I am using the Beagle bone black with debian to run the application, To flash the kernel images on eMMC I used the minicom in Ubuntu environment.
I am using the TFTP protocol to transfer uboot and kernel images, onto BBB RAM. From RAM using the “dd” command I am flashing it into the eMMC, the sequence of flashing is as follows
Flashing MLO
Flashing uboot
Creating rootfile system with the mkfs.ext4 -L rootfs command.
Copying kernel images over ethernet throught NFS server using “rsync”
The problem currently I am facing with the multiple flashing, after flashing when BBB restarted it will stuck at uboot prompt only, kernel will not bootup.
I am attaching flashing session log for the reference, Any help will be useful.
Nitin
kernelBoot_Error_Log.txt (38.9 KB)
