MIcro SDXC card in BB AI-64 gives black screen and only solid light
Continuing the discussion from Micro SDXC card in BB AI-64 gives black screen and only flashing light.:
Hello
I flashed bbai64-emmc-flasher-debian-11.3-xfce-arm64-2022-06-14-10gb.img.xz on SDcard and inserted sdmmc card into BBAI64 and I still cannot boot, serial port shows below,
-Boot SPL 2021.01-g3419da0b (Jan 13 2022 - 15:29:57 +0000)
Model: Texas Instruments K3 J721E SoC
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0015 ’21.5.0—v2021.05 (Terrific Llam’)
ti_i2c_eeprom_am6_parse_record: Ignoring record id 17
Trying to boot from MMC1
U-Boot 2021.01-g3419da0b (Jan 13 2022 - 15:29:57 +0000)
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
eth0: ethernet@46000000
Hit any key to stop autoboot:  2  1  0
board_name=[BBONEAI-64-B0-] …
name_fdt=[k3-j721e-beagleboneai64.dtb] …
MMC: no card present
mmc_init: -123, time 2002
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
500 bytes read in 8 ms (60.5 KiB/s)
1:	Linux New
Retrieving file: /boot/initrd.img-5.10.162-ti-arm64-r97
Failed to load ‘/boot/initrd.img-5.10.162-ti-arm64-r97’
Skipping Linux New for failure retrieving initrd
2:	Linux eMMC
Retrieving file: /initrd.img
14943002 bytes read in 89 ms (160.1 MiB/s)
Retrieving file: /Image
32715264 bytes read in 185 ms (168.6 MiB/s)
append: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait net.ifnames=0
Retrieving file: /k3-j721e-beagleboneai64.dtb
176972 bytes read in 9 ms (18.8 MiB/s)
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f1bf000, end 8ffff31a … OK
   Loading Device Tree to 000000008f190000, end 000000008f1be34b … OK
Starting kernel …
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.90-ti-arm64-r28 (voodoo@rpi4b8g-20) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP PREEMPT Thu Jan 13 15:02:48 UTC 2022
[    0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options ‘’)
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 10 pages/cpu s580504 r8192 d66664 u655360
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait net.ifnames=0
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3309824K/4194304K available (16384K kernel code, 2380K rwdata, 8640K rodata, 4096K init, 901K bss, 360192K reserved, 524288K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x28/0x500 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008801e0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008801f0000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008506] Console: colour dummy device 80x25
[    0.013073] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023744] pid_max: default: 32768 minimum: 301
[    0.028614] LSM: Security Framework initializing
[    0.033440] Yama: becoming mindful.
[    0.037054] AppArmor: AppArmor initialized
[    0.041243] TOMOYO Linux initialized
[    0.044943] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.052510] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.061904] rcu: Hierarchical SRCU implementation.
[    0.067347] Platform MSI: msi-controller@1820000 domain created
[    0.073768] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.083126] EFI services will not be available.
[    0.088003] smp: Bringing up secondary CPUs …
[    0.093306] Detected PIPT I-cache on CPU1
[    0.093328] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.093338] GICv3: CPU1: using allocated LPI pending table @0x0000000880200000
[    0.093375] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.093442] smp: Brought up 1 node, 2 CPUs
[    0.122800] SMP: Total of 2 processors activated.
[    0.127607] CPU features: detected: 32-bit EL0 Support
[    0.132865] CPU features: detected: CRC32 instructions
[    0.151040] CPU: All CPU(s) started at EL2
[    0.155244] alternatives: patching kernel code
[    0.160443] devtmpfs: initialized
[    0.173071] KASLR disabled due to lack of seed
[    0.177771] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.187748] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.195479] pinctrl core: initialized pinctrl subsystem
[    0.201103] DMI not present or invalid.
[    0.205387] NET: Registered protocol family 16
[    0.213685] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.220990] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.228994] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.237124] audit: initializing netlink subsys (disabled)
[    0.242866] audit: type=2000 audit(0.156:1): state=initialized audit_enabled=0 res=1
[    0.243251] thermal_sys: Registered thermal governor ‘fair_share’
[    0.250794] thermal_sys: Registered thermal governor ‘bang_bang’
[    0.257020] thermal_sys: Registered thermal governor ‘step_wise’
[    0.263156] thermal_sys: Registered thermal governor ‘user_space’
[    0.269291] thermal_sys: Registered thermal governor ‘power_allocator’
[    0.276213] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.289864] ASID allocator initialised with 65536 entries
[    0.321918] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.328774] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.335533] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.349371] cryptd: max_cpu_qlen set to 1000
[    0.364250] raid6: skip pq benchmark and using algorithm neonx8
[    0.370511] raid6: using neon recovery algorithm
[    0.376741] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.386747] vsys_3v3: supplied by evm_12v0
[    0.391918] vsys_5v0: supplied by evm_12v0
[    0.398285] iommu: Default domain type: Translated
[    0.404475] SCSI subsystem initialized
[    0.408730] usbcore: registered new interface driver usbfs
[    0.414467] usbcore: registered new interface driver hub
[    0.419940] usbcore: registered new device driver usb
[    0.425715] mc: Linux media interface: v0.10
[    0.430091] videodev: Linux video capture interface: v2.00
[    0.435736] pps_core: LinuxPPS API ver. 1 registered
[    0.440806] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.450144] PTP clock support registered
[    0.454166] EDAC MC: Ver: 3.0.0
[    0.458480] NetLabel: Initializing
[    0.461952] NetLabel:  domain hash size = 128
[    0.466408] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.472219] NetLabel:  unlabeled traffic allowed by default
[    0.478204] clocksource: Switched to clocksource arch_sys_counter
[    0.801497] VFS: Disk quotas dquot_6.6.0
[    0.805617] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.813340] AppArmor: AppArmor Filesystem Enabled
[    0.821780] NET: Registered protocol family 2
[    0.826403] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.835265] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.844084] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.852363] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.860256] TCP: Hash tables configured (established 32768 bind 32768)
[    0.867172] MPTCP token hash table entries: 4096 (order: 0, 98304 bytes, linear)
[    0.874824] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.881725] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.889146] NET: Registered protocol family 1
[    0.893961] RPC: Registered named UNIX socket transport module.
[    0.900030] RPC: Registered udp transport module.
[    0.904836] RPC: Registered tcp transport module.
[    0.909640] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.916223] NET: Registered protocol family 44
[    0.920769] PCI: CLS 0 bytes, default 64
[    0.924890] Trying to unpack rootfs image as initramfs…
[    1.191608] Freeing initrd memory: 14528K
[    1.196059] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.206978] Initialise system trusted keyrings
[    1.211617] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    1.220505] zbud: loaded
[    1.224437] NFS: Registering the id_resolver key type
[    1.229618] Key type id_resolver registered
[    1.233890] Key type id_legacy registered
[    1.238022] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[    1.244871] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[    1.252440] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.259978] fuse: init (API version 7.32)
[    1.264227] F2FS not supported on PAGE_SIZE(65536) != 4096
[    1.289272] xor: measuring software checksum speed
[    1.295428]    8regs           :  7884 MB/sec
[    1.300958]    32regs          :  9101 MB/sec
[    1.306741]    arm64_neon      :  7383 MB/sec
[    1.311189] xor: using function: 32regs (9101 MB/sec)
[    1.316354] Key type asymmetric registered
[    1.320537] Asymmetric key parser ‘x509’ registered
[    1.325540] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.333180] io scheduler mq-deadline registered
[    1.339854] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    1.346068] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    1.355761] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    1.362054] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    1.370439] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    1.379764] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    1.388754] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    1.397589] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    1.405307] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    1.419650] brd: module loaded
[    1.550247] loop: module loaded
[    1.553915] megasas: 07.714.04.00-rc1
[    1.559583] libphy: Fixed MDIO Bus: probed
[    1.564358] tun: Universal TUN/TAP device driver, 1.6
[    1.569882] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.576290] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.582388] sky2: driver version 1.30
[    1.586794] VFIO - User Level meta-driver version: 0.3
[    1.592476] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[    1.599165] ehci-pci: EHCI PCI platform driver
[    1.604391] i2c /dev entries driver
[    1.608161] Driver for 1-wire Dallas network protocol.
[    1.613439] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[    1.620606] sdhci: Secure Digital Host Controller Interface driver
[    1.626923] sdhci: Copyright(c) Pierre Ossman
[    1.631695] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.640012] ledtrig-cpu: registered to indicate activity on CPUs
[    1.646379] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ….
[    1.652999] hid: raw HID events driver (C) Jiri Kosina
[    1.658422] usbcore: registered new interface driver usbhid
[    1.664123] usbhid: USB HID core driver
[    1.668837] optee: probing for conduit method.
[    1.673397] optee: revision 3.12 (3d47a131)
[    1.673655] optee: initialized driver
[    1.682970] drop_monitor: Initializing network drop monitor service
[    1.689744] NET: Registered protocol family 10
[    1.708277] Segment Routing with IPv6
[    1.712086] mip6: Mobile IPv6
[    1.715161] NET: Registered protocol family 17
[    1.719807] Key type dns_resolver registered
[    1.724386] registered taskstats version 1
[    1.728575] Loading compiled-in X.509 certificates
[    1.733618] zswap: loaded using pool lzo/zbud
[    1.738230] Key type ._fscrypt registered
[    1.742330] Key type .fscrypt registered
[    1.746334] Key type fscrypt-provisioning registered
[    1.753086] Btrfs loaded, crc32c=crc32c-generic
[    1.757765] AppArmor: AppArmor sha1 policy hashing enabled
[    1.770144] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    1.776516] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    1.785858] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 ’21.5.0—v2021.05 (Terrific Llam’)
[    1.816202] random: fast init done
[    1.841231] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    1.847375] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    1.853884] at24 2-0050: supply vcc not found, using dummy regulator
[    1.882346] at24 2-0050: 512 byte 24c04 EEPROM, writable, 1 bytes/write
[    1.889137] omap_i2c 42120000.i2c: bus 2 rev0.12 at 400 kHz
[    1.895372] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    1.902167] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[    1.908338] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[    1.914490] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[    1.920539] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    1.927037] omap_i2c 2050000.i2c: bus 8 rev0.12 at 400 kHz
[    1.933185] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
[    1.939810] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.949787] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.958600] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    1.968448] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.990558] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    1.999694] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.007377] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.015662] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.023942] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.033319] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    2.043202] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    2.049962] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.059184] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    2.069333] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    2.076093] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.084098] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    2.093578] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 27, base_baud = 3000000) is a 8250
[    2.102330] printk: console [ttyS2] enabled
[    2.110769] printk: bootconsole [ns16550a0] disabled
[    2.121308] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 28, base_baud = 3000000) is a 8250
[    2.130378] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 29, base_baud = 3000000) is a 8250
[    2.139398] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 30, base_baud = 3000000) is a 8250
[    2.190212] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.197863] libphy: 46000f00.mdio: probed
[    2.206059] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.214375] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    2.228432] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    2.239509] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.245007] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.253223] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[    2.262626] xhci-hcd xhci-hcd.0.auto: irq 224, io mem 0x06410000
[    2.268804] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.277058] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.284266] usb usb1: Product: xHCI Host Controller
[    2.289133] usb usb1: Manufacturer: Linux 5.10.90-ti-arm64-r28 xhci-hcd
[    2.295732] usb usb1: SerialNumber: xhci-hcd.0.auto
[    2.300825] hub 1-0:1.0: USB hub found
[    2.304586] hub 1-0:1.0: 1 port detected
[    2.308637] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.314123] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    2.321785] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    2.328338] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[    2.336488] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    2.344735] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.351941] usb usb2: Product: xHCI Host Controller
[    2.356805] usb usb2: Manufacturer: Linux 5.10.90-ti-arm64-r28 xhci-hcd
[    2.363425] usb usb2: SerialNumber: xhci-hcd.0.auto
[    2.368474] hub 2-0:1.0: USB hub found
[    2.372229] hub 2-0:1.0: 1 port detected
[    2.478332] mmc0: CQHCI version 5.10
[    2.487136] gpio gpiochip2: gpio-line-names is length 37 but should be at most length 36
[    2.496175] vdd_mmc1: supplied by vsys_3v3
[    2.501229] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    2.508158] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    2.515063] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    2.521918] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    2.526219] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    2.528736] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    2.545964] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.553529] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.561671] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.566216] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    2.569809] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.639428] mmc0: mmc_select_hs200 failed, error -110
[    2.644475] mmc0: error -110 whilst initialising MMC card
[    2.685926] j721e-pcie 2910000.pcie: Link up
[    2.690265] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[    2.696579] pci_bus 0000:00: root bus resource [bus 00-0f]
[    2.702110] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[    2.711584] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[    2.718531] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[    2.724582] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    2.734274] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    2.743988] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[    2.753788] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.763594] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[    2.773388] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[    2.783226] pci 0000:00:00.0: supports D1
[    2.783229] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[    2.783232] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    2.787282] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.795428] usb 1-1: SerialNumber: D60700591EA6
[    2.802512] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[    2.823285] hub 1-1:1.0: USB hub found
[    2.825408] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.835053] hub 1-1:1.0: 4 ports detected
[    2.835056] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.835061] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.858499] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.868357] pci 0000:01:00.0: [8086:f1aa] type 00 class 0x010802
[    2.874434] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    2.881559] pci 0000:01:00.0: reg 0x1ac: [mem 0x00000000-0x0000ffff 64bit]
[    2.888430] pci 0000:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0007ffff 64bit] (contains BAR0 for 8 VFs)
[    2.898338] pci 0000:01:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[    2.918239] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    2.925115] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[    2.931926] pci 0000:00:00.0: BAR 14: assigned [mem 0x18100000-0x181fffff]
[    2.938800] pci 0000:01:00.0: BAR 7: assigned [mem 0x18100000-0x1817ffff 64bit]
[    2.946110] pci 0000:01:00.0: BAR 0: assigned [mem 0x18180000-0x18183fff 64bit]
[    2.953453] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.958424] pci 0000:00:00.0:   bridge window [mem 0x18100000-0x181fffff]
[    2.965319] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[    2.965458] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    2.973483] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.986897] hub 2-1:1.0: USB hub found
[    2.986932] pcieport 0000:00:00.0: PME: Signaling with IRQ 498
[    2.996493] hub 2-1:1.0: 4 ports detected
[    2.996751] pcieport 0000:00:00.0: AER: enabled with IRQ 498
[    3.007436] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    3.018117] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    3.032294] mmc0: mmc_select_hs200 failed, error -110
[    3.032390] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.037346] mmc0: error -110 whilst initialising MMC card
[    3.049593] spi-nor: probe of spi1.0 failed with error -2
[    3.094248] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.101918] libphy: 46000f00.mdio: probed
[    3.110052] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    3.118422] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    3.132007] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.138959] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    3.146180] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.152552] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    3.200365] mmc0: mmc_select_hs200 failed, error -110
[    3.205417] mmc0: error -110 whilst initialising MMC card
[    3.210817] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
[    3.318622] usb 1-1.1: New USB device found, idVendor=045e, idProduct=0040, bcdDevice= 3.00
[    3.326974] usb 1-1.1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[    3.334268] usb 1-1.1: Product: Microsoft 3-Button Mouse with IntelliEye(TM)
[    3.341301] usb 1-1.1: Manufacturer: Microsoft
[    3.350424] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:045E:0040.0001/input/input0
[    3.369024] hid-generic 0003:045E:0040.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-xhci-hcd.0.auto-1.1/input0
[    3.405314] mmc0: mmc_select_hs200 failed, error -110
[    3.410360] mmc0: error -110 whilst initialising MMC card
[    3.462210] usb 1-1.2: new full-speed USB device number 4 using xhci-hcd
[    3.566641] usb 1-1.2: New USB device found, idVendor=0b97, idProduct=7731, bcdDevice= 2.10
[    3.574977] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.584880] hub 1-1.2:1.0: USB hub found
[    3.588933] hub 1-1.2:1.0: 2 ports detected
[    3.878208] usb 1-1.2.1: new full-speed USB device number 5 using xhci-hcd
[    3.901245] mmc1: CQHCI version 5.10
[    3.901924] debugfs: Directory ‘pd:27’ with parent ‘pm_genpd’ already present!
[    3.912191] debugfs: Directory ‘pd:26’ with parent ‘pm_genpd’ already present!
[    3.920874] debugfs: Directory ‘pd:242’ with parent ‘pm_genpd’ already present!
[    3.928262] debugfs: Directory ‘pd:241’ with parent ‘pm_genpd’ already present!
[    3.935604] debugfs: Directory ‘pd:240’ with parent ‘pm_genpd’ already present!
[    3.942918] debugfs: Directory ‘pd:239’ with parent ‘pm_genpd’ already present!
[    3.951356] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    3.994531] usb 1-1.2.1: New USB device found, idVendor=0b97, idProduct=7732, bcdDevice= 2.10
[    4.003052] usb 1-1.2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.098214] usb 1-1.2.2: new low-speed USB device number 6 using xhci-hcd
[    4.215313] usb 1-1.2.2: New USB device found, idVendor=049f, idProduct=0051, bcdDevice= 1.05
[    4.223832] usb 1-1.2.2: New USB device strings: Mfr=1, Product=8, SerialNumber=0
[    4.231304] usb 1-1.2.2: Product: Compaq USB Keyboard
[    4.236344] usb 1-1.2.2: Manufacturer: CHICONY
[    4.250037] input: CHICONY Compaq USB Keyboard as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/0003:049F:0051.0002/input/input2
[    4.326410] hid-generic 0003:049F:0051.0002: input,hidraw1: USB HID v1.10 Keyboard [CHICONY Compaq USB Keyboard] on usb-xhci-hcd.0.auto-1.2.2/input0
[    4.348084] input: CHICONY Compaq USB Keyboard Consumer Control as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.1/0003:049F:0051.0003/input/input3
[    4.426381] hid-generic 0003:049F:0051.0003: input,hiddev0,hidraw2: USB HID v1.10 Device [CHICONY Compaq USB Keyboard] on usb-xhci-hcd.0.auto-1.2.2/input1
[    5.422529] sdhci-am654 4fb0000.mmc: Power on failed
[    5.458086] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    5.466805] Freeing unused kernel memory: 4096K
[    5.488311] Checked W+X mappings: passed, no W+X pages found
[    5.493993] Run /init as init process
Loading, please wait…
Starting version 247.3-6
[    5.963126] nvme nvme0: pci function 0000:01:00.0
[    5.968105] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    6.042397] nvme nvme0: 2/0/0 default/read/poll queues
[    6.150891] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[    6.165461] remoteproc remoteproc0: b034000.pru is available
[    6.171564] remoteproc remoteproc1: b004000.rtu is available
[    6.177632] remoteproc remoteproc2: b00a000.txpru is available
[    6.183743] remoteproc remoteproc3: b038000.pru is available
[    6.189665] remoteproc remoteproc4: b006000.rtu is available
[    6.195684] remoteproc remoteproc5: b00c000.txpru is available
[    6.201791] remoteproc remoteproc6: b134000.pru is available
[    6.207786] remoteproc remoteproc7: b104000.rtu is available
[    6.213771] remoteproc remoteproc8: b10a000.txpru is available
[    6.219826] remoteproc remoteproc9: b138000.pru is available
[    6.225802] remoteproc remoteproc10: b106000.rtu is available
[    6.226080] remoteproc remoteproc11: b10c000.txpru is available
[    6.253230] Console: switching to colour frame buffer device 240x67
[    6.297362] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Mounting root file system … Begin: Running /scripts/local-top … done.
Begin: Running /scripts/local-premount … Scanning for Btrfs filesystems
done.
Begin: Waiting for root file system … Begin: Running /scripts/local-block … done.
[   35.898222] vdd_mmc1: disabling
done.
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/mmcblk0p2 does not exist.  Dropping to a shell!
BusyBox v1.30.1 (Debian 1:1.30.1-6+b3) built-in shell (ash)
Enter ‘help’ for a list of built-in commands.
(initramfs) e[6n
Hi @Alok_Kumar_Mishra this is a know issue with early BBAI-64 images, please retest with images i posted last week..
flashed two images (they are bbai64-debian-11.3-xfce-arm64-2022-06-14-10gb.img and bbai64-emmc-flasher-debian-11.7-minimal-arm64-2023-05-03-4gb.img.xz) on SD card using balenaetcher and inserted SD card in BB AI64, then I pressed boot button and applied power to the BB AI64 ,so that it boots from SD card),I still cannot boot , serial log says
[ 35.897369] vdd_mmc1: disabling
done.
  • Boot args (cat /proc/cmdline)
    • Check rootdelay= (did the system wait long enough?)
  • Missing modules (cat /proc/modules; ls /dev)
(initramfs) .[6n…
it has been two months since I am trying it to boot, is my board defective…?
