Error -101 whilst initialising SD Card
this seems to be a common issue.
Nonetheless, I could not find any suitable fix.
But first things first.
I have followed the guidelines to assemble a bootable Linux image that I could deploy to an SD card:
  • Bootloader and firmware: using the build.sh script from this repo and deployed following the guidelines
  • Kernel, device tree, overlays and extlinux.conf: following the guidelines
  • rootfs: following the guidelines
I’ve flashed the first two to the BOOT partition and the last to the rootfs.
Then, I inserted the SD Card and powered up the board while pressing the BOOT button, and this is the result I get:
U-Boot SPL 2021.01-gea96725b (Sep 02 2023 - 15:57:35 +0000)
Model: BeagleBoard.org BeagleBone AI-64 R5
EEPROM not available at 0x50, trying to read at 0x51
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0008 ‘8.6.3–v08.06.03 (Chill Capybar’)
Trying to boot from MMC1
init_env from device 17 not supported!
Starting ATF on ARM64 core…
NOTICE: BL31: v2.9(release):v2.9.0
NOTICE: BL31: Built : 15:57:35, Sep 2 2023
I/TC:
I/TC: OP-TEE version: 3.22.0 (gcc version 10.2.1 20210110 (Debian 10.2.1-6)) #1 Sat Sep 2 15:57:35 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 ‘8.6.3–v08.06.03 (Chill Capybar’)
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
Model: Texas Instruments K3 J721E SoC
ti_i2c_eeprom_am6_parse_record: Ignoring record id 17
U-Boot 2021.01-gea96725b (Sep 02 2023 - 15:57:35 +0000)
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT… *** Warning - bad CRC, using default environment
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
board_name=[BBONEAI-64-B0-] …
name_fdt=[k3-j721e-beagleboneai64.dtb] …
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
171 bytes read in 8 ms (20.5 KiB/s)
1:Linux microSD
Retrieving file: /Image
29323776 bytes read in 1222 ms (22.9 MiB/s)
append: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0
Retrieving file: /k3-j721e-beagleboneai64.dtb
205872 bytes read in 16 ms (12.3 MiB/s)
Loading Device Tree to 000000008ffca000, end 000000008ffff42f … OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.162 (zmp-ubuntu@zmp-ubuntu-qemu) (aarch64-linux-gnu-gcc (Ubuntu 12.3.0-1ubuntu1~23.04) 12.3.0, GNU ld (GNU Binutils for Ubuntu) 2.40) #1 SMP Thu Oct 12 21:38:22 WEST 2023
[ 0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options ‘’)
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 560 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@fb000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@fb800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fcffffff]
[ 0.000000] node 0: [mem 0x00000000fd000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 144 MiB at 0x0000000095800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s92952 r8192 d29928 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000091800000-0x0000000095800000] (64MB)
[ 0.000000] Memory: 2078756K/4194304K available (17088K kernel code, 2268K rwdata, 5356K rodata, 3776K init, 723K bss, 1968092K reserved, 147456K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @890800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008900d0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008900e0000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008526] Console: colour dummy device 80x25
[ 0.013092] Calibrating delay loop (skipped), value calculated using timer frequency… 400.00 BogoMIPS (lpj=800000)
[ 0.023762] pid_max: default: 32768 minimum: 301
[ 0.028617] LSM: Security Framework initializing
[ 0.033355] Yama: becoming mindful.
[ 0.036982] AppArmor: AppArmor initialized
[ 0.041168] TOMOYO Linux initialized
[ 0.044889] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.052467] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.061578] rcu: Hierarchical SRCU implementation.
[ 0.067104] Platform MSI: msi-controller@1820000 domain created
[ 0.073563] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.082946] EFI services will not be available.
[ 0.087834] smp: Bringing up secondary CPUs …
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.101150] Detected PIPT I-cache on CPU1
[ 0.101174] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.101184] GICv3: CPU1: using allocated LPI pending table @0x00000008900f0000
[ 0.101219] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.101277] smp: Brought up 1 node, 2 CPUs
[ 0.130618] SMP: Total of 2 processors activated.
[ 0.135421] CPU features: detected: 32-bit EL0 Support
[ 0.140668] CPU features: detected: CRC32 instructions
[ 0.145916] CPU features: detected: 32-bit EL1 Support
[ 0.170595] CPU: All CPU(s) started at EL2
[ 0.174823] alternatives: patching kernel code
[ 0.180047] devtmpfs: initialized
[ 0.195574] KASLR disabled due to lack of seed
[ 0.200268] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.210251] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.219285] pinctrl core: initialized pinctrl subsystem
[ 0.224991] DMI not present or invalid.
[ 0.229298] NET: Registered protocol family 16
[ 0.234574] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.241880] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.249932] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.258047] audit: initializing netlink subsys (disabled)
[ 0.263742] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
[ 0.264029] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.271662] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.277887] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.284023] thermal_sys: Registered thermal governor ‘user_space’
[ 0.290157] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.297041] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.310684] ASID allocator initialised with 65536 entries
[ 0.340880] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.347738] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.354591] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.361438] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.369261] cryptd: max_cpu_qlen set to 1000
[ 0.375373] raid6: skip pq benchmark and using algorithm neonx8
[ 0.381437] raid6: using neon recovery algorithm
[ 0.386657] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.395476] vsys_3v3: supplied by evm_12v0
[ 0.399835] vsys_5v0: supplied by evm_12v0
[ 0.404450] iommu: Default domain type: Translated
[ 0.409731] SCSI subsystem initialized
[ 0.413664] usbcore: registered new interface driver usbfs
[ 0.419304] usbcore: registered new interface driver hub
[ 0.424743] usbcore: registered new device driver usb
[ 0.430319] mc: Linux media interface: v0.10
[ 0.434697] videodev: Linux video capture interface: v2.00
[ 0.440339] pps_core: LinuxPPS API ver. 1 registered
[ 0.445410] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.454747] PTP clock support registered
[ 0.458766] EDAC MC: Ver: 3.0.0
[ 0.462999] NetLabel: Initializing
[ 0.466471] NetLabel: domain hash size = 128
[ 0.470924] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.476731] NetLabel: unlabeled traffic allowed by default
[ 0.482774] clocksource: Switched to clocksource arch_sys_counter
[ 0.803009] VFS: Disk quotas dquot_6.6.0
[ 0.807067] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.814179] FS-Cache: Loaded
[ 0.817325] CacheFiles: Loaded
[ 0.820727] AppArmor: AppArmor Filesystem Enabled
[ 0.829086] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.835429] NET: Registered protocol family 2
[ 0.840190] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.848871] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.857879] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.866317] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.874071] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.881018] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.888702] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.895638] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.903079] NET: Registered protocol family 1
[ 0.907984] RPC: Registered named UNIX socket transport module.
[ 0.914049] RPC: Registered udp transport module.
[ 0.918854] RPC: Registered tcp transport module.
[ 0.923658] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.930239] NET: Registered protocol family 44
[ 0.934784] PCI: CLS 0 bytes, default 64
[ 0.939254] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.947937] kvm [1]: IPA Size Limit: 44 bits
[ 0.952678] kvm [1]: vgic-v2@6f020000
[ 0.956440] kvm [1]: GIC system register CPU interface enabled
[ 0.962437] kvm [1]: vgic interrupt IRQ9
[ 0.966507] kvm [1]: Hyp mode initialized successfully
[ 0.973995] Initialise system trusted keyrings
[ 0.978634] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.987414] zbud: loaded
[ 0.991095] NFS: Registering the id_resolver key type
[ 0.996311] Key type id_resolver registered
[ 1.000582] Key type id_legacy registered
[ 1.004724] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.011572] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.019142] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 1.026902] fuse: init (API version 7.32)
[ 1.051046] xor: measuring software checksum speed
[ 1.057211] 8regs : 7799 MB/sec
[ 1.062745] 32regs : 9061 MB/sec
[ 1.068416] arm64_neon : 8044 MB/sec
[ 1.072863] xor: using function: 32regs (9061 MB/sec)
[ 1.078026] Key type asymmetric registered
[ 1.082213] Asymmetric key parser ‘x509’ registered
[ 1.087217] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 1.094850] io scheduler mq-deadline registered
[ 1.101113] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 1.107371] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 1.116706] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 1.123139] debugfs: Directory ‘31010000.pat’ with parent ‘regmap’ already present!
[ 1.131167] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 1.137597] debugfs: Directory ‘31011000.pat’ with parent ‘regmap’ already present!
[ 1.145547] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 1.151968] debugfs: Directory ‘31012000.pat’ with parent ‘regmap’ already present!
[ 1.159943] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 1.166267] debugfs: Directory ‘31013000.pat’ with parent ‘regmap’ already present!
[ 1.174230] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 1.180564] debugfs: Directory ‘31014000.pat’ with parent ‘regmap’ already present!
[ 1.190551] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 1.199307] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 1.207520] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 1.214564] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 1.223082] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 1.236126] brd: module loaded
[ 1.366819] loop: module loaded
[ 1.370738] megasas: 07.714.04.00-rc1
[ 1.377186] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.383621] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.389709] sky2: driver version 1.30
[ 1.394127] VFIO - User Level meta-driver version: 0.3
[ 1.399898] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.406618] ehci-pci: EHCI PCI platform driver
[ 1.411507] usbcore: registered new interface driver uas
[ 1.416965] usbcore: registered new interface driver usb-storage
[ 1.423890] i2c /dev entries driver
[ 1.427588] Driver for 1-wire Dallas network protocol.
[ 1.432867] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[ 1.439916] sdhci: Secure Digital Host Controller Interface driver
[ 1.446234] sdhci: Copyright(c) Pierre Ossman
[ 1.450872] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.459163] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.465521] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 1.472272] hid: raw HID events driver (C) Jiri Kosina
[ 1.477629] usbcore: registered new interface driver usbhid
[ 1.483323] usbhid: USB HID core driver
[ 1.487724] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 1.492284] optee: revision 3.22 (001ace66)
[ 1.508704] optee: dynamic shared memory is enabled
[ 1.518177] optee: initialized driver
[ 1.523081] drop_monitor: Initializing network drop monitor service
[ 1.529879] NET: Registered protocol family 10
[ 1.536005] Segment Routing with IPv6
[ 1.539803] mip6: Mobile IPv6
[ 1.542841] NET: Registered protocol family 17
[ 1.547490] Key type dns_resolver registered
[ 1.551879] mpls_gso: MPLS GSO support
[ 1.555903] registered taskstats version 1
[ 1.560091] Loading compiled-in X.509 certificates
[ 1.565056] zswap: loaded using pool lzo/zbud
[ 1.569641] Key type .fscrypt registered
[ 1.573678] Key type fscrypt-provisioning registered
[ 1.582552] Btrfs loaded, crc32c=crc32c-generic
[ 1.587271] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.601140] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 ‘8.6.3–v08.06.03 (Chill Capybar’)
[ 1.661768] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 1.667962] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.674468] at24 2-0050: supply vcc not found, using dummy regulator
[ 1.702913] at24 2-0050: 512 byte 24c04 EEPROM, writable, 1 bytes/write
[ 1.709707] omap_i2c 42120000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.716012] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.722748] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.729008] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.735170] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
[ 1.741607] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.751590] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.760406] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.770284] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.794861] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.802530] j721e-pcie 2910000.pcie: IO 0x0018001000…0x0018010fff → 0x0018001000
[ 1.810807] j721e-pcie 2910000.pcie: MEM 0x0018011000…0x001fffffff → 0x0018011000
[ 1.819084] j721e-pcie 2910000.pcie: IB MEM 0x0000000000…0xffffffffffff → 0x0000000000
[ 1.828476] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 1.838364] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.845125] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.854435] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 1.864591] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.871351] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.879401] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 1.888886] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 30, base_baud = 3000000) is a 8250
[ 1.897639] printk: console [ttyS2] enabled
[ 1.906077] printk: bootconsole [ns16550a0] disabled
[ 1.916606] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 31, base_baud = 3000000) is a 8250
[ 1.925616] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 32, base_baud = 3000000) is a 8250
[ 1.936658] cdns-mhdp8546 a000000.dp-bridge: Direct firmware load for cadence/mhdp8546.bin failed with error -2
[ 1.946755] cdns-mhdp8546 a000000.dp-bridge: cdns_mhdp_fw_cb: No firmware.
[ 1.956138] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 1.963305] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 1.976190] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.022778] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.031304] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.039623] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.052435] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.059642] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.065994] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.076321] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[ 2.122777] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.130333] davinci_mdio c000f00.mdio: no live phy, scanning all
[ 2.149058] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown
[ 2.156905] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown
[ 2.164719] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown
[ 2.172530] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown
[ 2.180342] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown
[ 2.188158] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown
[ 2.195970] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown
[ 2.203782] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown
[ 2.211594] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown
[ 2.219405] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown
[ 2.227217] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown
[ 2.235114] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown
[ 2.243012] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown
[ 2.250910] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown
[ 2.258811] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown
[ 2.266709] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown
[ 2.274606] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown
[ 2.282503] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown
[ 2.290400] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown
[ 2.298297] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown
[ 2.306194] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown
[ 2.314093] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown
[ 2.321990] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown
[ 2.329888] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown
[ 2.337785] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown
[ 2.345682] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown
[ 2.353579] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown
[ 2.361477] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown
[ 2.369374] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown
[ 2.377272] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown
[ 2.385170] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown
[ 2.393066] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown
[ 2.401032] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[ 2.413711] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[ 2.427235] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 2.439078] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.444587] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.452333] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 2.461722] xhci-hcd xhci-hcd.0.auto: irq 232, io mem 0x06410000
[ 2.467905] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.476157] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.483369] usb usb1: Product: xHCI Host Controller
[ 2.488237] usb usb1: Manufacturer: Linux 5.10.162 xhci-hcd
[ 2.493793] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.498901] hub 1-0:1.0: USB hub found
[ 2.502653] hub 1-0:1.0: 1 port detected
[ 2.506730] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.512212] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 2.519857] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 2.526413] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.534549] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 2.542795] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.549999] usb usb2: Product: xHCI Host Controller
[ 2.554863] usb usb2: Manufacturer: Linux 5.10.162 xhci-hcd
[ 2.560430] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.565496] hub 2-0:1.0: USB hub found
[ 2.569250] hub 2-0:1.0: 1 port detected
[ 2.676181] mmc0: CQHCI version 5.10
[ 2.685047] gpio gpiochip2: gpio-line-names is length 37 but should be at most length 36
[ 2.693950] vdd_mmc1: supplied by vsys_3v3
[ 2.699080] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 2.705956] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 2.712799] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 2.715377] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.719648] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 2.733647] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 2.743988] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.751499] j721e-pcie 2910000.pcie: IO 0x0018001000…0x0018010fff → 0x0018001000
[ 2.759581] j721e-pcie 2910000.pcie: MEM 0x0018011000…0x001fffffff → 0x0018011000
[ 2.762786] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 2.767662] j721e-pcie 2910000.pcie: IB MEM 0x0000000000…0xffffffffffff → 0x0000000000
[ 2.839657] mmc0: Command Queue Engine enabled
[ 2.844101] mmc0: new HS200 MMC card at address 0001
[ 2.849437] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 2.854094] mmcblk0boot0: mmc0:0001 TB2916 partition 1 4.00 MiB
[ 2.860102] mmcblk0boot1: mmc0:0001 TB2916 partition 2 4.00 MiB
[ 2.866111] mmcblk0rpmb: mmc0:0001 TB2916 partition 3 4.00 MiB, chardev (236:0)
[ 2.874431] mmcblk0: p1 p2
[ 2.927139] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 2.935307] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 2.942426] usb 1-1: SerialNumber: BC0A0841A4CD
[ 2.947414] hub 1-1:1.0: USB hub found
[ 2.951179] hub 1-1:1.0: 4 ports detected
[ 3.054796] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 3.079010] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 3.087172] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.094754] hub 2-1:1.0: USB hub found
[ 3.098520] hub 2-1:1.0: 4 ports detected
[ 3.778949] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[ 3.785212] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.790687] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[ 3.800145] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.807029] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.813022] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 3.822717] pci 0000:00:00.0: supports D1
[ 3.826715] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 3.836105] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.847806] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.854420] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.859706] pcieport 0000:00:00.0: PME: Signaling with IRQ 506
[ 3.865720] pcieport 0000:00:00.0: AER: enabled with IRQ 506
[ 3.872389] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 3.883462] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 3.898667] spi-nor spi11.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 3.905636] spi-nor: probe of spi11.0 failed with error -2
[ 3.914140] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 3.958785] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 3.967279] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 3.975601] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 3.988418] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 3.995624] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 4.001961] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 4.012354] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 4.750989] mmc1: CQHCI version 5.10
[ 4.751102] debugfs: Directory ‘pd:27’ with parent ‘pm_genpd’ already present!
[ 4.761793] debugfs: Directory ‘pd:26’ with parent ‘pm_genpd’ already present!
[ 4.770359] debugfs: Directory ‘pd:242’ with parent ‘pm_genpd’ already present!
[ 4.777691] debugfs: Directory ‘pd:241’ with parent ‘pm_genpd’ already present!
[ 4.785007] debugfs: Directory ‘pd:240’ with parent ‘pm_genpd’ already present!
[ 4.792312] debugfs: Directory ‘pd:239’ with parent ‘pm_genpd’ already present!
[ 4.800818] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.807750] of_cfs_init
[ 4.810203] of_cfs_init: OK
[ 5.817510] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 5.825259] Waiting for root device /dev/mmcblk1p2…
[ 5.880152] mmc1: error -110 whilst initialising SD card
[ 6.076693] mmc1: error -110 whilst initialising SD card
[ 6.267619] mmc1: error -110 whilst initialising SD card
[ 6.464185] mmc1: error -110 whilst initialising SD card
[ 79.773788] mmc1: error -110 whilst initialising SD card
[ 79.967272] mmc1: error -110 whilst initialising SD card
U-Boot manages to load the kernel, but fails when loading the rootfs from the SD card.
Kernel: 5.10.162
Other things I tried:
Update:
So it’s NOT just about the SD card.
I can share more details about the build if you want.
/run/media/zmp/SDCard/BOOT
|-- Image
|-- extlinux
| – extlinux.conf
|-- k3-j721e-beagleboneai64-no-shared-mem.dtb
|-- k3-j721e-beagleboneai64.dtb
|-- k3-j721e-common-proc-board.dtb
|-- k3-j721e-proc-board-tps65917.dtb
|-- k3-j721e-sk.dtb
|-- overlays
| |-- BB-I2C2-MPU6050.dtbo
| |-- BBAI64-CSI0-imx219.dtbo
| |-- BBAI64-CSI1-imx219.dtbo
| |-- BBAI64-DSI-RPi-7inch-panel.dtbo
| |-- BBAI64-P8_37-ehrpwm5_a.dtbo
| |-- BBAI64-P9_25-ehrpwm4_b.dtbo
| |-- BBORG_LOAD-00A2.dtbo
| |-- BBORG_RELAY-00A2.dtbo
| |-- BBORG_SERVO-00A2.dtbo
| |-- BONE-FAN.dtbo
| |-- BONE-I2C1.dtbo
| |-- BONE-I2C2.dtbo
| |-- BONE-I2C3.dtbo
| |-- BONE-LED_P8_03.dtbo
| |-- BONE-LED_P9_11.dtbo
| |-- BONE-PWM0.dtbo
| |-- BONE-PWM1.dtbo
| |-- BONE-PWM2.dtbo
| |-- BONE-SPI0_0.dtbo
| |-- BONE-SPI0_1.dtbo
| |-- BONE-SPI1_0.dtbo
| |-- BONE-UART1.dtbo
| |-- BONE-USB0-host.dtbo
| |-- J721E-PRU-UIO-00A0.dtbo
| |-- k3-am625-beagleplay-bcfserial-no-firmware.dtbo
| |-- k3-am625-beagleplay-csi2-ov5640.dtbo
| |-- k3-am625-beagleplay-lt-lcd185.dtbo
| |-- k3-j721e-beagleboneai64-RPi-7inch-panel.dtbo
| – robotics-cape.dtbo
|-- sysfw.itb
|-- tiboot3.bin
|-- tispl.bin
`-- u-boot.img
U-Boot SPL 2021.01-g6e056cc6 (Oct 12 2023 - 21:35:38 +0100)
SYSFW ABI: 3.1 (firmware rev 0x0015 ‘21.9.1–v2021.09a (Terrific Lla’)
TLB table from ffffc000 to 00000000
SPL: board_init_r()
spl_init
Trying to boot from MMC2
spl: mmc boot mode: fs
board_fit_image_post_process: processing image: addr=70000000, size=39864, os=arm-trusted-firmware
board_fit_image_post_process: matched image for ID 0
board_fit_image_post_process: processing image: addr=9e800000, size=395152, os=tee
board_fit_image_post_process: matched image for ID 1
board_fit_image_post_process: processing image: addr=89000000, size=217356, os=DM
board_fit_image_post_process: matched image for ID 3
board_fit_image_post_process: processing image: addr=80080000, size=164232, os=U-Boot
board_fit_image_post_process: matched image for ID 2
board_fit_image_post_process: processing image: addr=ffffffff, size=10103, os=
Unsupported OS image… Jumping nevertheless…
loaded - jumping to U-Boot…
jump_to_image_no_args: jumping to address 41010000
NOTICE: BL31: v2.5(release):577844a
NOTICE: BL31: Built : 21:34:39, Oct 12 2023
U-Boot SPL 2021.01-g6e056cc6 (Oct 12 2023 - 21:36:05 +0100)
TLB table from ffff4000 to 100000000
SPL malloc() before relocation used 0x2500 bytes (9 KB)
SPL: board_init_r()
spl_init
Jumping to U-Boot
image entry point: 0x80800000
U-Boot 2021.01-g6e056cc6 (Oct 12 2023 - 21:36:05 +0100)
SoC: J721E SR2.0
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Scanning mmc 1:1…
171 bytes read in 7 ms (23.4 KiB/s)
1:Linux microSD
29323776 bytes read in 1220 ms (22.9 MiB/s)
205872 bytes read in 15 ms (13.1 MiB/s)
Linux kernel Image start = 0x82000000 end = 0x83cc0000
Starting kernel …
[ 0.008514] Console: colour dummy device 80x25
[ 0.013078] Calibrating delay loop (skipped), value calculated using timer frequency… 400.00 BogoMIPS (lpj=800000)
[ 0.023748] pid_max: default: 32768 minimum: 301
[ 0.028599] LSM: Security Framework initializing
[ 0.033337] Yama: becoming mindful.
[ 0.036963] AppArmor: AppArmor initialized
[ 0.041148] TOMOYO Linux initialized
[ 0.044867] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.052444] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.061499] rcu: Hierarchical SRCU implementation.
[ 0.066991] Platform MSI: msi-controller@1820000 domain created
[ 0.073426] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.082803] EFI services will not be available.
[ 0.087666] smp: Bringing up secondary CPUs …
[ 0.092976] Detected PIPT I-cache on CPU1
[ 0.092996] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.093006] GICv3: CPU1: using allocated LPI pending table @0x00000008900f0000
[ 0.093040] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.093100] smp: Brought up 1 node, 2 CPUs
[ 0.122443] SMP: Total of 2 processors activated.
[ 0.127247] CPU features: detected: 32-bit EL0 Support
[ 0.132494] CPU features: detected: CRC32 instructions
[ 0.137742] CPU features: detected: 32-bit EL1 Support
[ 0.162367] CPU: All CPU(s) started at EL2
[ 0.166589] alternatives: patching kernel code
[ 0.171776] devtmpfs: initialized
[ 0.187130] KASLR disabled due to lack of seed
[ 0.191819] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.201800] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.210736] pinctrl core: initialized pinctrl subsystem
[ 0.216421] DMI not present or invalid.
[ 0.220716] NET: Registered protocol family 16
[ 0.225967] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.233271] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.241325] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.249435] audit: initializing netlink subsys (disabled)
[ 0.255120] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
[ 0.255395] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.263036] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.269261] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.275396] thermal_sys: Registered thermal governor ‘user_space’
[ 0.281530] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.288390] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.302032] ASID allocator initialised with 65536 entries
[ 0.331781] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.338639] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.345491] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.352338] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.360176] cryptd: max_cpu_qlen set to 1000
[ 0.366237] raid6: skip pq benchmark and using algorithm neonx8
[ 0.372298] raid6: using neon recovery algorithm
[ 0.377495] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.386302] vsys_3v3: supplied by evm_12v0
[ 0.390652] vsys_5v0: supplied by evm_12v0
[ 0.395234] iommu: Default domain type: Translated
[ 0.400491] SCSI subsystem initialized
[ 0.404422] usbcore: registered new interface driver usbfs
[ 0.410061] usbcore: registered new interface driver hub
[ 0.415499] usbcore: registered new device driver usb
[ 0.421058] mc: Linux media interface: v0.10
[ 0.425433] videodev: Linux video capture interface: v2.00
[ 0.431072] pps_core: LinuxPPS API ver. 1 registered
[ 0.436143] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.445480] PTP clock support registered
[ 0.449499] EDAC MC: Ver: 3.0.0
[ 0.453668] NetLabel: Initializing
[ 0.457140] NetLabel: domain hash size = 128
[ 0.461593] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.467400] NetLabel: unlabeled traffic allowed by default
[ 0.473411] clocksource: Switched to clocksource arch_sys_counter
[ 0.790926] VFS: Disk quotas dquot_6.6.0
[ 0.794987] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.802102] FS-Cache: Loaded
[ 0.805237] CacheFiles: Loaded
[ 0.808611] AppArmor: AppArmor Filesystem Enabled
[ 0.816831] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.823170] NET: Registered protocol family 2
[ 0.827913] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.836600] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.845598] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.854018] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.861755] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.868698] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.876372] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.883298] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.890743] NET: Registered protocol family 1
[ 0.895597] RPC: Registered named UNIX socket transport module.
[ 0.901652] RPC: Registered udp transport module.
[ 0.906455] RPC: Registered tcp transport module.
[ 0.911263] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.917845] NET: Registered protocol family 44
[ 0.922392] PCI: CLS 0 bytes, default 64
[ 0.926832] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.935489] kvm [1]: IPA Size Limit: 44 bits
[ 0.940218] kvm [1]: vgic-v2@6f020000
[ 0.943971] kvm [1]: GIC system register CPU interface enabled
[ 0.949972] kvm [1]: vgic interrupt IRQ9
[ 0.954037] kvm [1]: Hyp mode initialized successfully
[ 0.961390] Initialise system trusted keyrings
[ 0.966021] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.974746] zbud: loaded
[ 0.978371] NFS: Registering the id_resolver key type
[ 0.983560] Key type id_resolver registered
[ 0.987833] Key type id_legacy registered
[ 0.991969] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.998821] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.006389] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 1.014181] fuse: init (API version 7.32)
[ 1.038517] xor: measuring software checksum speed
[ 1.044682] 8regs : 7785 MB/sec
[ 1.050223] 32regs : 9061 MB/sec
[ 1.055901] arm64_neon : 7999 MB/sec
[ 1.060347] xor: using function: 32regs (9061 MB/sec)
[ 1.065511] Key type asymmetric registered
[ 1.069698] Asymmetric key parser ‘x509’ registered
[ 1.074701] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 1.082327] io scheduler mq-deadline registered
[ 1.088567] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 1.094842] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 1.104099] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 1.110569] debugfs: Directory ‘31010000.pat’ with parent ‘regmap’ already present!
[ 1.118564] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 1.124987] debugfs: Directory ‘31011000.pat’ with parent ‘regmap’ already present!
[ 1.132939] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 1.139358] debugfs: Directory ‘31012000.pat’ with parent ‘regmap’ already present!
[ 1.147299] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 1.153625] debugfs: Directory ‘31013000.pat’ with parent ‘regmap’ already present!
[ 1.161577] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 1.167908] debugfs: Directory ‘31014000.pat’ with parent ‘regmap’ already present!
[ 1.177856] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 1.186536] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 1.194735] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 1.201786] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 1.210251] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 1.223087] brd: module loaded
[ 1.353455] loop: module loaded
[ 1.357301] megasas: 07.714.04.00-rc1
[ 1.363634] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.370063] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.376152] sky2: driver version 1.30
[ 1.380560] VFIO - User Level meta-driver version: 0.3
[ 1.386297] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.393001] ehci-pci: EHCI PCI platform driver
[ 1.397872] usbcore: registered new interface driver uas
[ 1.403320] usbcore: registered new interface driver usb-storage
[ 1.410211] i2c /dev entries driver
[ 1.413917] Driver for 1-wire Dallas network protocol.
[ 1.419195] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[ 1.426256] sdhci: Secure Digital Host Controller Interface driver
[ 1.432575] sdhci: Copyright(c) Pierre Ossman
[ 1.437245] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.445381] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.451724] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 1.458466] hid: raw HID events driver (C) Jiri Kosina
[ 1.463837] usbcore: registered new interface driver usbhid
[ 1.469531] usbhid: USB HID core driver
[ 1.473903] optee: probing for conduit method.
[ 1.478460] optee: revision 3.12 (cac3fef2)
[ 1.478734] optee: initialized driver
[ 1.487809] drop_monitor: Initializing network drop monitor service
[ 1.494608] NET: Registered protocol family 10
[ 1.500564] Segment Routing with IPv6
[ 1.504353] mip6: Mobile IPv6
[ 1.507388] NET: Registered protocol family 17
[ 1.512034] Key type dns_resolver registered
[ 1.516420] mpls_gso: MPLS GSO support
[ 1.520404] registered taskstats version 1
[ 1.524595] Loading compiled-in X.509 certificates
[ 1.529547] zswap: loaded using pool lzo/zbud
[ 1.534128] Key type .fscrypt registered
[ 1.538162] Key type fscrypt-provisioning registered
[ 1.546914] Btrfs loaded, crc32c=crc32c-generic
[ 1.551634] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.565276] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 ‘21.9.1–v2021.09a (Terrific Lla’)
[ 1.624450] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 1.630620] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.637108] at24 2-0050: supply vcc not found, using dummy regulator
[ 1.665551] at24 2-0050: 512 byte 24c04 EEPROM, writable, 1 bytes/write
[ 1.672344] omap_i2c 42120000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.678629] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.685332] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.691556] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.697678] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
[ 1.704065] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.714051] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.722860] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.732744] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.756632] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.764307] j721e-pcie 2910000.pcie: IO 0x0018001000…0x0018010fff → 0x0018001000
[ 1.772584] j721e-pcie 2910000.pcie: MEM 0x0018011000…0x001fffffff → 0x0018011000
[ 1.780861] j721e-pcie 2910000.pcie: IB MEM 0x0000000000…0xffffffffffff → 0x0000000000
[ 1.790225] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 1.800115] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.806875] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.816135] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 1.826290] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.833049] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.841034] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 1.850482] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 30, base_baud = 3000000) is a 8250
[ 1.859226] printk: console [ttyS2] enabled
[ 1.867663] printk: bootconsole [ns16550a0] disabled
[ 1.878189] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 31, base_baud = 3000000) is a 8250
[ 1.887149] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 32, base_baud = 3000000) is a 8250
[ 1.898697] cdns-mhdp8546 a000000.dp-bridge: Direct firmware load for cadence/mhdp8546.bin failed with error -2
[ 1.908779] cdns-mhdp8546 a000000.dp-bridge: cdns_mhdp_fw_cb: No firmware.
[ 1.918037] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 1.925193] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 1.937792] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 1.981425] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.989928] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.998246] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.011050] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.018255] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.024599] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.034884] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[ 2.081410] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.088967] davinci_mdio c000f00.mdio: no live phy, scanning all
[ 2.107434] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown
[ 2.115278] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown
[ 2.123091] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown
[ 2.130903] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown
[ 2.138713] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown
[ 2.146529] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown
[ 2.154341] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown
[ 2.162151] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown
[ 2.169963] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown
[ 2.177774] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown
[ 2.185586] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown
[ 2.193484] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown
[ 2.201382] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown
[ 2.209282] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown
[ 2.217180] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown
[ 2.225081] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown
[ 2.232979] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown
[ 2.240877] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown
[ 2.248774] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown
[ 2.256672] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown
[ 2.264570] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown
[ 2.272470] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown
[ 2.280368] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown
[ 2.288265] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown
[ 2.296163] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown
[ 2.304060] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown
[ 2.311957] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown
[ 2.319855] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown
[ 2.327753] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown
[ 2.335652] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown
[ 2.343550] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown
[ 2.351447] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown
[ 2.359410] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[ 2.372088] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[ 2.385466] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 2.397525] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.403060] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.410817] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 2.420208] xhci-hcd xhci-hcd.0.auto: irq 232, io mem 0x06410000
[ 2.426393] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.434647] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.441856] usb usb1: Product: xHCI Host Controller
[ 2.446726] usb usb1: Manufacturer: Linux 5.10.162 xhci-hcd
[ 2.452285] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.457381] hub 1-0:1.0: USB hub found
[ 2.461143] hub 1-0:1.0: 1 port detected
[ 2.465211] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.470692] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 2.478346] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 2.484892] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.493025] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 2.501271] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.508474] usb usb2: Product: xHCI Host Controller
[ 2.513338] usb usb2: Manufacturer: Linux 5.10.162 xhci-hcd
[ 2.518898] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.523938] hub 2-0:1.0: USB hub found
[ 2.527693] hub 2-0:1.0: 1 port detected
[ 2.634300] mmc0: CQHCI version 5.10
[ 2.643257] gpio gpiochip2: gpio-line-names is length 37 but should be at most length 36
[ 2.652121] vdd_mmc1: supplied by vsys_3v3
[ 2.657163] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 2.664051] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 2.670906] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 2.677747] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 2.678477] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.691755] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 2.701979] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.709468] j721e-pcie 2910000.pcie: IO 0x0018001000…0x0018010fff → 0x0018001000
[ 2.717548] j721e-pcie 2910000.pcie: MEM 0x0018011000…0x001fffffff → 0x0018011000
[ 2.721421] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 2.725627] j721e-pcie 2910000.pcie: IB MEM 0x0000000000…0xffffffffffff → 0x0000000000
[ 2.756374] mmc0: Command Queue Engine enabled
[ 2.760818] mmc0: new HS200 MMC card at address 0001
[ 2.766129] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 2.770769] mmcblk0boot0: mmc0:0001 TB2916 partition 1 4.00 MiB
[ 2.776795] mmcblk0boot1: mmc0:0001 TB2916 partition 2 4.00 MiB
[ 2.782821] mmcblk0rpmb: mmc0:0001 TB2916 partition 3 4.00 MiB, chardev (236:0)
[ 2.791159] mmcblk0: p1 p2
[ 2.877759] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 2.885927] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 2.893044] usb 1-1: SerialNumber: BC0A0841A4CD
[ 2.898030] hub 1-1:1.0: USB hub found
[ 2.901794] hub 1-1:1.0: 4 ports detected
[ 3.005438] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 3.029646] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 3.037808] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.045357] hub 2-1:1.0: USB hub found
[ 3.049120] hub 2-1:1.0: 4 ports detected
[ 3.729548] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[ 3.735810] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.741284] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[ 3.750742] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.757623] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.763617] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 3.773320] pci 0000:00:00.0: supports D1
[ 3.777320] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 3.786480] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.797537] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.804150] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.809431] pcieport 0000:00:00.0: PME: Signaling with IRQ 506
[ 3.815447] pcieport 0000:00:00.0: AER: enabled with IRQ 506
[ 3.822099] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 3.833071] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 3.848034] spi-nor spi11.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 3.854998] spi-nor: probe of spi11.0 failed with error -2
[ 3.863319] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 3.909421] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 3.917875] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 3.926189] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 3.938990] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 3.946195] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 3.952517] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 3.962816] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 4.689505] mmc1: CQHCI version 5.10
[ 4.689588] debugfs: Directory ‘pd:27’ with parent ‘pm_genpd’ already present!
[ 4.700307] debugfs: Directory ‘pd:26’ with parent ‘pm_genpd’ already present!
[ 4.708815] debugfs: Directory ‘pd:242’ with parent ‘pm_genpd’ already present!
[ 4.716144] debugfs: Directory ‘pd:241’ with parent ‘pm_genpd’ already present!
[ 4.723449] debugfs: Directory ‘pd:240’ with parent ‘pm_genpd’ already present!
[ 4.730767] debugfs: Directory ‘pd:239’ with parent ‘pm_genpd’ already present!
[ 4.739238] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.746142] of_cfs_init
[ 4.748605] of_cfs_init: OK
[ 5.758091] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 5.765822] Waiting for root device /dev/mmcblk1p2…
[ 5.817221] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[ 5.824181] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
[ 5.833989] mmcblk1: p1 p2
[ 5.872684] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.880808] VFS: Mounted root (ext4 filesystem) readonly on device 179:770.
[ 5.895279] devtmpfs: mounted
[ 5.900121] Freeing unused kernel memory: 3776K
[ 5.917300] Checked W+X mappings: passed, no W+X pages found
[ 5.922974] Run /sbin/init as init process
[ 5.935786] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 6.241524] systemd[1]: System time before build time, advancing clock.
[ 6.275121] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 6.297593] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 11 (bullseye)!
[ 6.325484] systemd[1]: Set hostname to .
[ 6.595919] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.607776] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.615775] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 6.637509] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.644713] systemd[1]: Created slice system-modprobe.slice.
[ OK ] Created slice system-modprobe.slice.
[ 6.665490] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.672820] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 6.694038] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 6.717639] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password ts to Console Directory Watch.
[ 6.741569] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Ruests to Wall Directory Watch.
[ 6.765845] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ OK ] Set up automount Arbitrarys File System Automount Point.
[ 6.789538] systemd[1]: Reached target Local Encrypted Volumes.
[ OK ] Reached target Local Encrypted Volumes.
[ 6.809532] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 6.825482] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 6.845471] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 6.861482] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 6.881841] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 6.897629] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 6.921820] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 6.941684] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 6.961716] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 6.977818] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 6.997669] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.019275] systemd[1]: Mounting Huge Pages File System…
[ 7.035432] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.059421] systemd[1]: Mounting Kernel Debug File System…
[ 7.075365] systemd[1]: Mounting Kernel Trace File System…
[ 7.095862] systemd[1]: Starting Restore / save the current clock…
[ 7.117660] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[ 7.131056] systemd[1]: Starting Load Kernel Module configfs…
[ 7.159462] systemd[1]: Starting Load Kernel Module drm…
[ 7.183455] systemd[1]: Starting Load Kernel Module fuse…
[ 7.206017] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 7.218179] systemd[1]: Starting Journal Service…
[ 7.244297] systemd[1]: Starting Load Kernel Modules…
[ 7.266259] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.291558] systemd[1]: Starting Coldplug All udev Devices…
[ 7.318723] systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted Huge Pages File System.
[ 7.344215] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Trace File System.
[ OK ] Finished Restore / save the current clock.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System…
Mounting Kernel Configuration File System…
Starting Flush Journal to Persistent Storage…
[ 7.556239] systemd-journald[252]: Received client request to flush runtime journal.
Starting Load/Save Random Seed…
Starting Apply Kernel Variables…
Starting Create Static Device Nodes in /dev…
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create Static Device Nodes in /dev.
[ 7.738089] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Reached target Local File Systems (Pre).
[ 7.761573] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Reached target Local File Systems.
[ 7.785516] random: systemd: uninitialized urandom read (16 bytes read)
Starting Helper to synchronize boot up for ifupdown…
Starting Create Volatile Files and Directories…
Starting Rule-based Managefor Device Events and Files…
[ OK ] Finished Helper to synchronize boot up for ifupdown.
[ OK ] Finished Create Volatile Files and Directories.
Starting Raise network interfaces…
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Finished Update UTMP about System Boot/Shutdown.
[FAILED] Failed to start Network Time Synchronization.
See ‘systemctl status systemd-timesyncd.service’ for details.
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Finished Raise network interfaces.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Periodic ext4 Onliata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Avahi mDNS/DNS-SD Stack…
[ OK ] Started Regular background program processing daemon.
[ OK ] Started D-Bus System Message Bus.
Starting Network Manager…
Starting Remove Stale Onlit4 Metadata Check Snapshots…
Starting Authorization Manager…
Starting Regenerate SSH host keys…
Starting System Logging Service…
Starting User Login Management…
Starting WPA supplicant…
[FAILED] Failed to start User Login Management.
See ‘systemctl status systemd-logind.service’ for details.
[ OK ] Found device /dev/ttyS2.
[ 8.748144] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.755988] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.768439] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Started System Logging Service.
[ OK ] Finished Remove Stale Onliext4 Metadata Check Snapshots.
[ OK ] Reached target Hardware activated USB gadget.
[ OK ] Listening on Load/Save RF itch Status /dev/rfkill Watch.
[ OK ] Stopped User Login Management.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started WPA supplicant.
[ OK ] Started Authorization Manager.
Starting Modem Manager…
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting A high performanc and a reverse proxy server…
Starting Hostname Service…
Starting Permit User Sessions…
[FAILED] Failed to start Hostname Service.
See ‘systemctl status systemd-hostnamed.service’ for details.
[ OK ] Finished Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
[ OK ] Started Modem Manager.
[FAILED] Failed to start A high perer and a reverse proxy server.
See ‘systemctl status nginx.service’ for details.
[FAILED] Failed to start Load Kernel Module drm.
See ‘systemctl status modprobe@drm.service’ for details.
[ 10.585415] random: crng init done
[ 10.588812] random: 270 urandom warning(s) missed due to ratelimiting
[FAILED] Failed to start Regenerate SSH host keys.
See ‘systemctl status regenerate_ssh_host_keys.service’ for details.
Starting OpenBSD Secure Shell server…
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Finished Update UTMP about System Runlevel Changes.
Debian GNU/Linux 11 arm ttyS2
default username:password is [debian:temppwd]
arm login: [ 34.433364] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 34.442874] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
