Today I have using beagle bone as normal (connected through USB). But suddenly the beaglebone turned off and when I connect it (usb or 5v input) only the led PWR flash once but nothing else happens. Only uart1_tx (rx was not) and ground were connected to other device (arduino) so I think that I could not fry the board.
I have a similar problem, but now the beaglebone does not do anything (powering by usb or adpater)
The last thing I did was use pin p9_5 (VDD_5V). The other time I did exactly the same so I think there could be any relation.
I use a lipo battery connected to a BEC and the BEC output connected to the pin p9_5 (VCC) and pin p9_1 (GROUND). BeagleBone worked perfectly but
when I switched it off (and disconnected from BEC) and connect by USB it never turn on again.
My BEC works perfectly, I used it to power the beaglebone using the dc input for a lot of time without having any issue.
The reason for using these pins instead of DC input is only for reasons of space.
When I connect the adapter I have 5V in the pin p9_5 but no led flash.
i too have this same problem. Filed a RMA already, will be sending it but facing problems in sending the courier from India. got it returned back from airport.!!
what shõud i do?
Contact the RMA team and they can help you get your paper work in line. Or, return it to your in country supplier for a replacement. If you bought it from outside of India, then the first suggestion is the best path to take.
Most likely there is a short in the processor. When the LED flashes that means the PMIC has detected an over current condition on power up and has shutdown. What sort of voltage did you have on the UART1 signals?
Well, glad you showed me. The maximum voltage is 3.3V on the processor. From what you told me you powered the MAX232 with 5V. That means the signal to the processor is 5V. You blew up the processor. Next time I suggest you run the MAX232 at 3.3V
Hi Gerald,
We need your help in how can we use UART1 in beaglebone for serial communication with PC.
In previous post you have asked me to power up MAX232 IC with 3.3V . But i’m not sure whether it can work with 3.3V after reference with this link. http://www.engineersgarage.com/electronic-components/max232-datasheet . It is said that its supply voltage is 5V (4.5 - 5.5V) , so please tell us what supply voltage should i use. If its true that MAX232 works on 5V , tell us how we can step it down to take it to the processor .
It would be highly appreciated if you guide us on the complete steps on how we can connect UART1 of beaglebone to PC , so that we can avoid any mess with the new beaglebone .
Our goal was to boot the kernel from UART1 and see it on minicom , where u-boot still remains in UART0.
1. In previous post you have asked me to power up MAX232 IC with
3.3V . But i'm not sure whether it can work with 3.3V after reference
processor .
Give this [1] a try instead of a MAX232 if you need to power from
3.3V and use 3.3V logic levels. It works well for my bones.
2. It would be highly appreciated if you guide us on the complete
3. Our goal was to boot the kernel from UART1 and see it on minicom ,
To use UART1 for Linux, simply set your "console=" boot arg to be ttyO1
instead of ttyO0, then spawn a getty (or similar login manager) on
ttyO1. You may also need to ensure /etc/securetty (or similar) allows
use of that tty within Linux.
Can you copy the circuitry used on the BeagleBoard-xm? It is on page 8 of the schematic. The device runs at 3.3V and connect it direct to the expansion headers. Very simple to do. You do not need the level shifter because 3.3V is what the board uses.
