Hi Guys,
I downloaded the latest u-boot and compiled it for devkit8000. But, after putting the new u-boot, my board hang after printing the “DRAM: 128”.
Does anyone here able to use the latest u-boot for devkit8000?.
John
Hi Guys,
John
Hello John,
U-Boot 2010.06-00073-g54841ab (Jul 14 2010 - 08:11:17)
OMAP3530-GP ES3.1, CPU-OPP2 L3-165MHz
OMAP3 DevKit8000 + LPDDR/NAND
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
Die ID #1d82000400000000040365f90100b017
Net: dm9000
No problem here.
Thomas
Hi Thomas,
Thanks for info., I will try it again.
john
Hi Thomas,
Did you re-flash the x-loader too?. I have tried updating the u-boot again but still not working.
Can I have a copy of your u-boot.bin and I will try it to my board if it’s going to work?.
John
Hello John,
x-loader is original from the CD. Is your board working with the bootloader from the CD?
Tomorrow I can send you my u-boot.bin
My toolchain is codesourcery 2010qX
Thomas
Yes, I used the x-loader from the CD. I re-compiled the u-boot source from the CD, flashed it and it works.
john
Hi Thomas,
Additional info, my board has only 128M of RAM. I am not sure if you have the 256M of RAM.
John
Mine boots fine with latest git checkout, too.
U-Boot 2010.06-00152-gd6f324d (Jul 15 2010 - 09:02:30)
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
Die ID #6186000400000000040365fa1900700a
Net: dm9000
OMAP3 DevKit8000 #
Cheers,
Kanru
Hi Kanru,
Can I have a copy of your u-boot.bin?
John
Hello John,
can you come into irc freenode.net #devkit8000
What toolchain do you use?
Can you try some more versions of u-boot? Back to the early days. I think in v2009.11 the Devkit8000 is in.
Yes, I have a 128 MB version too.
Thomas
Hello Thomas,
I am using the latest codesourcery lite version.
I will try the other version tomorrow and let you know.
john
x-load 1.41 binary copied from CD and
u-boot 2010.06 stable compiled from
ftp://ftp.denx.de/pub/u-boot/ source
are work for me (devkit8000).
bootlog:
http://pastebin.com/cFEnzHiq
toolchain:
Sourcery G++ Lite ARM GNU/Linux 2010q1-202
Hello, what are your setenv arguments ?
2010/7/15 林俊良 <goldie.lin@gmail.com>
My boot script:
$ vi boot.cmd
Hi Thomas,
The problem was on my host computer although, I didn’t understand why?. After rebooting my host computer and recompile the latest u-boot source, flashing it to my board then it works.
Btw, have you able to tried to power up the board on USB?
Thanks again,
john
<snip>
Hello John,
no, I have a 7 inch lcd attached + ethernet. So there will be needed to
much current.
Thomas
I have a SBC8100 (like DevKit8000). I am a poor beginner in linux. I
am looking for a ready compiled linux (MLO, uboot, uimage, filesystem
- to start from SD-Card) with drivers and a GUI - e.g. Ubuntu.
I could start the linux which was delivered with the board - but I am
not able to run the Ubuntus or Androids I found in the Internet - I
tried a lot of them.
Could any body help me?
thx
Uwe
MLO from CD,
latest stable U-Boot (2010.06) from ftp://ftp.denx.de/pub/u-boot/
and uImage 2.6.34-rc6-g8ee7837 from http://gitorious.org/devkit8000
are work for my SBC8100.
But I not sure whether it had all drivers you need.
rootfs I used is Ubuntu 10.04 minimal from http://rcn-ee.net/deb/
or custom-built by rootstock.
Do not contain GUI desktop environment packages,
like lxde or lubuntu-desktop,
or you will unable to build Ubuntu 10.04 (lucid) rootfs with rootstock.
And… you should search the BeagleBoard Google Group for more info,
I had posted before.
4G1_FAT32.7z (2.22 MB)
Thank you very much - I hope, I will success
What settings (setenv bootargs...) will I need to boot from SD-Card
with 7''-LCD?
Hello Uwe,
something like
console=ttyS2,115200n8 root=/dev/mmcblk0p2 rootfstype=ext3 rootwait
vram=12M omapdss.def_disp=lcd
omapfb.mode=lcd:800x480 omapfb.mode=dvi:1024x768MR-24@60
Thomas
