We have released a preliminary version of JB release - Android 4.1.1
for beagleboard and beaglebone platforms, the sources are now
available on http://gitorious.org/rowboat
I can not increase the RAM from 256M to 512M. I think there is issue in u-boot and(or) x-loader.
u-boot printed “DRAM: 512MiB”, but actually the 256M-512M RAM is invariable. Because I called mem_ok() to test, mem_ok() failed.
I think the issue is in x-loader, the version of which is ''Texas Instruments X-Loader 1.51". I just merged some RAM related commits from http://gitorious.org/x-load-omap3/mainline/ into this x-loader. Now the whole 512M RAM is working fine.
Thanks. I tested on Beagleboard-XM and it looks good. Video playback
seems smooth. But there appears to be a problem in that the Android
Settings UI does not show any ethernet interface. From the console,
usb0 is present and netcfg usb0 dhcp works fine, but nothing is
visible in the Android UI for configuring ethernet.
I also plan on testing with Beagleboard C5. I see that the rowboat-jb
release still uses the same 2.6.37 psp baselined kernel. So, the MTD
bugs (mtd_pagetest failures) are still present and so ubifs on
Beagleboard C5 won't work. Any plans to rectify this?
Hi Khasim,
The Ethernet Manager is not yet integrated into the settings application. The Settings app that you see is the vanilla AOSP version.
I want to enable DSP to accelerate video playback. I find the “DSP Stack Integration” for gingerbread http://code.google.com/p/rowboat/wiki/DSP. Is there an instruction for JB?
