cts-gpios = <&gpioX Y GPIO_ACTIVE_LOW>;
rts-gpios = <&gpioX Z GPIO_ACTIVE_LOW>;
Unfortunately for me, I don’t understand the task above. .dts? Are we rebuilding the Kernel? Can anyone give me some help or point me to some documentation which describes steps on what I need to do. Does getting some handshake lines on a UART t have to be so complicated?
For my list of questions, please refer to the link above.
Hi Robert
Thanks for your assistance. I am sorry to be a burden but I just need a little more help if possible please.
I have done the following:
cloned the beagleboard/bb.org-overlays project
edited the file home\debian/bb.org-overlays/src/arm/BB-UART1-00A0.dts and added (uncommented and changed to mode 7)
BONE_P9_19 (PIN_OUTPUT | MUX_MODE7)|// uart1_rtsn.uart1_rtsn
BONE_P9_20 (PIN_INPUT | MUX_MODE7)|// uart1_ctsn.uart1_ctsn
checked lines 59-64 but found they already contained the text you described.
make
sudo make install
rebooted.
Everything built successfully and no errors were reported.
But when I check my UART1 RTS pin using:
config-pin -q p9.19
Current mode for P9_19 is: default
…there is no change.
I tried changing it to mode0 as for UART1 the the P9 port pin 19 is uart1_rtsn in MODE0 and MODE7 is GPIO.
My test app still cannot manually control RTS and the driver does not automatically drive it for Tx-Enable when I am sending data which is what I am hoping for. (checked on my oscillation).
I think the missing pieces in my understanding might be:
confirming expectations: Are we able to get RTS to automatically drive Tx-Enablke when I send data or must I drive it high manually before I send and low after all data is sent?
confirming which mode I need to set uart1_rtsn and uart1_ctsn to: mode 0 or 7 for RTS to drive my Tx-Enable
confirming if I need to add other parameters to the section in lines 59 - 64? If so, what do I need to add.
confirming if I need to add other parameters from your earlier response to the 8250_omap.yaml file. I also don’t understand how this fits in. Do I need to clone this project or do anything with this file.
