[ 1.760395] pinctrl-single 44e10800.pinmux: pin PIN108 already requested by ocp:A15_pinmux; cannot claim for 0-0070
[ 1.770982] pinctrl-single 44e10800.pinmux: pin-108 (0-0070) status -22
[ 1.777665] pinctrl-single 44e10800.pinmux: could not request pin 108 (PIN108) from group nxp_hdmi_bonelt_pins on device pinctrl-single
[ 1.790007] tda998x 0-0070: Error applying setting, reverse things back
[ 1.796746] tda998x: probe of 0-0070 failed with error -22
Thank you. That worked. I’ll add it to my building up a beagle document. Is there a way so that apt upgrade does this automatically? Either tests for kernel version and won’t run until it’s upgraded or does it automatically?
On the 19th of September you had posted to someone else having the same problem to apt update and upgrade and reboot.
This bit of not upgrading anymore? I’m puzzled why the instructions for the BBB keep changing. How many books have now been made useless by stopping bb-cape-overlays? How many 10’s of thousands of man hours are now being tossed in the trash or wasted looking for solutions?
So is
sudo apt-mark hold bb-cape-overlays
supposed to be done before sudo apt update or before sudo apt upgrade? Or after? Or does the kernel need to be updated first?
It was after reflashing the 16Gb MicroSD for the 7th time, backing up one operation each time, before I decided I wasn’t doing anything wrong and asked for help.
And again, why isn’t there something in the update or upgrade script that either warns or announces the issue. Why doesn’t apt upgrade also update the kernel with a request as to which one we’d like? That would have prevented this problem.
it’s an ABI problem… The kernel keeps changing, over time, I’ve “dropped” support for v4.1.x, v4.4.x, and v4.9.x from bb-cape-overlays… Most users didn’t notice this as it was just assuming v4.14.x+ drivers… However after v5.9.x was released there was a major ABI change in mainline effectually breaking “all” pinmux’ing…
This effectually stopped bb-cape-overlay from working on 5.9.x+ built kernels.
My workaround is to “move”
to kernel specific versions:
So “while” this effectually ends the “bb-cape-overlay” package as built-binary, it’s source is still much alive.
My mistake was when back-porting other device tree fixes into the bb-cape-overlay project i broke our older v4.19.x kernel on https://beagleboard.org/latest-images
Debian GNU/Linux 10 beaglebone ttyS0
BeagleBoard.org Debian Buster IoT Image 2020-04-06
Support: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
beaglebone login: root
Password:
Last login: Mon Apr 6 13:27:04 UTC 2020 on ttyS0
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@beaglebone:~# apt update ; apt install bbb.io-kernel-4.19-ti-am335x
Get:1 http://deb.debian.org/debian buster InRelease [122 kB]
Get:2 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:3 http://deb.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:4 http://repos.rcn-ee.com/debian buster InRelease [3,078 B]
Get:5 http://deb.debian.org/debian buster/contrib armhf Packages [40.1 kB]
Get:6 http://deb.debian.org/debian buster/non-free armhf Packages [62.1 kB]
Get:7 http://deb.debian.org/debian buster/main armhf Packages [7,698 kB]
Get:8 http://deb.debian.org/debian buster-updates/main armhf Packages [14.4 kB]
Get:9 http://deb.debian.org/debian-security buster/updates/main armhf Packages [300 kB]
Get:10 http://repos.rcn-ee.com/debian buster/main armhf Packages [2,073 kB]
Fetched 10.4 MB in 1min 7s (156 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
145 packages can be upgraded. Run 'apt list --upgradable' to see them.
The following additional packages will be installed:
bb-u-boot-am335x-evm bbb.io-kernel-tasks libpruio-modules-4.19.94-ti-r68
linux-image-4.19.94-ti-r68 ti-sgx-ti335x-modules-4.19.94-ti-r68
The following NEW packages will be installed:
bb-u-boot-am335x-evm bbb.io-kernel-4.19-ti-am335x bbb.io-kernel-tasks
libpruio-modules-4.19.94-ti-r68 linux-image-4.19.94-ti-r68
0 upgraded, 6 newly installed, 0 to remove and 145 not upgraded.
Need to get 29.0 MB of archives.
After this operation, 50.1 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Unpacking bb-u-boot-am335x-evm (2019.04.20210831.0-0~buster+20210831) ...
Setting up bbb.io-kernel-tasks (1.20211014.2-0~buster+20211014) ...
Setting up bbb.io-kernel-4.19-ti-am335x (1.20211014.2-0~buster+20211014) ...
Setting up ti-sgx-ti335x-modules-4.19.94-ti-r68 (1buster) ...
Setting up bb-u-boot-am335x-evm (2019.04.20210831.0-0~buster+20210831) ...
Setting up libpruio-modules-4.19.94-ti-r68 (1buster) ...
root@beaglebone:~# apt upgrade
Calculating upgrade... Done
gt libbrotli1 libconfig9 libusbgx
The following packages have been kept back:
c9-core-installer
The following packages will be upgraded:
apt apt-utils avahi-daemon avahi-utils base-files bb-bbai-firmware
bb-cape-overlays bb-customizations bb-node-red-installer bb-usb-gadgets
bb-wl18xx-firmware bind9-host bluetooth bluez bone101 ca-certificates
connman curl dbus debconf debconf-i18n debian-archive-keyring
device-tree-compiler distro-info-data dnsmasq dnsmasq-base file git git-man
groff-base hostapd iproute2 ipumm-dra7xx-installer iputils-ping
isc-dhcp-client isc-dhcp-common klibc-utils libapt-inst2.0 libapt-pkg5.0
libavahi-client3 libavahi-common-data libavahi-common3 libavahi-core7
libbind9-161 libbluetooth3 libbsd0 libc-ares2 libcpupower1 libcurl3-gnutls
libcurl4 libdbus-1-3 libdbus-1-dev libdns-export1104 libdns1104 libfreetype6
libgcrypt20 libglib2.0-0 libgnutls30 libgssapi-krb5-2 libhogweed4
libisc-export1100 libisc1100 libisccc161 libisccfg163 libjpeg62-turbo
libjs-jquery libjson-c3 libk5crypto3 libklibc libkrb5-3 libkrb5support0
libldap-2.4-2 libldap-common liblwres161 liblz4-1 libmagic-mgc libmagic1
libnettle6 libnginx-mod-http-auth-pam libnginx-mod-http-dav-ext
libnginx-mod-http-echo libnginx-mod-http-geoip
libnginx-mod-http-image-filter libnginx-mod-http-subs-filter
libnginx-mod-http-upstream-fair libnginx-mod-http-xslt-filter
libnginx-mod-mail libnginx-mod-stream libnode-dev libnode64 libnss-systemd
libp11-kit0 libpam-systemd libperl5.28 libpython3.7 libpython3.7-dev
libpython3.7-minimal libpython3.7-stdlib librobotcontrol libsqlite3-0
libssl-dev libssl1.1 libsystemd0 libtiff5 libudev1 libuv1 libuv1-dev
libwebp6 libx11-6 libx11-data libxml2 libzstd1 linux-cpupower linux-libc-dev
mjpg-streamer nginx nginx-common nginx-full node-ansi-regex
node-hosted-git-info node-ini node-minimist node-tar node-y18n
node-yargs-parser nodejs nodejs-doc npm openssl perl perl-base
perl-modules-5.28 python3.7 python3.7-dev python3.7-minimal screen sudo
systemd systemd-sysv ti-pru-cgt-installer tzdata udev vpdma-dra7xx-installer
wpasupplicant
144 upgraded, 4 newly installed, 0 to remove and 1 not upgraded.
Need to get 289 MB of archives.
After this operation, 99.8 MB of additional disk space will be used.
Processing triggers for ca-certificates (20200601~deb10u2) ...
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
root@beaglebone:~# reboot
Password:
Last login: Thu Oct 14 18:22:45 UTC 2021 on ttyS0
root@beaglebone:~# uname -r
4.19.94-ti-r68
Video/etc all still work…
Do i need to document these:
root@beaglebone:~# apt-cache search bbb.io
bbb.io-kernel-4.19-ti - BeagleBoard.org 4.19-ti
bbb.io-kernel-4.19-ti-am335x - BeagleBoard.org 4.19-ti for am335x
bbb.io-kernel-4.19-ti-am57xx - BeagleBoard.org 4.19-ti for am57xx
bbb.io-kernel-4.19-ti-rt - BeagleBoard.org 4.19-ti-rt
bbb.io-kernel-4.19-ti-rt-am335x - BeagleBoard.org 4.19-ti-rt for am335x
bbb.io-kernel-4.19-ti-rt-am57xx - BeagleBoard.org 4.19-ti-rt for am57xx
bbb.io-kernel-5.10-ti - BeagleBoard.org 5.10-ti
bbb.io-kernel-5.10-ti-am335x - BeagleBoard.org 5.10-ti for am335x
bbb.io-kernel-5.10-ti-am57xx - BeagleBoard.org 5.10-ti for am57xx
bbb.io-kernel-5.10-ti-rt - BeagleBoard.org 5.10-ti-rt
bbb.io-kernel-5.10-ti-rt-am335x - BeagleBoard.org 5.10-ti-rt for am335x
bbb.io-kernel-5.10-ti-rt-am57xx - BeagleBoard.org 5.10-ti-rt for am57xx
bbb.io-kernel-5.4-ti - BeagleBoard.org 5.4-ti
bbb.io-kernel-5.4-ti-am335x - BeagleBoard.org 5.4-ti for am335x
bbb.io-kernel-5.4-ti-am57xx - BeagleBoard.org 5.4-ti for am57xx
bbb.io-kernel-5.4-ti-rt - BeagleBoard.org 5.4-ti-rt
bbb.io-kernel-5.4-ti-rt-am335x - BeagleBoard.org 5.4-ti-rt for am335x
bbb.io-kernel-5.4-ti-rt-am57xx - BeagleBoard.org 5.4-ti-rt for am57xx
bbb.io-kernel-tasks - BeagleBoard.org Kernel Branches
