ROOT
debian-9.3-minimal-armhf-2017-12-09.tar.xz (extracted and copied to the ROOT partition)
It is able to flash eMMC via Sd card but failing to boot and giving kernel panic.
Bootup messages and uEnv.txt files are attached for reference.
Please let us know if we are missing anything. uEnv.txt (2.1 KB) BBB_Bootup_Messages.txt (27.5 KB)
Can you please confirm… microSD is “plugged in”???
Checking running system
==> Copying: [/dev/mmcblk1] -> [/dev/mmcblk0]
==> lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk1 179:0 0 3.6G 0 disk
`-mmcblk1p1 179:1 0 3.6G 0 part /
mmcblk1boot0 179:8 0 2M 1 disk
mmcblk1boot1 179:16 0 2M 1 disk
mmcblk1rpmb 179:24 0 512K 0 disk
==> df -h | grep rootfs:
!==> Error: [/dev/mmcblk0] does not exist
writing to [/dev/mmcblk0] failed...
If your microSD is plugged in, sadly the microSD or the microSD cage is damaged… Please first look inside the cage to see if there are any bent pins?? (they are very very delicate…)
Yes, microSD is plugged in.
However it is working fine if i try to flash demo images to eMMC via SD card.
We are facing issue with respect to custom image built.
