Got my BBB in today. Nice.
I am able to connect to it via the serial port header but can not connect via USB?
I tried installing the BONE_D64.exe drivers but all came back with red X’s. I rebooted
the P.C. and tried again. Same results.
The serial connection is via Putty. and that works. I tried using putty
via SSH to 192.168.7.2 but all I get is a blank screen which eventually
times out…
Someone asked me today why am I fooling around with a BBB when
I can get the “real” thing on a P.C. or VM. I told him there are things
a BBB can do like add on capes, peripheral I/O that you can’t really
do with a VM which if you could do it you would have to leave on 24/7
where as the BBB is a cute thing that once setup can run headless
at very little current. I just like it.
So, any help would be appreciated. Thanks.
As much as I miss pulling hair’s out I have not dug all my stuff out you really need all the toys like serial cable’s Routers, switches and for me JTAG if you want to be serious it doesn’t take up much space. Start with quick start guide and keep your focus on one problem your juggling approaches and reply with details to those offering help like previous responder. Best of luck
