I think I’m getting close with integrating android-bluez. I have bluetoothd ‘seeing’ my adapter however dies at connecting to IPC. I’ve posed the question to the bluez list.
Here is a logcat with debugging enabled. I’ve googled the errors and have had no luck.
I/bluetoothd( 1072): Bluetooth daemon 5.28
D/bluetoothd( 1072): external/bluetooth/bluez/android/main.c:set_capabilities() Caps: eff: 0x3400, perm: 0x3400, inh: 0x0
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:bt_bluetooth_start() index -1
I/bluetoothd( 1072): Starting SDP server
D/bluetoothd( 1072): external/bluetooth/bluez/android/main.c:main() Entering main loop
I/bluetoothd( 1072): mgmt_if: [0xffff] command 0x0001
I/bluetoothd( 1072): mgmt_if: < 01 00 ff ff 00 00 …??..
I/bluetoothd( 1072): mgmt_if: > 01 00 ff ff 06 00 01 00 00 01 07 00 …??..
I/bluetoothd( 1072): mgmt_if: [0xffff] command 0x0001 complete: 0x00
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:read_version_complete()
I/bluetoothd( 1072): Bluetooth management interface 1.7 initialized
I/bluetoothd( 1072): Kernel connection control will be used
I/bluetoothd( 1072): mgmt_if: [0xffff] command 0x0003
I/bluetoothd( 1072): mgmt_if: < 03 00 ff ff 00 00 …??..
I/bluetoothd( 1072): mgmt_if: > 01 00 ff ff 07 00 03 00 00 01 00 00 00 …??..
I/bluetoothd( 1072): mgmt_if: [0xffff] command 0x0003 complete: 0x00
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:read_index_list_complete()
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:read_index_list_complete() Number of controllers: 1
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0004
I/bluetoothd( 1072): mgmt_if: < 04 00 00 00 00 00 …
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 1b 01 04 00 00 e9 36 36 e7 18 00 03 …?66?..
I/bluetoothd( 1072): mgmt_if: 0f 00 bf 10 00 00 90 00 00 00 00 00 00 42 43 4d …?..BCM
I/bluetoothd( 1072): mgmt_if: 32 30 34 35 42 33 00 00 00 00 00 00 00 00 00 00 2045B3…
I/bluetoothd( 1072): mgmt_if: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
I/bluetoothd( 1072): mgmt_if: 00 .
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0004 complete: 0x00
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:read_info_complete()
D/bluetoothd( 1072): external/bluetooth/bluez/src/sdpd-service.c:register_device_id() Adding device id record for 0002:1d6b:0247:051c
D/bluetoothd( 1072): external/bluetooth/bluez/src/sdpd-service.c:add_record_to_server() Adding record with handle 0x10001
D/bluetoothd( 1072): external/bluetooth/bluez/src/sdpd-service.c:add_record_to_server() Record pattern UUID 00001002-0000-1000-8000-00805f9
D/bluetoothd( 1072): external/bluetooth/bluez/src/sdpd-service.c:add_record_to_server() Record pattern UUID 0000113a-0000-1000-8000-00805f9
D/bluetoothd( 1072): external/bluetooth/bluez/src/sdpd-service.c:add_record_to_server() Record pattern UUID 0000113b-0000-1000-8000-00805f9
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:load_ltks() ltks 0
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:load_irks() irks 0
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:load_link_keys() keys 0
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x000e
I/bluetoothd( 1072): mgmt_if: < 0e 00 00 00 02 00 02 0c …
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 06 00 0e 00 00 00 00 00 …
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x000e complete: 0x00
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0011
I/bluetoothd( 1072): mgmt_if: < 11 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 …
I/bluetoothd( 1072): mgmt_if: 00 00 00 00 00 00 …
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 06 00 11 00 00 00 00 00 …
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0011 complete: 0x00
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0034
I/bluetoothd( 1072): mgmt_if: < 34 00 00 00 07 00 00 00 00 00 00 00 00 4…
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 0a 00 34 00 00 00 00 00 00 00 00 00 …4…
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0034 complete: 0x00
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0018
I/bluetoothd( 1072): mgmt_if: < 18 00 00 00 01 00 01 …
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 03 00 18 00 00 …
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0018 complete: 0x00
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0028
I/bluetoothd( 1072): mgmt_if: < 28 00 00 00 08 00 02 00 6b 1d 47 02 1c 05 (…k.G…
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 03 00 28 00 00 …(…
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0028 complete: 0x00
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0010
I/bluetoothd( 1072): mgmt_if: < 10 00 00 00 11 00 fb 34 9b 5f 80 00 00 80 00 10 …?4._…
I/bluetoothd( 1072): mgmt_if: 00 00 00 12 00 00 00 …
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 06 00 10 00 00 00 00 00 …
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0010 complete: 0x00
I/bluetoothd( 1072): mgmt_if: 00 00 3b 11 00 00 00 …;…
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0013
I/bluetoothd( 1072): mgmt_if: < 13 00 00 00 02 00 00 00 …
I/bluetoothd( 1072): mgmt_if: > 02 00 00 00 03 00 13 00 0c …
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x13 status: 0x0c
I/bluetoothd( 1072): Failed to load LTKs: Not Supported (0x0c)
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0030
I/bluetoothd( 1072): mgmt_if: < 30 00 00 00 02 00 00 00 0…
I/bluetoothd( 1072): mgmt_if: > 02 00 00 00 03 00 30 00 0c …0…
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x30 status: 0x0c
I/bluetoothd( 1072): Failed to load IRKs: Not Supported (0x0c)
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0012
I/bluetoothd( 1072): mgmt_if: < 12 00 00 00 03 00 00 00 00 …
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 03 00 12 00 00 …
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0012 complete: 0x00
D/bluetoothd( 1072): external/bluetooth/bluez/android/bluetooth.c:load_link_keys_complete() status 0
I/bluetoothd( 1072): Adapter initialized
D/bluetoothd( 1072): external/bluetooth/bluez/android/ipc.c:cmd_connect_cb()
E/bluetoothd( 1072): IPC: command socket connect failed
I/bluetoothd( 1072): Switching controller off
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0005
I/bluetoothd( 1072): mgmt_if: < 05 00 00 00 01 00 00 …
I/bluetoothd( 1072): mgmt_if: > 01 00 00 00 07 00 05 00 00 90 00 00 00 …
I/bluetoothd( 1072): mgmt_if: [0x0000] command 0x0005 complete: 0x00
D/bluetoothd( 1072): external/bluetooth/bluez/android/main.c:cleanup_services()
I/bluetoothd( 1072): Stopping SDP server
I/bluetoothd( 1072): Exit
