how to make sd image for BB AI 64
For Uboot, first I download and run “build.sh” from here:
sw/bootloader · main · BeagleBoard.org / BeagleBone AI-64 · GitLab
I got some .bin, u-boot.image… in ./sw/bootloader/deploy folder. Looks no errors
From kernel (I guess) I download and ran “jenkins_build.sh” from here:
Files · 5.10-arm64 · BeagleBoard.org / Linux · GitLab
Looks no error too, a lot of new files generated.
But I am not sure how to make SD image from these files. Is there any script or instruction that allow me to make SD image from what I built?
Many thanks
Hi @caccac268 ,
Assuming microSD = /dev/sdb, mounting as /media/boot/ and /media/rootfs…
Start with the dual partitions:
sudo sfdisk ${DISK} <<-__EOF__
1M,128M,0xC,*
129M,,,-
__EOF__
Format 1st partition, as fat16 for boot rom…
sudo mkfs.vfat -F 16 /dev/sdb1 -n FIRMWARE
Format 2nd Partition as ext4 (rootfs)
sudo mkfs.ext4 /dev/sdb2 -L rootfs
Copy Firmware/U-boot files to boot partition:
cp -v sysfw.itb /media/boot/
cp -v tiboot3.bin /media/boot/
cp -v tispl.bin /media/boot/
cp -v u-boot.img /media/boot/
For the rootfs, grab your favorite linux file system, if you need a base grab:
wget -c https://rcn-ee.net/rootfs/eewiki/minfs/debian-11.4-minimal-arm64-2022-08-05.tar.xz
tar xf debian-11.4-minimal-arm64-2022-08-05.tar.xz
and copy it on the root partition:
sudo tar xfvp ./debian-*-*-arm64-*/arm64-rootfs-*.tar -C /media/rootfs/
sync
Create extlinux.conf in boot partition, this is what tell u-boot what to load… /media/boot/extlinux/extlinux.conf
label Linux microSD
    kernel /Image
    append console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0
    fdtdir /
The default vmlinuz file created by the kernel builder needs to be uncompressed, save it as “Image”
cat /boot/vmlinuz-${version} | gunzip -d > /media/boot/Image
Next, copy the device tree and overlays, in the boot partition, it should look like this… Used “*” to hide repeats…
debian@BeagleBone:~/$ tree /media/boot/
/media/boot/
├── Image
├── extlinux
│   └── extlinux.conf
├── k3-j721e-*.dtb
├── overlays
│   └── *.dtbo
├── sysfw.itb
├── tiboot3.bin
├── tispl.bin
└── u-boot.img
Thanks Robert, the instruction was very clear, so we got boot with custom image.
But when we try to call “sudo apt update”, the system says 30: read-only file system, I guess it could be bad SD card?
By the way, does your instructions about installing usb gadget on BBB still work on BB AI 64?
did you set /etc/fstab?
/dev/mmcblk0p2  /  ext4  noatime,errors=remount-ro  0  1
/dev/mmcblk0p1  /boot/firmware vfat defaults 0 0
debugfs  /sys/kernel/debug  debugfs  mode=755,uid=root,gid=gpio,defaults  0  0
Yes, designed to share the same setup.
When I tried to add /ete/fstab file
this error happened:
I already changed mmcblk0p to mmcblk1p because I think I am on SD, is it correct?
/dev/mmcblk1p2  /  ext4  noatime,errors=remount-ro  0  1
/dev/mmcblk1p1  /boot/firmware vfat defaults 0 0
Also
Should it be :
sudo mkfs.vfat -F 16 /dev/sdb1 -n boot
codepage cp437 not found okay, it’ll convert that into a built-in vs’s a module… So just drop the fat loading in etc/fstab then…
You are correct, /dev/mmcblk0 would be the eMMC…
I got “sudo apt update” working,
but usb-gadget doesn’t work yet. On BBB I just ran your instructions. Looks like on custom BBAI64 from two links above, there is no usb gadget driver in kernel yet?
Seems I didn’t build kernel modules yet :)).
Once you have the board booted… From the kernel build script just build the *.deb file… Copy it over and install with dpkg, everything will get installed in the correct location…
Hi, I got usb eth working by run this command from PC with SD inserted, with the path from where I built kernel.
make INSTALL_MOD_PATH=/media/rootfs   modules_install
just want to learn more about
Do you mean on BBAI-64 or on host PC? I mean, could you please tell a bit more about the path of *.deb file and path of the script please?
So on the same machine you ran, ./build_kernel.sh, now just run: ./tools/rebuild_deb.sh, let it run, then copy the linux-image*.deb generated under ./deploy/ to the target board, and then run: sudo dpkg -i linux-image*.deb and reboot…
Yes, thank you so much!
