Here are the exact serial, and model with info of the SD card I used
Thru the serial port, select:
microSD (debug)
This enables earlycon=ns16550a,mmio32,0x02800000 and removes quiet from the append line…
FWIW, I was using a Patriot 32 GB class 10 u1 card, which wasn’t working out. I am currently writing the latest image from bb-imager (dated 06-26) to a Sandisk 32 GB card and will edit the post with my results. Edit: and I am now also booted - currently logged into ssh via the local usb-c connection. The Sandisk 32 GB card did the trick. I wish I had known about the microsd card sensitivity but hopefully this thread will help others - thanks to everyone for the help.
thinking this issue is something that needs to be resolved…
I am basically there, with:
- the image recomanded from the quick start guide
- the recommanded SD card from the users above from Amazon flashed via balena
- changed username and pw and removed the #
+tried ssh via putty.
but so far no sucess.
Trying now different images…
hooked up a uart connection and i am recieving the following message:
i used the latest image from: Latest Software Images - BeagleBoard
and i have no idea how to resolve it. please advice
So all of us are on the same page. Log the entire boot, using gtk term setup a log file first then power up the board.
Also, try using to official beagle imager and set the user with that.
I am using the same image so I know for fact it works on our boards.
fred@bby2:~$ uname -a
Linux bby2 6.1.83-ti-arm64-r63 #1bookworm SMP PREEMPT_DYNAMIC Wed Jul 10 23:00:56 UTC 2024 aarch64 GNU/Linux
Unfortunately BB imager didnt work for me. neither on my old windows pc or my new one with windows 11, so i sticked with balena, it never started the installation process after clicking .exe.
Other option i can try is with raspberry pi imager that was also mentioned anywhere in this thread, havent tried that yet.
Update: the below output from putty is from the Raspberry Pi imager.
Update#2: Also tried to switch the SD card to another Beagley-AI board, basically recieve the same output from the serial monitor.
Beagley-AI.txt (8,4 KB)
mmc: -110 This means when jumping from u-boot to the kernel, Linux was not able to reinitialize the microSD…
Managed to get it work.
How to:
i used a Raspberry Pi 5, & installed the BB imager onto it, to flash some SD cards.
Then i used a different SD-Card as the recommanded one in this thread:
Amazon
Further i was wondering why there was no screen. The uart connection worked well.
I figured out that the raspberry pi is working with them without a problem, but the beagley-ai ist not. I tested a total of 3 displays of which 2 old displays with HDMI, a BenQ monitor and Alienware did not respond, only the most recent one i purchased was a quiet cheap one from Prechen that worked and instantly showed a screen.
Now the beagley-ai is working as wished in the standalone config.
Does BeagleY-AI support 64gb microsd cards?
yes
My BeagleY-AI is booting twice without giving me a window to ssh using the initial credentials that I wrote to sysconf.txt. The sysconf.txt file ends up getting restored to its original state. I am unable to login for the first time. Please help
What image are you using? Need a link so we can be on the same page.
I was using a windows host. Accessing the serial port over Putty instead of using ssh over powershell helped me fix the issue.
