cat /dev/rpmsg_pru30
1
2
^C
Edit: I have included the main.c file to copy into /usr/lib/ti/pru-software-support-package/examples/j721e/PRU_RPMsg_Echo_Interrupt0
main.c (4.1 KB)
