I have this simple script that I want to execute at boot time.
The script:
root@bbone:~# cat boneboot/ledsoff.js
var b=require(‘bonescript’);
b.pinMode(‘USR0’, ‘out’);
b.pinMode(‘USR1’, ‘out’);
b.pinMode(‘USR2’, ‘out’);
b.pinMode(‘USR3’, ‘out’);
b.digitalWrite(‘USR0’, 0);
b.digitalWrite(‘USR1’, 0);
b.digitalWrite(‘USR2’, 0);
b.digitalWrite(‘USR3’, 0);
To run it at boot I’ve created a file in /etc/cron.d which looks like this:
root@bbone:~# cat /etc/cron.d/boneboot
m h dom mon dow user command
@reboot root sleep 120 && /usr/bin/nodejs /root/boneboot/ledsoff.js 2>&1 | logger -p info -t ledsoff
Unfortunately, when I reboot the BBB the code is not executed succesfully as shown by the log:
root@bbone:~# cat /var/log/syslog Dec 18 21:54:49 bbone ledsoff: Dec 18 21:54:49 bbone ledsoff: module.js:340 Dec 18 21:54:49 bbone ledsoff: throw err; Dec 18 21:54:49 bbone ledsoff: ^ Dec 18 21:54:50 bbone ledsoff: Error: Cannot find module 'bonescript' Dec 18 21:54:50 bbone ledsoff: at Function.Module._resolveFilename (module.js:338:15) Dec 18 21:54:50 bbone ledsoff: at Function.Module._load (module.js:280:25) Dec 18 21:54:50 bbone ledsoff: at Module.require (module.js:364:17) Dec 18 21:54:50 bbone ledsoff: at require (module.js:380:17) Dec 18 21:54:50 bbone ledsoff: at Object.<anonymous> (/root/boneboot/ledsoff.js:1:69) Dec 18 21:54:50 bbone ledsoff: at Module._compile (module.js:456:26) Dec 18 21:54:50 bbone ledsoff: at Object.Module._extensions..js (module.js:474:10) Dec 18 21:54:50 bbone ledsoff: at Module.load (module.js:356:32) Dec 18 21:54:50 bbone ledsoff: at Function.Module._load (module.js:312:12) Dec 18 21:54:50 bbone ledsoff: at Function.Module.runMain (module.js:497:10)
However, when I logged in as root, the code executes normally.
Any suggestions on how to proceed?
