How does one copy the EMMC to an SD card to create a bootable SD card? I am close to running out of space on my 2Gb EMMC so I need to transfer to an SD card. I’m running Debian 11
good luck!
gomer
The only trouble with that is that /opt/scripts/tools/eMMC/beaglebone-black-make-microSD-flasher-from-eMMC.sh no longer exists. You have to jump through hoops in /etc to get the same result.
However that thread does tell me how to stop the new microSD image from flashing itself back onto the EMMC so I think I can probably fight my way through now. ![]()
Hi, good afternoon!
I don’t know what version of BeagleBoard do you have. I’m using the BeagleBoard Black and that file: "/opt/scripts/tools/eMMC/beaglebone-black-make-microSD-flasher-from-eMMC.sh " exists. Indeed, I’m using a lot for clone all the BBB I have (near 250 units).
I don’t know about how to boot from the SD Card. Maybe you could try changing the boot partition with fdisk.
Regards!
This was re-written in our Debian 11/12 images…
to configure flasher to copy from microSD → eMMC:
sudo cp -v /etc/beagle-flasher/beaglebone-black-microsd-to-emmc /etc/default/beagle-flasher
to configure flasher to copy from eMMC → microSD
sudo cp -v /etc/beagle-flasher/beaglebone-black-emmc-to-microsd /etc/default/beagle-flasher
To copy as is, while running, (not recommended for complex images X11/Docker/etc…)
sudo beagle-flasher
To copy on bootup like normal flashers:
sudo enable-beagle-flasher
sudo reboot
