here is my uboot log, i don’t know what to ajust to have my bb booting it is in a loop “resetting cpu” where could that come from ? thanks
U-Boot SPL 2015.10 (Sep 13 2024 - 17:17:45)
board is known
Timed out in wait_for_event: status=0000
Check if pads/pull-ups of bus 0 are properly configured
probe error tps
bad magic
U-Boot 2015.10 (Sep 13 2024 - 17:17:45 +0200)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
setting gpio1_3 : gpio 35
board_fdt:_▒▒▒▒▒
Net:
mac: 05c1ef49e20
<ethaddr> not set. Validating first E-fuse MAC
<ethaddr> mac to set is valid
debug ti cpsw
cpsw
select fdt _▒▒▒▒▒.dtb
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** File not found ${script} **
1175 bytes read in 12 ms (94.7 KiB/s)
Importing environment from mmc ...
Running uenvcmd ...
548 bytes read in 68 ms (7.8 KiB/s)
debug1: [/boot/vmlinuz-4.4.13-bone11] ...
7577952 bytes read in 1066 ms (6.8 MiB/s)
debug3: [/boot/initrd.img-4.4.13-bone11] ...
** File not found /boot/initrd.img-4.4.13-bone11 **
debug2: [/boot/dtbs/4.4.13-bone11/am335x-boneblack.dtb] ...
58677 bytes read in 93 ms (615.2 KiB/s)
debug: [console=tty1,115200n8 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait coherent_pool=1M quiet splash video=HDMI-A-1:1024x600MR@60e fbcon=rotate:3 usbcore.authorized_default=0 fsck.mode=auto fsck.repair=yes ima_audit=1 ima_tcb] ...
debug: [bootz 0x82000000 0x88080000:73a160 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x73a160 ]
data abort
pc : [<9ff7089c>] lr : [<9ff708f5>]
reloc pc : [<8080e89c>] lr : [<8080e8f5>]
sp : 9ef41898 ip : 00000000 fp : 9ef4a41c
r10: 00000003 r9 : 9ef41ed8 r8 : 00000002
r7 : 9ffa4ed4 r6 : 9ffa4ed8 r5 : 00000003 r4 : 9ffa4e3c
r3 : 00000000 r2 : 9ffa4e3c r1 : 9ef4a41c r0 : 00000000
Flags: nZcv IRQs off FIQs on Mode SVC_32
Resetting CPU ...
can anyone enlighten me pls ? thanks here is full logs
jerome uboot.txt (1,9 Ko)
