I have followed the the complete process, still no luck.
I have no clue what am I missing.
Here are the boot logs and dmesg logs.
Boot Logs
U-Boot SPL 2024.04-dirty (Aug 31 2024 - 09:30:23 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
Trying to boot from MMC2
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b8
NOTICE: BL31: Built : 09:06:38, Aug 31 2024
I/TC:
I/TC: OP-TEE version: 4.2.0-dev (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04)) #1 Sat Aug 31 09:07:40 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2024.04-dirty (Aug 31 2024 - 09:30:09 +0000)
U-Boot 2024.04-dirty (Aug 31 2024 - 09:30:09 +0000)
SoC: J721E SR1.1 GP
Model: BeagleBoard.org BeagleBone AI-64
DRAM: 2 GiB (effective 4 GiB)
Core: 124 devices, 32 uclasses, devicetree: separate
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1
Net: eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
1292 bytes read in 35 ms (35.2 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 42 ms (0 Bytes/s)
Already setup.
Scanning for bootflows in all bootdevs
Seq Method State Uclass Part Name Filename
Scanning bootdev 'mmc@4fb0000.bootdev':
0 extlinux ready mmc 1 mmc@4fb0000.bootdev.part_ /extlinux/extlinux.conf
** Booting bootflow 'mmc@4fb0000.bootdev.part_1' with extlinux
BeagleBone AI-64 microSD (extlinux.conf) Options
1: BeagleBone AI-64 microSD Recovery
2: BeagleBone AI-64 copy microSD to eMMC
3: BeagleBone AI-64 microSD (default)
Enter choice: 3: BeagleBone AI-64 microSD (default)
Retrieving file: /Image
append: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
Retrieving file: /ti/k3-j721e-beagleboneai64.dtb
## Flattened Device Tree blob at 88000000
Working FDT set to 88000000
ERROR: reserving fdt memory region failed (addr=880000000 size=27000000 flags=4)
Loading Device Tree to 000000008ffe0000, end 000000008ffff1c7 ... OK
Working FDT set to 8ffe0000
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 1.261642] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[ 2.429518] systemd[1]: Failed to start Start psplash boot splash screen.
[FAILED] Failed to start Start psplash boot splash screen.
[DEPEND] Dependency failed for Start psplasâŚtemd progress communication helper.
[FAILED] Failed to start Synchronize System and HW clocks.
[FAILED] Failed to start Weston, a Wayland compositor, as a system service.
NOTICE: This file system contains the following GPL-3.0 packages:
adwaita-icon-theme-symbolic
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
findutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gnu-config
grub-common
grub-editenv
grub-efi
gzip
hidapi
kbd-dev
kbd-keymaps-pine
less
libasm1
libatomic-dev
libatomic1
libbfd
libdebuginfod1
libdw1
libelf1
libgcc-s-dev
libgcc1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp10
libidn2-0
libmpc3
libmpfr6
libopcodes
libqt5charts-examples
libqt5charts-plugins
libqt5charts-qmlplugins
libqt5charts5
libqt5serialport-examples
libqt5serialport-plugins
libqt5serialport-qmlplugins
libqt5serialport5
libqt5svg-examples
libqt5svg-plugins
libqt5svg-qmlplugins
libqt5svg5
libqt5virtualkeyboard-plugins
libqt5virtualkeyboard-qmlplugins
libqt5virtualkeyboard5
libreadline-dev
libreadline8
libstdc++-dev
libstdc++6
libunistring5
m4
make
nettle
parted
piglit
qt3d-plugins
qt3d-qmlplugins
qt3d
qtbase-examples
qtbase-plugins
qtbase-qmlplugins
qtbase
qtconnectivity-plugins
qtconnectivity-qmlplugins
qtconnectivity
qtdeclarative-plugins
qtdeclarative-qmlplugins
qtdeclarative-tools
qtdeclarative
qtgraphicaleffects-qmlplugins
qtlocation-examples
qtlocation-plugins
qtlocation-qmlplugins
qtlocation
qtmultimedia-examples
qtmultimedia-plugins
qtmultimedia-qmlplugins
qtmultimedia
qtquics-qmlplugins.control
qtquics2-plugins.control
qtquics2-qmlplugins.control
qtquics2.control
qtscript-examples
qtscript-plugins
qtscript-qmlplugins
qtscript
qtwayland-examples
qtwayland-plugins
qtwayland-qmlplugins
qtwayland
tar
which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j721e-evm ttyS2
Arago 2023.10 j721e-evm ttyS2
j721e-evm login: root
dmesg logs
root@j721e-evm:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.6.32-gdb8871293143-dirty (root@ip-172-31-15-62) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #1 SMP PREEMPT Sat Aug 31 09:36:18 UTC 2024
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a4000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a5ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a4100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a6000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a6100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a7000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a7100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable vision-apps-c66-dma-memory@a8000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable vision-apps-c66-memory@a8100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a9000000..0x00000000a90fffff (1024 KiB) nomap non-reusable vision-apps-c66-dma-memory@a9000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a9100000..0x00000000a9ffffff (15360 KiB) nomap non-reusable vision-apps-c66-memory@a9100000
[ 0.000000] OF: reserved mem: 0x00000000aa000000..0x00000000abffffff (32768 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000ac000000..0x00000000b1ffffff (98304 KiB) nomap non-reusable vision-apps-dma-memory@ac000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b2000000..0x00000000b20fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@b2000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b2100000..0x00000000b7ffffff (97280 KiB) nomap non-reusable vision-apps-c71-memory@b2100000
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] OF: reserved mem: 0x00000000b8000000..0x00000000d7ffffff (524288 KiB) map non-reusable vision_apps_shared-memories
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000d8000000..0x00000000e3ffffff (196608 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@d8000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000e4000000..0x00000000e47fffff (8192 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-queues@e4000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000e4800000..0x00000000e5ffffff (24576 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-buffers@e4800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000880000000..0x00000008a6ffffff (638976 KiB) nomap non-reusable vision-apps-core-heap-memory-hi@880000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff]
[ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 32 MiB at 0x00000000fe000000 on node -1
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
[ 0.000000] pcpu-alloc: s42920 r8192 d30808 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 2.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB)
[ 0.000000] Memory: 2186280K/4194304K available (11968K kernel code, 1250K rwdata, 4032K rodata, 2432K init, 502K bss, 1975256K reserved, 32768K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008a7040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7050000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000207] Console: colour dummy device 80x25
[ 0.000214] printk: console [tty0] enabled
[ 0.000281] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000288] pid_max: default: 32768 minimum: 301
[ 0.000332] LSM: initializing lsm=capability,integrity
[ 0.000392] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000408] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001290] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[ 0.001340] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[ 0.001452] rcu: Hierarchical SRCU implementation.
[ 0.001456] rcu: Max phase no-delay instances is 1000.
[ 0.001628] Platform MSI: msi-controller@1820000 domain created
[ 0.001816] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.001977] EFI services will not be available.
[ 0.002079] smp: Bringing up secondary CPUs ...
[ 0.010676] Detected PIPT I-cache on CPU1
[ 0.010725] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.010737] GICv3: CPU1: using allocated LPI pending table @0x00000008a7060000
[ 0.010768] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.010824] smp: Brought up 1 node, 2 CPUs
[ 0.010829] SMP: Total of 2 processors activated.
[ 0.010832] CPU features: detected: 32-bit EL0 Support
[ 0.010835] CPU features: detected: CRC32 instructions
[ 0.010872] CPU: All CPU(s) started at EL2
[ 0.010874] alternatives: applying system-wide alternatives
[ 0.011755] devtmpfs: initialized
[ 0.018100] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.018116] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.018724] pinctrl core: initialized pinctrl subsystem
[ 0.019056] DMI not present or invalid.
[ 0.019369] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.019893] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.020017] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.020141] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.020169] audit: initializing netlink subsys (disabled)
[ 0.020258] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
[ 0.020443] thermal_sys: Registered thermal governor 'step_wise'
[ 0.020447] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.020466] cpuidle: using governor menu
[ 0.020544] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.020571] ASID allocator initialised with 65536 entries
[ 0.029739] platform a000000.dp-bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.029952] platform a000000.dp-bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.029980] platform 4a00000.dss: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[ 0.031438] platform a000000.dp-bridge: Fixed dependency cycle(s) with /connector
[ 0.031471] platform connector: Fixed dependency cycle(s) with /bus@100000/dp-bridge@a000000
[ 0.031652] Modules: 27680 pages in range for non-PLT usage
[ 0.031655] Modules: 519200 pages in range for PLT usage
[ 0.032100] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.032105] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.032109] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.032111] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.032114] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.032116] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.032119] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.032121] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.032826] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.1 JTAGID[0x1bb6402f] Detected
[ 0.033442] iommu: Default domain type: Translated
[ 0.033448] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.033736] SCSI subsystem initialized
[ 0.033807] libata version 3.00 loaded.
[ 0.033884] usbcore: registered new interface driver usbfs
[ 0.033898] usbcore: registered new interface driver hub
[ 0.033913] usbcore: registered new device driver usb
[ 0.034164] pps_core: LinuxPPS API ver. 1 registered
[ 0.034167] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.034174] PTP clock support registered
[ 0.034270] EDAC MC: Ver: 3.0.0
[ 0.034506] scmi_core: SCMI protocol bus registered
[ 0.034637] FPGA manager framework
[ 0.034677] Advanced Linux Sound Architecture Driver Initialized.
[ 0.035117] vgaarb: loaded
[ 0.035280] clocksource: Switched to clocksource arch_sys_counter
[ 0.035400] VFS: Disk quotas dquot_6.6.0
[ 0.035414] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.038390] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.038461] NET: Registered PF_INET protocol family
[ 0.038606] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.040082] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.040114] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.040122] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.040234] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.041247] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.041333] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.041386] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.041526] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.041866] RPC: Registered named UNIX socket transport module.
[ 0.041871] RPC: Registered udp transport module.
[ 0.041874] RPC: Registered tcp transport module.
[ 0.041875] RPC: Registered tcp-with-tls transport module.
[ 0.041877] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.041883] NET: Registered PF_XDP protocol family
[ 0.041898] PCI: CLS 0 bytes, default 64
[ 0.042561] Initialise system trusted keyrings
[ 0.042676] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.042824] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.042951] NFS: Registering the id_resolver key type
[ 0.042967] Key type id_resolver registered
[ 0.042969] Key type id_legacy registered
[ 0.042980] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.042983] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.056620] Key type asymmetric registered
[ 0.056624] Asymmetric key parser 'x509' registered
[ 0.056652] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.056656] io scheduler mq-deadline registered
[ 0.056660] io scheduler kyber registered
[ 0.056682] io scheduler bfq registered
[ 0.058766] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.059077] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.059569] pinctrl-single 104200.pinctrl: 20 pins, size 80
[ 0.059627] pinctrl-single 104280.pinctrl: 8 pins, size 32
[ 0.063122] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 0.065548] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.065850] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.066047] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.066999] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.069713] loop: module loaded
[ 0.070262] megasas: 07.725.01.00-rc1
[ 0.072067] tun: Universal TUN/TAP device driver, 1.6
[ 0.072600] VFIO - User Level meta-driver version: 0.3
[ 0.073198] usbcore: registered new interface driver usb-storage
[ 0.073527] i2c_dev: i2c /dev entries driver
[ 0.074160] sdhci: Secure Digital Host Controller Interface driver
[ 0.074164] sdhci: Copyright(c) Pierre Ossman
[ 0.074284] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.074682] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.074844] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.075230] usbcore: registered new interface driver usbhid
[ 0.075234] usbhid: USB HID core driver
[ 0.076022] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.076275] optee: probing for conduit method.
[ 0.076292] optee: revision 4.2 (12d7c4ee)
[ 0.092757] optee: dynamic shared memory is enabled
[ 0.093187] random: crng init done
[ 0.093238] optee: initialized driver
[ 0.094539] NET: Registered PF_PACKET protocol family
[ 0.094583] Key type dns_resolver registered
[ 0.097921] registered taskstats version 1
[ 0.098102] Loading compiled-in X.509 certificates
[ 0.105091] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[ 0.197264] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.197714] omap_i2c 2000000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.198242] omap_i2c 2010000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.198827] omap_i2c 2020000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.199187] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.199550] omap_i2c 2040000.i2c: bus 3 rev0.12 at 100 kHz
[ 0.199899] omap_i2c 2050000.i2c: bus 7 rev0.12 at 400 kHz
[ 0.200306] omap_i2c 2060000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.200424] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[ 0.200514] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[ 0.200601] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[ 0.200751] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.209508] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 0.209520] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.209524] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.211751] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 0.211762] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.211765] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.212385] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 209, base_baud = 3000000) is a 8250
[ 0.212425] printk: console [ttyS2] enabled
[ 0.213093] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 0.251283] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 0.253218] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 0.253242] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 0.253344] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 0.253349] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 0.253752] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 0.255265] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 0.256004] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 0.256155] mmc0: CQHCI version 5.10
[ 0.256346] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 0.256699] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 0.257027] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 0.257315] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 0.270474] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 0.270500] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 0.270511] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 0.270521] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 0.294557] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 0.392330] mmc0: Command Queue Engine enabled
[ 0.392338] mmc0: new HS200 MMC card at address 0001
[ 0.392601] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 0.393468] mmcblk0: p1 p2
[ 0.393706] mmcblk0boot0: mmc0:0001 TB2916 4.00 MiB
[ 0.394160] mmcblk0boot1: mmc0:0001 TB2916 4.00 MiB
[ 0.394581] mmcblk0rpmb: mmc0:0001 TB2916 4.00 MiB, chardev (239:0)
[ 1.259718] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[ 1.259729] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.259735] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[ 1.259740] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 1.259763] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 1.259768] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 1.259837] pci 0000:00:00.0: supports D1
[ 1.259840] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.261457] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.261551] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.261564] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.268550] pcieport 0000:00:00.0: PME: Signaling with IRQ 484
[ 1.268710] pcieport 0000:00:00.0: AER: enabled with IRQ 484
[ 1.269609] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 1.272242] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 1.275189] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 1.315302] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.317233] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.317258] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 1.317369] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.317373] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.317719] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 1.325604] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 1.330301] leds-gpio leds: Led :disk-activity renamed to :disk-activity_1 due to name collision
[ 1.331154] mmc1: CQHCI version 5.10
[ 1.334873] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.335196] clk: Disabling unused clocks
[ 1.353864] ALSA device list:
[ 1.353871] No soundcards found.
[ 1.367301] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 1.367403] Waiting for root device /dev/mmcblk1p2...
[ 1.421803] mmc1: new ultra high speed DDR50 SDXC card at address aaaa
[ 1.422196] mmcblk1: mmc1:aaaa SH64G 59.5 GiB
[ 1.423649] mmcblk1: p1 p2
[ 1.439584] EXT4-fs (mmcblk1p2): mounted filesystem e818e229-dbd3-4974-864d-9cb749e4a0d4 ro with ordered data mode. Quota mode: none.
[ 1.439626] VFS: Mounted root (ext4 filesystem) readonly on device 179:98.
[ 1.444178] devtmpfs: mounted
[ 1.445311] Freeing unused kernel memory: 2432K
[ 1.445393] Run /sbin/init as init process
[ 1.445397] with arguments:
[ 1.445399] /sbin/init
[ 1.445401] with environment:
[ 1.445403] HOME=/
[ 1.445405] TERM=linux
[ 1.766687] systemd[1]: System time before build time, advancing clock.
[ 1.815784] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 1.815800] systemd[1]: Detected architecture arm64.
[ 1.826351] systemd[1]: Hostname set to <j721e-evm>.
[ 1.834524] systemd[1]: Initializing machine ID from random generator.
[ 1.834613] systemd[1]: Installed transient /etc/machine-id file.
[ 2.078976] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 2.078999] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 2.099622] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 2.155022] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 2.200544] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.234233] systemd[1]: Created slice Slice /system/getty.
[ 2.235444] systemd[1]: Created slice Slice /system/modprobe.
[ 2.236464] systemd[1]: Created slice Slice /system/serial-getty.
[ 2.237193] systemd[1]: Created slice User and Session Slice.
[ 2.237366] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.237466] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.237531] systemd[1]: Expecting device /dev/ttyS2...
[ 2.237611] systemd[1]: Reached target Path Units.
[ 2.237646] systemd[1]: Reached target Remote File Systems.
[ 2.237682] systemd[1]: Reached target Slice Units.
[ 2.237718] systemd[1]: Reached target Swaps.
[ 2.243159] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 2.243312] systemd[1]: Reached target RPC Port Mapper.
[ 2.247181] systemd[1]: Listening on Process Core Dump Socket.
[ 2.247432] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.248034] systemd[1]: Listening on Journal Audit Socket.
[ 2.248320] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.248608] systemd[1]: Listening on Journal Socket.
[ 2.248955] systemd[1]: Listening on Network Service Netlink Socket.
[ 2.253074] systemd[1]: Listening on udev Control Socket.
[ 2.253362] systemd[1]: Listening on udev Kernel Socket.
[ 2.253600] systemd[1]: Listening on User Database Manager Socket.
[ 2.256960] systemd[1]: Mounting Huge Pages File System...
[ 2.258942] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.263149] systemd[1]: Mounting Kernel Debug File System...
[ 2.263484] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 2.291542] systemd[1]: Mounting Temporary Directory /tmp...
[ 2.291812] systemd[1]: Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/6.6.32-gdb8871293143-dirty/modules.devname).
[ 2.294723] systemd[1]: Starting Load Kernel Module configfs...
[ 2.300839] systemd[1]: Starting Load Kernel Module drm...
[ 2.311808] systemd[1]: Starting Load Kernel Module fuse...
[ 2.323931] systemd[1]: Starting Start psplash boot splash screen...
[ 2.331863] systemd[1]: Starting RPC Bind...
[ 2.339940] systemd[1]: Starting File System Check on Root Device...
[ 2.350056] systemd[1]: Starting Journal Service...
[ 2.363592] systemd[1]: Starting Load Kernel Modules...
[ 2.368922] systemd[1]: Starting Generate network units from Kernel command line...
[ 2.379986] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 2.391934] systemd[1]: Starting Coldplug All udev Devices...
[ 2.398903] systemd[1]: Mounted Huge Pages File System.
[ 2.403499] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.403979] systemd[1]: Mounted Kernel Debug File System.
[ 2.404322] systemd[1]: Mounted Temporary Directory /tmp.
[ 2.404963] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.407494] systemd[1]: Finished Load Kernel Module configfs.
[ 2.408344] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.408695] systemd[1]: Finished Load Kernel Module drm.
[ 2.409431] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.409815] systemd[1]: Finished Load Kernel Module fuse.
[ 2.411914] systemd[1]: FUSE Control File System was skipped because of an unmet condition check (ConditionPathExists=/sys/fs/fuse/connections).
[ 2.416871] systemd[1]: Mounting Kernel Configuration File System...
[ 2.426614] systemd[1]: psplash-start.service: Main process exited, code=exited, status=255/EXCEPTION
[ 2.426953] systemd[1]: psplash-start.service: Failed with result 'exit-code'.
[ 2.443621] systemd[1]: Dependency failed for Start psplash-systemd progress communication helper.
[ 2.443688] systemd[1]: psplash-systemd.service: Job psplash-systemd.service/start failed with result 'dependency'.
[ 2.446255] systemd[1]: Finished Generate network units from Kernel command line.
[ 2.447938] systemd[1]: Mounted Kernel Configuration File System.
[ 2.460240] systemd[1]: Finished Load Kernel Modules.
[ 2.475641] systemd[1]: Starting Apply Kernel Variables...
[ 2.476586] systemd-journald[111]: Collecting audit messages is enabled.
[ 2.507908] systemd[1]: Started RPC Bind.
[ 2.532830] systemd[1]: Started Journal Service.
[ 2.704211] EXT4-fs (mmcblk1p2): re-mounted e818e229-dbd3-4974-864d-9cb749e4a0d4 r/w. Quota mode: none.
[ 2.753009] systemd-journald[111]: Received client request to flush runtime journal.
[ 2.811511] audit: type=1334 audit(1709054765.040:2): prog-id=6 op=LOAD
[ 2.812347] audit: type=1334 audit(1709054765.044:3): prog-id=7 op=LOAD
[ 2.812600] audit: type=1334 audit(1709054765.044:4): prog-id=8 op=LOAD
[ 2.955345] audit: type=1334 audit(1709054765.188:5): prog-id=9 op=LOAD
[ 2.955522] audit: type=1334 audit(1709054765.188:6): prog-id=10 op=LOAD
[ 3.670639] audit: type=1334 audit(1709054765.900:7): prog-id=11 op=LOAD
[ 3.678804] audit: type=1334 audit(1709054765.908:8): prog-id=12 op=LOAD
[ 4.776823] EXT4-fs (mmcblk0p2): mounted filesystem 924be20d-6ebf-4646-b3c9-2ef195b6ec8d r/w with ordered data mode. Quota mode: none.
[ 7.012388] audit: type=1334 audit(1709054769.244:9): prog-id=13 op=LOAD
[ 7.111221] dbus-broker-lau[538]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 7.196219] audit: type=1334 audit(1709054769.424:10): prog-id=14 op=LOAD
[ 7.198636] audit: type=1334 audit(1709054769.428:11): prog-id=15 op=LOAD
[ 7.198779] audit: type=1334 audit(1709054769.428:12): prog-id=16 op=LOAD
[ 7.249940] audit: type=1334 audit(1709054769.480:13): prog-id=17 op=LOAD
[ 7.779707] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 7.779727] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ 8.632367] audit: type=1006 audit(1709054770.864:14): pid=619 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 8.632406] audit: type=1300 audit(1709054770.864:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffcfa78088 a2=4 a3=1 items=0 ppid=1 pid=619 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[ 8.632433] audit: type=1327 audit(1709054770.864:14): proctitle="(systemd)"
[ 9.138365] audit: type=1006 audit(1709054771.368:15): pid=609 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
[ 9.138383] audit: type=1300 audit(1709054771.368:15): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe8185ce8 a2=4 a3=1 items=0 ppid=1 pid=609 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[ 9.832137] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 16.394735] kauditd_printk_skb: 4 callbacks suppressed
[ 16.394743] audit: type=1006 audit(1709054778.624:19): pid=995 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[ 16.395432] audit: type=1300 audit(1709054778.624:19): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffece3ee78 a2=1 a3=1 items=0 ppid=1 pid=995 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[ 16.395446] audit: type=1327 audit(1709054778.624:19): proctitle="(systemd)"
[ 16.411205] audit: type=1334 audit(1709054778.640:20): prog-id=21 op=LOAD
[ 16.411221] audit: type=1300 audit(1709054778.640:20): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffdb7f2e58 a2=90 a3=0 items=0 ppid=1 pid=995 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[ 16.411228] audit: type=1327 audit(1709054778.640:20): proctitle="(systemd)"
[ 16.411236] audit: type=1334 audit(1709054778.640:21): prog-id=21 op=UNLOAD
[ 16.411242] audit: type=1300 audit(1709054778.640:21): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff8941ec60 items=0 ppid=1 pid=995 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[ 16.411248] audit: type=1327 audit(1709054778.640:21): proctitle="(systemd)"
[ 16.411615] audit: type=1334 audit(1709054778.640:22): prog-id=22 op=LOAD
[ 30.370557] kauditd_printk_skb: 5 callbacks suppressed
[ 30.370564] audit: type=1701 audit(1709054792.600:24): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1018 comm="vx_app_c7x_kern" exe="/opt/vision_apps/vx_app_c7x_kernel.out" sig=11 res=1
[ 30.390054] audit: type=1334 audit(1709054792.620:25): prog-id=23 op=LOAD
[ 30.390376] audit: type=1334 audit(1709054792.620:26): prog-id=24 op=LOAD
[ 30.390472] audit: type=1334 audit(1709054792.620:27): prog-id=25 op=LOAD
[ 31.403358] audit: type=1334 audit(1709054793.636:28): prog-id=25 op=UNLOAD
[ 31.403375] audit: type=1334 audit(1709054793.636:29): prog-id=24 op=UNLOAD
[ 31.403382] audit: type=1334 audit(1709054793.636:30): prog-id=23 op=UNLOAD
[ 40.051634] audit: type=1334 audit(1709054802.284:31): prog-id=20 op=UNLOAD
[ 40.051650] audit: type=1334 audit(1709054802.284:32): prog-id=19 op=UNLOAD
[ 40.051655] audit: type=1334 audit(1709054802.284:33): prog-id=18 op=UNLOAD
[ 40.090363] audit: type=1334 audit(1725098328.872:34): prog-id=26 op=LOAD
[ 40.195726] audit: type=1334 audit(1725098328.980:35): prog-id=26 op=UNLOAD
