Dear All
Does someone have the stackup of the BeagleBone PCB? I couldn't find
it on the hardware design page and it would help many people who want
to do their own design.
Dear All
I will post it for you in the next day or so.
The layer stackup is already posted. It is included in PCB Files ZIP file. It is in the form of a PDF file, beaglebone_revC1_PDF.zip.
http://circuitco.com/support/index.php?title=BeagleBone#Hardware_Files
I get a kick out of those “Guidelines”. They are just that, guidelines. One of the key functions of a PCB is to control the impedance of a signal, something that is done by a combination of the trace width, length, and the distance to ground, the “air gap”. That is the key aspect of the stack-up and it varies from PCB shop to PCB shop depending on their processes and the equipment they use.
These models they mention again, make for a nice document. Yes the BeagleBone layout has good EMC, it did pass FCC part 15 and CE. There was no model used in the design of the BeagleBone. In fact, I have never heard of any PCB guy relying on models to lay out a board. Models do not comprehend things like power planes, cross talk, signal integrity, trace length, impedance, and length matching that are dictated by things like, schematic and mechanical restrictions.
The six layer design was dictated by needing enough layers to make all the connections. Needing the DDR signals to run over a ground plane and all signals to me matched lengths. USB impedance to meet the USB specification and making sure the signals did not cross over breaks in the power planes so as to pick up noise. LCD signal to be matched lengths so as not to create any skewing of the data. Having enough ground planes to pull the heat off the various devices. Ensuring that the power connections were large enough to connect to all pints and provide proper isolation between the various rails as needed. And making sure it all fit in the constraints of the board size.
I hope I was able to answer your question. One other side note. The board was not autorouted and it was done out by a guy with over 30 years of experience.
Hi Gerald,
Regarding PCB stackup, I loooked at the layer stackup defined in the BBB Altium PCB file.
I can see that:
How much plating is there on top and bottom layer?
Is 2.4 mils just copper or copper + plating?
I am trying to do some pre-layout sim for a BBB and a cape and I need to model the PCB.
Thanks in advance
Antbert
AnBer:
Normal PCB manufacturing process is to to use 1.2 mil copper
(also known as 1/2 ounce copper) on the inner layers
and a subtractive process (etching) to remove unwanted copper.
Outer layers are originally (the same) 1.2 mil copper then etched to provide the
desired features, then all the through holes for vias
are drilled through the stack, and an additional 1.2 mils of copper plated
on top of the original copper. This as well provides the copper plating inside
the drilled holes to form the via connections between layers.
So, the outer layers are 1.2 mils of rolled, dead soft copper plus another
1.2 mils of hard plated copper for a total of 2.4 mils (also known as 1 Ounce copper.)
— Graham
Hi Gerald,
I can see that:
- Top and bottom signal layers are 2.4 mil copper
- Inner layers (signal and power planes) are 1.2 mil copper
Is 2.4 mils just copper or copper + plating?I am trying to do some pre-layout sim for a BBB and a cape and I need to model the PCB.
Numbers in Altium refer to the final thickness which is used for impedance calculations.
John
Graham, John,
Thanks for the comments.
I finally found the layer stackup document for the BBB (revB4).
Strangely enough I could not find it in a readable format from:
http://elinux.org/Beagleboard:BeagleBoneBlack#Hardware_Files
I found it at the below page for an older BBB version:
https://github.com/SweedJesus/Beaglebone-Black-Stuff/tree/master/Docs/Beaglebone%20Black/BBB_PCB/BeagleBone_Black_RevB4_MFG
From the beaglebone_black_RevB4_NOLOGO_FAB.pdf enclosed file looking at the different info I can see:
Am I missing something in the oz to mils conversion?
Even if the Layer stack-up table from the .pdf file says that all dimension are in INCHES it looks like that the that it is oz and mils instead.
In both document the total board height is 62 mils.
AnBer
BeagleBone_Black_RevB4_FAB.pdf (24.9 KB)
AnBer:
I realize that it is in writing on the Internet, therefore it must be true.
But, the board as documented by “SweedJesus” is a non-standard
and unusual construction for PC boards, therefore there is a slight
chance that the information is wrong.
I would suggest that you use the dimensions suggested by myself
and John.
Please also realize that the dimensions and parameters in building
PC boards that affect your E&M modeling are typically +/- 10 percent,
sometimes +/- 20 percent, so do not spend a lot of time chasing
decimal places for the input to your modeling program.
— Graham
Hello gerald/forum
I had a look at BeagleBone_Black_RevB4_FAB.pdf
in there i can see for the 50 ohm impedance signal with a track width of 4.75 on external layers and 5.25 on internal layers
so does that mean power supply lines are also 4.75 track width on external layer and 5.25 on internal layer
Regards
Nick
Power supply lines? Power supplies are power planes with a connection from the pad to the plane using a via.
Power is supplied via power planes which are on layers 2 and 5.
John
I guess I should have scrolled up before answering this post.
John
