#!/usr/bin/env python
import time
import os
import signal
import sys
# Motor is attached here
# controller = ["P9_11", "P9_13", "P9_15", "P9_17"];
# controller = ["30", "31", "48", "5"]
# controller = ["P9_14", "P9_16", "P9_18", "P9_22"];
controller = ["50", "51", "4", "2"]
states = [[1,0,0,0], [0,1,0,0], [0,0,1,0], [0,0,0,1]]
statesHiTorque = [[1,1,0,0], [0,1,1,0], [0,0,1,1], [1,0,0,1]]
statesHalfStep = [[1,0,0,0], [1,1,0,0], [0,1,0,0], [0,1,1,0],
[0,0,1,0], [0,0,1,1], [0,0,0,1], [1,0,0,1]]
curState = 0 # Current state
ms = 100 # Time between steps, in ms
maxStep = 22 # Number of steps to turn before turning around
minStep = 0 # minimum step to turn back around on
CW = 1 # Clockwise
CCW = -1
pos = 0 # current position and direction
direction = CW
GPIOPATH="/sys/class/gpio"
def signal_handler(sig, frame):
print('Got SIGINT, turning motor off')
for i in range(len(controller)) :
f = open(GPIOPATH+"/gpio"+controller[i]+"/value", "w")
f.write('0')
f.close()
sys.exit(0)
signal.signal(signal.SIGINT, signal_handler)
print('Hit ^C to stop')
def move():
global pos
global direction
global minStep
global maxStep
pos += direction
print("pos: " + str(pos))
# Switch directions if at end.
if (pos >= maxStep or pos <= minStep) :
direction *= -1
rotate(direction)
# This is the general rotate
def rotate(direction) :
global curState
global states
# print("rotate(%d)", direction);
# Rotate the state according to the direction of rotation
curState += direction
if(curState >= len(states)) :
curState = 0;
elif(curState<0) :
curState = len(states)-1
updateState(states[curState])
# Write the current input state to the controller
def updateState(state) :
global controller
print(state)
f.write(str(state[i]))
f.close()
# Initialize motor control pins to be OUTPUTs
# Make sure pin is exported
if (not os.path.exists(GPIOPATH+"/gpio"+controller[i])):
f = open(GPIOPATH+"/export", "w")
f.write(pin)
f.close()
# Make it an output pin
f = open(GPIOPATH+"/gpio"+controller[i]+"/direction", "w")
f.write("out")
f.close()
# Put the motor into a known state
updateState(states[0])
rotate(direction)
# Rotate
while True:
move()
time.sleep(ms/1000)
This is some source from the docs.beagleboard.org pages that I found for a L298 driver. I switched things up a bit and made the source run…
To my surprise, I got it to work but nothing happened. I get it. Some Python3 source in the land of Debian these days.
Too many apt styled library reckonings. Anyway, thank you for trying to make me understand.
