BBB information:
> Linux BeagleBone 5.10.168-ti-r77 #1bullseye SMP PREEMPT Wed Feb 28 21:05:58 UTC 2024 armv7l GNU/Linux
> Debian GNU/Linus 11.9 (bullseye)
> BeagleBoard.org Debian Bullseye IoT Image 2023-09-02
When I try to run the example blinkLED.bs.js in Beagle Bone code workspace or from a command prompt. I get the following error;
> internal/modules/cjs/loader.js:818
> throw err;
> Error: Cannot find module 'bonescript'
> Require stack:
> - /opt/vsx-examples/examples/BeagleBone/Black/blinkLED.bs.js
> at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
> at Function.Module._load (internal/modules/cjs/loader.js:667:27)
> at Module.require (internal/modules/cjs/loader.js:887:19)
> at require (internal/modules/cjs/helpers.js:74:18)
> at Object.<anonymous> (/opt/vsx-examples/examples/BeagleBone/Black/blinkLED.bs.js:11:11)
> at Module._compile (internal/modules/cjs/loader.js:999:30)
> at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
> at Module.load (internal/modules/cjs/loader.js:863:32)
> at Function.Module._load (internal/modules/cjs/loader.js:708:14)
> at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
> code: 'MODULE_NOT_FOUND',
> requireStack: [ '/opt/vsx-examples/examples/BeagleBone/Black/blinkLED.bs.js' ]
Read the following posts:
Post (1) had no replies or solution
Post (2) had some sort of solution but I do not understand it.
Also read several other posts but the majority did not apply or dealt with specific coding errors.
