I can connect to the BeagleV-Fire but I cannot update/upgrade the board so far. Gateware can be updated via the command with sudo only and without the . pre-period for the command:
cd /usr/share/beagleboard/gateware
. ./change-gateware.sh default
So, the command that worked for me is this one:
sudo ./change-gateware.sh default
Anyway, what can I do if anything to get back to working order. I have tried with the online program but it is giving me these ideas:
Hit:2 http://ports.ubuntu.com lunar InRelease
Hit:4 http://ports.ubuntu.com lunar-security InRelease
Hit:5 http://ports.ubuntu.com lunar-updates InRelease
Ign:1 https://repos.rcn-ee.com/debian-riscv64 lunar InRelease
Ign:3 https://debian.beagleboard.org/riscv64 lunar InRelease
Err:1 https://repos.rcn-ee.com/debian-riscv64 lunar InRelease
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification.
Err:3 https://debian.beagleboard.org/riscv64 lunar InRelease
Reading package lists... Done
E: Release file for http://ports.ubuntu.com/dists/lunar-security/InRelease is not valid yet (invalid for another 127d 20h 13min 19s). Updates for this repository will not be applied.
E: Release file for http://ports.ubuntu.com/dists/lunar-updates/InRelease is not valid yet (invalid for another 127d 22h 40min 26s). Updates for this repository will not be applied.
Please send guidance…
Have you tried any of the suggestions you get if you Google “apt The certificate is NOT trusted”?
Alternate gateware can be uploaded to the Beagle manually; all is not lost…
I am not certain that an image reload via the procedure here is enough to also reprogram the FPGA part.
( scroll down to the eMMC part )
I’m sure @RobertCNelson has some insight here…
@RobertCNelson ,
How would I allow the clock to sync? With rsync or some way I am not familiar with currently?
Update…
Okay. I think the 128 Days to sync is excessive but I can wait if need be…
By default, time is kept in sync by systemd-timesyncd, the normal answer is to just plug in ethernet and as long as you have it working network it’ll sync right up..
That’s stating your clock is 128+ days out of date..
Sir,
how do I make the clock up-to-date?
P.S. Could it be that the PCIe overlay is loaded?
/proc/device-tree/chosen/overlays/
├── name
├── PCIE-M2-GATEWARE
└── ROBOTICS-CAPE-GATEWARE
1 directory, 3 files
It normally happens automatically, once you have some kind of network connection…
(NTP)
I have a network connection. It is not happening…
I am getting an error in certificate verification error when I use apt update.
Yes, it’s still related to your clock being off by +128 days.
Certificate verification relies on your clock being right.
You might be able to help it along if you try:
sudo date -s '2024-06-23 12:34:56'
date --version…
date (GNU coreutils) 9.1
Okay. got it. Thank you, I will try it.
P.S. I tried the command. It shows now: Could not connect to repos.rcn-ee.com:80. Connection Timed Out. Hmm…I will keep searching for ideas. If you know of another way, please let me know.
What does it say if you do an ip addr?
You can also try and ping something…
Update
@lranders and @RobertCNelson …
Okay. I had to do what @lranders stated as the command and then get_kernel_update script and then update/upgrade via apt.
@lranders ,
Hey there once more or again…
ip a states my IP Address as USB and eth0.
P.S. I checked the software status of :9090 and updated via ssh instead. Anyway, thank you.
Update (Again)!
Okay…so I ran a command to find failed services…
â—Ź motd-news.service loaded failed failed Message of the Day
is this an issue?
Would you mind posting the entire output from ip addr?
Hello @lranders ,
I would rather not. I am sorry. It is just my IP Address for the board.
It’s really not dangerous. If you’re dubious, you can mask out the MAC.
( it might show us what’s going on )
Oh.
I am sorry. It is too late. I need to flash another image. I broke it somehow…
I think the update and upgrade, when it worked and without updating the gateware image via the command sudo apt install bbb.io-gateware, created a bad image and along with the get_kernel_update script.
Blah…
P.S. Sorry to bother you during my trials.
@lranders ,
This seems to be an ongoing issue with my board, e.g. I checked past circumstances…
imx219 1-0010: failed to read chip id 219
P.S. Okay…I will show it off:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:04:a3:10:96:dc brd ff:ff:ff:ff:ff:ff
inet 192.168.0.57/24 metric 1024 brd 192.168.0.255 scope global dynamic eth0
valid_lft 172705sec preferred_lft 172705sec
inet6 fe80::204:a3ff:fe10:96dc/64 scope link
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 00:04:a3:10:96:db brd ff:ff:ff:ff:ff:ff
altname end0
4: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1000
link/tunnel6 :: brd :: permaddr 52a9:aff8:998c::
5: usb0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:04:a3:10:96:df brd ff:ff:ff:ff:ff:ff
inet 192.168.7.2/24 brd 192.168.7.255 scope global usb0
inet6 fe80::204:a3ff:fe10:96df/64 scope link
6: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:7b:28:58:ab brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
Alrighty; nothing out of the ordinary there.
You can ignore the imx219 error; it’s because you got no camera connected.
